Question about Asrock Computers & Internet
Fsb 1066 manual
Motherboard does not start power supply. No fan works on MB nor power supply. Voltage between "power on" pins is 3.75 VCC. Does exist some fuse on the MB? How can I diagnose and solve this failure? Many thanks in advance.
    Problem Solver:
  • 9 Answers
I'm having the same problem, hope sommeone can answer
Posted on Oct 11, 2013
elcubano
  • 14 Answers
SOURCE: PC won't start - most probably a motherboard problem.
Try this. Re-seat the video card, reseat your memory modules. Unplugg all USB cables. ethernet cables, power cables, and reset your BIOS by finding the reset jumper on your motherboard. Now plug in your keyboard, mouse and power cord. NO USBs, now try and start computer, it if starts replug USBs one at a time after computer is working. If no power up, are you getting any beeps? Possible causes for computer to try and start for a second and immediately power off.
1. Short Circuit (Motherboard touching chasis)
2. Bad power supply
3. Bad/stalled USB device plugged in.
4. Bad connection on Video Card / Memory Module (Corrosion?)
5. Bad Video Card / Bad Monitor
6. Look at the pins on the VGA connector and make sure there are none bend creating a short.
I hope this works for you!
Good Luck!
Posted on Jan 12, 2008
  • 13433 Answers
SOURCE: MOTHERBOARD AUDIO PIN CONNECTIONS
The pins are pretty much universal, I'm 90% certan that the other one of these is correct for you.
Posted on Feb 11, 2008
map9966
  • 2351 Answers
SOURCE: 1333 FSB processor ( E6850 ) on a 1066 FSB motherboard, DDR2 667 memory
Hi proenza. you're making good sence! You're D945GCL MB should be able to run 1066 FSB. Not 100% sure you're memory will keep FSB up to 1066.
Here's the trouble though. The Intel Core 2 Duo E6850 will not run on the Intel D945GCL motherboard because it is not supported. Look here at Intel's web site. Supported CPU's.
http://processormatch.intel.com/CompDB/SearchResult.aspx?Boardname=d945gcl
Intel E6850 specs sheet. http://www.dealtime.com/xPF-Intel-Intel-Core-2-Duo-E6850-Processor-3-0GHz-4MB-Cache-1333MHz-FSB-Conroe-Dual-Core-OEM-Socket-77
Intel E6700 spec sheet. http://www.dealtime.com/xPF-Intel-Core-2-Duo-E6700-2-67Ghz
This CPU is supported by the D945GCL MB.
Intel Core 2 Duo E4700 Processor BX80557E4700 - 2.60GHz.
$149.99
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3826343&CatId=2396
In order to get 1066MHz (CPU can run at), you'll also need the memory support at 800MHz. The D945GCL MB can only run DDR2-667MHz.
Many people buy a CPU to run MB's specs (1333MHz) just to find the same MB does not support DDR2-1066MHz or DDR2-800MHz. Motherboard Mfg's are lagging. DDR3-1333MHz is out there now to support the 1333 MHz CPU FSB.
http://www.lagoom.com/KINGSTON_1G_DDR3_1333MHZ_PC3-10667/KVR1333D3N9_1G/partinfo-id-580235.html
I hope this has helped you make a decision proenza.
Good Luck!
Mike
Posted on Jul 18, 2008
SOURCE: new asus m3n72-d motherboard bios will not post
If you don't already have a case speaker hooked up to the board, you might want to connect one since there isn't an on board speaker and you will not hear error beeps otherwise.
Also, if you have another non-phenom AM2 processor handy you should really update the BIOS to latest release. Many late model Phenoms will not work on motherboards that have earlier BIOS releases and you will not be able to post. You should then choose "Set Optimized Defaults" and save the bios without any changes then shut down (not reset). When you power on again it should post and you should be able to get into the BIOS.
A third thing you can try (after you get a case speaker hooked up) is using a cheap pair of ddr2-6400 RAM to get the board to post so you can get into BIOS and change the voltage to the correct settings for your RAM if it requires a higher voltage than the bios expects.
Posted on Nov 17, 2008
md_ehsan_1
  • 255 Answers
SOURCE: i need gigabyte fsb 1066 motherboard drivers
download from this link
http://www.lostmydrivers.com/bios-and-system-update-drivers/gigabyte/gigabyte-ga-945gcmx-s2-bios-f1.html
Posted on Jun 30, 2009
My computer won't power on. Tested power supply by shorting green to black wire. Found PS fan seized. Replaced fan. Worked with pins shorted.
