Question about Pioneer DEH-P790BT
Pioneer deh p790bt display only works when open and goes out when faceplate is closed. everything works but no display.
    New Friend:
    Problem Solver:
  • 15 Answers
The ribbon cable is bad. This is easily repairable. I think Best Buy still does them or call your local electronics repair shop.
Posted on Nov 16, 2013
Jexx
  • 148 Answers
SOURCE: Screen behind faceplate stopped illuminating/working
The ribbon cable has gone bad. A new one can be ordered direct from pioneer at parts.pioneerelectronics.com Good luck!
Posted on Nov 05, 2006
SOURCE: display problem
Hello, I had the same problem with my 7800, I found R841 was open. Try this.
Sorry for my english, I´m from Argentina. Good luck.
Posted on Oct 10, 2008
SOURCE: Lost Faceplate for Car Stereo Pioneer Premier DEH-P700BT
e-bay
Posted on Feb 02, 2009
SOURCE: pioneer premier deh-p980bt screen went blank
Its the ribbon cable needs replacing going from the deck to the faceplate
Posted on Aug 13, 2009
MNfisherman
  • 11896 Answers
SOURCE: Another one with Faceplate buttons not working?
The capacitors in these plates tend to burn out quickly for being so hot and lack of air cooling circulation. You can test all connection pins on the deck and faceplate with an ohmmeter in ohm setting to see which pins is not sending 25-30 ohms or 5 volts of power
Posted on Oct 23, 2009
Hello, I have an odd problem with my Pioneer DEH-P9800BT Screen
Clean all contacts chemically and check all wiring for good, tight connections.
Aug 25, 2017 | Pioneer DEH-P9800BT CD/MP3/WMA Player/Blue...
My Pioneer DEH-P9800 BT faceplate won't close
The clip that locks the plate into place probably broke.
Mar 20, 2013 | Pioneer DEH-P9800BT - In-Dash CD/MP3/WMA...
Basically I have the same problem that has been displayed a lot on this site. My pioneer DEH-P7800MP display won't show when the face closes. When the face opens up all the buttons and lights and display...
The faceplate and head unit is is attached via a flat ribbon cable. (Caution only continue if you have some courage). If you open the faceplate you will see that the ribbon cable is seated in too a flat connector on the PCB (Printed Circuit Board). This connector has a locking mechanism on it that when locked presses the contacts of the cable to the connector. Ensure that the cable is seated properly and that the latch or the lock is in the locked position. Assuming that the tension lessons when the unit is closed so it draws away from the connector and when the unit is open it pulls tension creating a contact. If you see no signs of mishap on this end of the connector try the other end.
Hope this helps.
Nov 17, 2010 | Pioneer DEH-P7800MP
Faceplate won't display
if its a fold down display the ribbon cable is gone, repair shop job) it goes from the front panel into the motherboard of the stereo and after a while with you opening and closing the display the cable eventually breaks, if its not a fold down display clean the contacts of the front panel with meths and a cotton bud, if still no joy take it to repair shop,
May 09, 2009 | Car Audio & Video
OEL Display not Working on my Pioneer DEH-P7800MP
Do you take the faceplate off often? If so mayeb you could try wiping the metal contact plate on the unit b4 u put on the faceplate.
Jun 02, 2008 | Pioneer DEH-P7800MP
Display
go into your tools menu by pressing the center of the multi knob.(the volume control knob) turn same knob to bring up the entertainment field, press center of knob to set then turn till you get to the prompt about alternating screen. switch to no. done.
Apr 06, 2008 | Pioneer DEH-P790BT
Display problem
Mar 27, 2008 | Pioneer DEH-P7800MP
Nov 03, 2006 | Pioneer Premier DEH-P960MP CD Player
Pioneer DEH-P790BT Logo
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
