Question about RCA DISH Network(r) 311 Satellite System
TV ''Dish'' not working on second TV
Built new house, ran RG6 from old house to new house. Connected RG6 at available port multiswitch on Sat dish and to a distribution panel in new house. One receiver in new house works great. Second receiver only recognizes one satelite when on alone and goes to searching for satelite when good receiver is turned on. I've switched receivers with same result. Could I have a bad crimp on the RG6 to the second room? I get good digital antenae reception when second room is connected to antenae
  • 56 Answers
Check sat in cable, if cracks or breaks in line can cause sfss. also on back of receiver you want to make sure that sat in cable has a little copper wire sticking straight up and that its getting a good connection on the back of the receiver.
Posted on Apr 28, 2009
How to hook up Dish Network Receiver
which Dish Receiver do u have. if it is a Dual Tuner (322,625,622, 722) u run a RG6 Coax from the Dish to the back of the Receiver. on back of the receiver there should be two ports (Dish 1,, and Dish2) u will need two short pieces of coax and a Separator ,(which should have come with the Receiver. u hook the coax from the outside Dish to the single port of the Separator , now u run a coax (or RCA or what ever) to the TV. Turn on TV and Receiver.
on the Dish remote u hit the Menu button and hit #6 then #1 and #1 again (wait for each screen to change ) u should see a signal bar at the bottom. U will need to get someone to turn the dish a little at a time till u get a signal. once u get a strong signal u hit the Check Switch and let it program.
Sep 23, 2014 | DISH Network Televison & Video
My VP 612 will not give a signal to the 2nd TV. We had a have a VIP 211 and it works fine.
Hi there Rick, my name is Kimberly and I form part of the Social Media Department with DISH. It is my pleasure to help you. A VIP 612 is a single receiver, meaning it can only control one tv independently, if you do have a second Tv connected it is mirrored correct? (meaning it watches/shares the same programming as the main TV connected directly to the receiver) If so, the TV connected with RG6 cable must be on channel 3 in order to receive a picture. Feel free to reach me at: kimberly.escobar@dish.com if you have any additional questions or concerns.
Kimberly Escobar
Social Media Representative
DISH L.L.C
Mar 02, 2014 | DISH Network ViP 612
Lcd Tv has colored lines
Yuu amy have a possible Gorund problem. Call the Cable Company and find out if they can install an ISOLATOR in the input of the RG6 that feed the enitire home. The ISOLATOR Should say 5-1000Ghz this will filter any noice or Hum that you see on your set..Make sure his home has a ground. If the cable company doesn't supply the ISOLATOR go online and Goole the Part..it looks like a sliver tube. It sells for $50 and up. If his using a Dish call the Dish people. Make sure the Dish is Grounded.
Mar 18, 2010 | Televison & Video
HOW TO HOOK UP TWO SATELLITE RECIVERS THAT I HAVE LIKE MODEL 4000 DISHJNETWORK RECIVER I FOUND IN MY CLOSET AND MY NEW DISH NETWORK RENTED DVR 625 RECIVER HOW TOO HOOK BOTH OF THEM UP TO THE 3 CABLES AND...
Ok since you have A 625 it uses different technology than the 4000 in a sense but I will assume that whomever connected the 625 use a Dish Pro Plus LNB. You can verify this by going out to the dish and looking at the LNB which is the eyes if you will on the dish. The cover facing you will read DP Plus, or Dish Pro, Dish Network, or you may have nothing at all on the housing. You will want it to say DP Plus for the easiest install.
On this LNB there are three ports. You will only need the two on the left if looking at it so you can not read the housing. One of the ports will be connected to a line running to the 625 and the other to the 4000. The line going to the 4000 should not contain any breaks in it after the ground block if one was used. Once inside the house connect the line from the lnb for the 4000 to the back of the receiver. Conect the receiver to the TV and run a check switch. This receiver will go into a test of 1 of 38 if all connections are good. A 1 of 50 indicates a loss of signal somewher on that side of the install.