Admittedly, this could still be your power supply (PSU). Perhaps you did attach the 24 pin motherboard (MB) connection to a tester, but since the post does not specifically mention this I presume you may not have. Forgive me if that was done.
Assuming the test was only jumping the 24 pin connection verifying that fans kicked on; my guess would be that the PSU still functions. However, it may no longer be producing enough juice to power the PC.
If you have not done so already, I recommend testing the power supply against a tester to verify that you are getting enough voltage to power the motherboard.
Oct 24, 2015 | Dell Inspiron 531s Desktop Computer
Ms 7399
"on silver sticker on MB N1996 printed in white directley on MB"
here are some one eBay
N1996 Motherboards eBay
The way a PC shop like I run would 'test' it, would be to connect the PSU to another mobo after using the tester on it. This is because the testers can only test for Voltage, not 'load' (amps.) So it COULD be providing the proper Voltage, but at too low an Amperage which would cause unexpected behavior, or non-start....especially if the Power Good signal is not received by the Motherboard within say 600ms.
Mar 30, 2014 | Computers & Internet
D945gccr MB NO DISPLAY I GUESS ITS BIOS PROBLEM
Maltesh,
1) IF ALL of the LED (Lights) were on they would use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts of power.
3) A typical Processor can use 51 to 125 Watts of power.
Intel D945GCCR motherboard?
Can use up to an Intel Core2 Duo E4700, (800MHz FSB), according to Intel Support,
http://processormatch.intel.com/CompDB/SearchResult.aspx?Boardname=d945gccr
An Intel Core2 Duo E4700 can use up to 65 Watts,
http://en.wikipedia.org/wiki/List_of_Intel_Core_2_microprocessors#.22Allendale.22.2C_.22Conroe.22_.2865_nm.29
Check the Power Supply.
A Power Supply with a weak voltage power rail, will have plenty of power to light LED's, and maybe spin fans, but Not enough power to turn the Processor on.
No processor, no computer.
The computer isn't generating a video signal.
No Signal to the monitor.
Do you have access to a multimeter, or DC Volt meter?
Test the three Low DC voltages coming out of the Power Supply.
A) 3.3 Volt power rail
B) 5 Volt power rail
C) 12 Volt power rail (ALL are DC voltage)
[ In comparison two D cell flashlight batteries store 3 Volts DC ]
Need guidance with testing post back in a Comment.
Or if you have a KNOWN to be good, and Compatible power supply, that you can borrow for a test, try it.
Regards,
joecoolvette
Aug 14, 2012 | Intel Motherboard
What arethe compatible components of this kind motherboard
CPU P5KPL-AM empty.jpg Valuable Intel G31 uATX solution with FSB overclocking 1600MHz!
- Intel® Core™2 Quad Ready
- Intel® 45nm CPU Ready
- FSB 1600(O.C.)/1333/1066/800 MHz
- Intel® G31/ICH7
- Dual channel DDR2 1066(O.C.)/800/667
- EZ Flash2 & CrashFree BIOS3
- 8 Channel High Definition Audio
Intel® Socket 775 Core™2 Quad/Core™2 Extreme/Core™2 Duo/Pentium® D/Pentium® 4/Celeron® E1000 Series and Celeron 400 Series Intel® Hyper-Threading Technology ready
*Refer to www.asus.com for Intel CPU support list
Chipset Intel® G31 Intel ICH7
Front Side Bus 1600*/1333/1066/800 MHz (*1600 is overclock speed) Memory 2 x DIMM, Max. 4 GB, DDR2 1066(O.C.)/800/667 Non-ECC,Un-buffered Memory
Dual Channel memory architecture
*Overclock speed
**Refer to www.asus.com or user manual for Memory QVL (Qualify Vendor List)
***When installing total memory of 4GB capacity or more, WindowsR 32-bit operation system may only recognize less than 3GB. Hence, a total installed memory of less than 3GB is recommended. Expansion Slots 1 x PCIe x16
1 x PCIe x1
2 x PCI
VGA Integrated Intel Graphics Media Accelerator (Intel® GMA 3100)
Max. resolution:2048x1536X32bpp, Horizontal:127.5KHz Vertical:85Hz Storage Southbridge
1 xUltraDMA 100/66/33
4 xSATA 3 Gb/s ports
LAN Realtek RTL8102EL 100/10 LAN
Audio VIA VT1708B 8 -Channel High-Definition Audio CODEC
Anti-Pop Function
Jack-detect & Multi-Streaming
Support S/PDIF Out connector USB 8 USB 2.0 ports (4 ports at mid-board, 4 ports at back panel) Overclocking Features SFS (Stepless Frequency Selection)
