Question about Wolfgang Puck Bistro Collection Blender
The base spins when I turn it on without the attachment but when I put the attachment on it will not attach
    Problem Solver:
  • 9 Answers
Try locking it in reverse, turn it the other way.
Posted on Oct 11, 2013
Making a high pitched noise while blending; is motor breaking down?
there are some Breville Blender troubleshooting tips here
http://brevilleusasupport.com/bbl550xl/troubleshooting . Tied in with that, a high pitched noise could come in from a few directions:
Some blenders will use reduction gears to get more torque and power out of a high RPM, lower power motor. If this is the case, the whine could be from the motor, though if you hadn't noticed before, that would not be reassuring.
Per the troubleshooting, check that the blade is firmly attached, and that the coupling from jug to base is firm. If there are gaps or loos spots, there can be buzzing or whining between sort-of-spinning parts and shafts or bolt threads.
Check the motor base for dried spilled-on margarita mix or marinara sauce or what have you. they try to seal this pretty tight in a blender, but it has to spin, so food spills can get in the gap and cause friction and resistance, which can in turn cause whining noises from parts not expecting the load. If you do any cleaning or poking there, make sure you unplug the blender first. Shocks are not fun.
likewise, make sure that blade rotates easily from turning the coupling on the outside of the jug. If not, the bearing may be siezed or contaminated. That you'd likely want to fix by replacement.
Hope this helps!
D
Nov 19, 2015 | Breville Blenders
Why doesn't blade spin?
Either the coupling from the motor with the fingers on it is not really attached to the motor shaft or the drive on the blade that engages with it is not attached to the blade shaft. One other thing is that on some models if the rubber jar seal between the beaker and the blade carrier is in the wrong place it can raise the blade drive to not engaging properly with the motor coupling. The gasket goes between the jar and the blade carrier, not under the blade carrier.
Sep 04, 2015 | KitchenAid KSB3 Classic Work Top Blender
I can manually turn the blades inside the glass pitcher and I can turn the piece on the top of the motor base into which the pitcher blade attachment fits.
One of the parts is not being driven properly. Either the clutch on the top of the motor is not really attached to the motor shaft OR the clutch on the bottom of the blade is not engaging with the motor clutch OR the blade clutch is not properly attached to the blade shaft. On some models if you put the rubber sealing ring in the wrong place between the beaker and the blade housing it is enough to lift the clutches apart. The rubber wing goes between the beaker and the blade housing, not between the blade housing and the blade retaining ring.
Jul 14, 2015 | Blenders
Does anyone have a schematic showing how to put the motor back together. mine was taken apart, and now I can't find the washers and need to replace and put everything back together correctly. any help...
follow this steps . God bless you
  1. Unplug the blender and remove the jar. Undo the screws securing the baseplate. Separate the baseplate and attached motor collar from the base housing.
  2. To remove the switch housing, remove the decorative facing to get at the top screws. Remove the lower screws from inside the blender base.
  3. Hold the fan to keep the motor shaft from turning as you unscrew the drive stud. Remove the shield and any washers. Unscrew the fan nut to remove the fan.
  4. Disengage the strain-relief fitting from the housing. Remove the wire connector joining the power cord and the lead to the brush housing.
  5. Label and disconnect the lead wires from the switch block. Remove the motor mounting bolts and lift out the motor if necessary.
  6. To free brushes, remove the leads attached to the brush housing. Use a screwdriver to press lead terminal through the slot in housing. The brush spring may pop out (don't lose it!).
Nov 24, 2013 | Waring MBB518 2Speed Blender
I'm using the single serve mixer and it's stuck on the base and won't come off!
follow this steps and fix it. God bless you
Nov 04, 2013 | Blenders
Hello, I ordered a replacement coupling gear(?) and need to figure out how to replace it. This is the little grey plastic gear that attaches to the base unit causing the blade to spin. Here are some...
Hope you have solved your problem by now, but put a flathead screw driver in the bottom of the blender to hold the blender shaft in place then turn the gear by hand or with a plyers and it should just screw off, it is reverse threaded...
Jul 14, 2011 | Krups GMA1-42 Power Xtreme VI Work Top...
I have been given a Kenwood BL300 blender. After using it to make breadcrumbs, I undid it somehow and now I can't get it back together. Can't remember if the blade goes straight into the base or the jug,...
You need to unfasten the white base from the clear jug, then the rotating blade will sit inside the white base, with the blade facing upwards. The white rubber flange goes in next. Then screw the assembled base back into the clear jug. The jug should then fit on to the stand.
Dec 08, 2010 | Kenwood BL300 SingleSpeed Blender
Cuisinart fpb-5ch blender not working
Remove blender attachment completely, turn machine on and see if it will spin with all attachments removed - if it spins, then replace the blade assembly - parts available from Cuisinart. If it doesn't spin, send to Cuisinart for repair (call first).
Dec 11, 2008 | Blenders
Cuisinart DFP-14 Series does not start
First, do a motor test by removing the work bowl completely and using a pen to press in the grey button on top of the base (with the food processor plugged in and turned on of course), toward the back. If the processor spins, the motor is still good. At that point, I would inspect the work bowl pieces, lid, pusher assembly, etc for cracks/damage. If all appears well, insert ALL the pieces back into place and try again. For the DFP-14, remember: handle faces front, feed tube faces back, and metal element on back of pusher faces back of processor. Connect the pieces separately - if you try to put the work bowl on with the lid and pusher already attached, it will not always lock properly. If even one piece is out of place, the processor will not spin.
If it no longer spins, the motor has a problem.
-Tha Mp3 Doctor
Nov 17, 2008 | Blenders
Attaching top container to bottom tub.
Place food processor attachment on base
Put work bowl on gear collar with left slot just to the left of the tab on left side, slide until tabs click
Place work bowl lid on top of workbowl with tabs slightly to left of work bowl handle - slide into place until it clicks
Nov 13, 2008 | Cuisinart BFP-703 Blender
Wolfgang Puck Bistro Collection Blender Logo
66 people viewed this question
Top Wolfgang Puck Blenders Experts
ray gallant
Bill Boyd
Are you a Wolfgang Puck Blender Expert? Answer questions, earn points and help others