- FSB tuning from 200MHz up to 600MHz at 1MHz increment
Overclocking Protection
- ASUS C.P.R.(CPU Parameter Recall)
Special Features ASUS MyLogo 2
ASUS EZ Flash 2
ASUS CrashFree BIOS 3
ASUS Q-Fan
Back Panel I/O Ports 1 x Parallel
1 x VGA
1 x PS/2 Keyboard
1 x PS/2 Mouse
1 x LAN(RJ45) port
4 x USB 2.0/1.1
1 x COM port
8 -Channel Audio I/O
Internal I/O Connectors 2 x USB connectors support additional 4 USB ports
1 x Floppy disk drive connector
1 x IDE connector
4 x SATA connectors
1 x internal speaker connector
1 x S/PDIF Out connector
1 x CPU/ Chassis/ Power Fan connector
1 x Front panel High Definition audio connector
1 x Chassis Intrusion connector
1 x CD audio in connector
24-pin EPS 12V Power connector
4-pin ATX 12V Power connector
1 x System Panel connector
BIOS 8 Mb Flash ROM
DMI 2.0
AMI BIOS
PnP
WfM 2.0
SM BIOS 2.5
ACPI 2.0
Manageability WOL,PXE,RPL,WOR ,PME Wake Up Accessories User's manual
1 x UltraDMA 133/100/66 cable
1 x Floppy disk drive cable
1 x SATA cable
1 x SATA power cable
I/O Shield
Support Disc Drivers
ASUS PC Probe II
Anti-virus software (OEM version)
ASUS Update
Form Factor uATX Form Factor
9.6 inch x8 inch ( 24.4 cm x 20.3 cm )
hope this helps
Jul 18, 2011 | ASUS P5KPL-AM - Motherboard - micro ATX -...
Currently i am using desktop computer celeron 1.7 Ghz which i am thinking to replaced by a P4(2.8 or 3.06) processor on the same motherboard. Apparently there is a voltage difference between 2...
If you motherboard will accept the P4 speed you want, you will NOT need to change anything. The board will automatically adjust the voltage when it sense the new cpu. I do recommend you upgrade your power supply that will support the voltage requirement. Most time when vendors build a pc with a low voltage cpu they usually use low voltage power supplies.
Check your motherboard specs, inparticular the voltage requirments and processor that are compatiable with your model board.
Good Luck.
C2Solutions
Jan 22, 2011 | Foxconn 661FX7MF-S Motherboard
Does not boot
To exclude a possible short, remove the MB from the case and place MB on to a couple phone books thats covered with a non static MB bag. Connect power supply, keyboard, mouse, primary hard disk drive, monitor and internal speaker. Also leaving CPU/heatsink assembly and memory connected.
Short the power-on pins by using a pen. See page
1-34 in you're manual, PWR BTN. If the system boots ok than there was a short with the MB while in the case. If the system does not boot than the MB is bad or the bios needs flashed. Keep the MB out of the case and follow the instructions on page 2-2 section 2.1.1
Link to Asus; http://usa.asus.com/Search.aspx?SearchKey=P5RD1-VM
Hope you find this helpful!
Mike
May 08, 2010 | ASUS P5RD1-VM Motherboard
Ax4per with 1.8GHz does not recognize new 2.8GHz processor. Socket 478. BIOS is current. Is it not plug and play?
Does it POST and can you get into the BIOS? You need to set the FSB to 133MHz and the Ratio to 21x.
(I am assuming you did install the CPU correctly and installed the fan.)
If you can't get into the BIOS, you may need to reset it using JP14 on the motherboard.
Turn OFF power. Remove the AC power cord. Hold the power button in for 5 to 10 seconds. (This is done to discharge any capacitors.) JP14 normally is on Pins 1 and 2. Place the jumper on Pins 2 and 3 for approx. 10 seconds. Then place it back on pins 1 and 2. Connect the power cord and turn it on. This will set all the BIOS settiings to default and you should be able to set the FSB and Ratio.
Do you have a manual for the MB? you can get it from:
ftp://ftp.aopen.com/pub/manual/mb/ax4per/ax4per-ol-e.pdf
Thanks for using Fixya.
Wayne
Sep 10, 2009 | AOpen AX4PER 845PE P4-533MHz...
$149.99
Good Luck!
Mike
Jul 17, 2008 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
Matsonic MS8328E user manual
Here is the pin out for USB connector. 1 VCC 2 VCC 3 USB0 4 USB1 5 USB0+ 6 USB1+ 7 GND 8 GND 9 Key(no pin) 10 USBOC
Aug 10, 2007 | Matsonic 8328E (MS8328E) Motherboard
Computers & Internet Logo
252 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Computer Links
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