The 625 can utilize di plexers but that type of install is to detailed to go into straight away so we will connect it using a straight feed to TV2. Run the cable from the LNB into th room with the 625. Inside connect that line to a siver device called a seperator that came with the receiver and connect the two leads from it to the sat in ports on the back of the receiver. Connect a line to the Home distribution port on the back of the receiver and run it to the room with the second tv you want to have DVR in such as a mater bedroom etc.Connect the cable from the tv out port on the receiver to the tv. Power all devices on and run a check switch. This test should read 1 of 3 if all connections are good. A bad connection will read 1 of 38 on the receiver. A total absence of signal will stay at 1 of 1 for a longt ime brfore going to 1 of 38.
You will need to call dish and activate the 4000 rx since it has not been on the account for some time and will need a software update that they will send to it via satellite.
Other obstacles could arise and if they do let me know. Thanks for using Fix Ya.
Feb 28, 2010 | DISH Network DVR-625 DTV Receiver /...
Hi guys, I bought new HD TV I have Dish receiver,# VIP211hd. Tv is not seeing HDMI signal. Tried three diff cables into all 4 ports on tv. DVD player works in any of them .Dish tells me output is port...
This is a really difficult problem to answer correctly on the first try but here we go. Some tvs will not recognize the introduction of a new component without unplugging the tv for about 30 seconds with the component connected and powering the tv back on. The issue I believe Dish was trying to convey was to make sure the port you plug the receiver into is turned on in the tv menu. Since the dvd works in any of them this seems to be the case. I f you have further difficulties you should contact the tv manufacturer for assistance as they are more familiar with teaching the tv to communicate with the receiver than Dish personell will be in most cases.
Jan 30, 2009 | DISH Network ViP 211 DTV Receiver
Tv has sound but no picture.
If it works on DVD but not on your Dish, and when you connected it to another house it had the same problem then it sounds like your input connection is bad on the TV. That is if I am understanding this right. From what I am reading your Dish network is not showing a picture but the audio is working fine. The DVD player works fine on the TV though. Then you took the TV and hooked it to another dish system and it was the same problem. That sounds to me like you TV is having a problem, either that or the cables for your Dish network are bad. Try switching to a different input, like the one the DVD player is on and seeing if it works there. If not, then the cables are bad and you just need to replace the cables. If it does work though where the DVD was working before then your TV input is bad on that port you were hooked to before.
Let me know if you have any other questions and if this was helpful. If you need some more clarification let me know, I hope this is helpful. Good luck and have a good weekend. Get it fixed before the Super Bowl.
Jan 25, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Set Up for DVR
Hello: If you have only one incoming cable, just hook it up on SAT 1. What happens is that you will only be able to record what you're watching. If you want two incoming cables, just change the LNB to a dual LNB if you have a round dish. If you have an oval dish, most likely has a multiswitch LNB, so all you need to do is hook up another cable to that LNB and run it to the receiver and put it on SAT 2.
This way, you can watch one program and record another program on a dif. channel at the same time. Either way, you need to take out the LNB from the dish for one or the other option. It's best to contact your service provider and get a tech, to do the changes. It's not costly.
Jan 16, 2009 | Samsung SIR-S4040R DirecTV DTV Receiver /...
Adding tv to a dish network dvr
Your upstairs tv is connected via a coaxial cable and you can do a few things to get programming to the third room.
The first is to locate the wire that enters the upsairs room that currently has tv and insert a splitter by cutting the line to that room and running the out ports to the rooms and the in port to the other end of the wire that you cut. This will give you the same picture in both rooms.
If you have a system that does not use diplexers to backfeed the second TV you can backfeed the 3-4 cable going to the TV1 by cutting the line and adding a splitter with the inport running to the 3-4 port on the receiver and one of the out ports going to your tv1 and the other outport going into the UHF side of a diplexer. You will need to cut the Satellite feed into the back of the receiver on the back side of the seperator and connect the seperator to the SAT port of the diplexer. The IN/OUT port of the diplexer will connect to the end of the sat feed cable that goes to the wall plate. This will allow you to go into the attic of outside of the house and find the sat cable that feeds the TV one and break it there and put the IN/OUT port of that diplexer facing the TV1 room and the SAT port connecting to the other end of the cable you broke. The remaining UHF port will be the feed for the new room that you wish to connect. This set up will allow for viewing the same program as that at the TV1 location however you will need to change the channels at the TV1 location or buy an IR to UHF converter to allow you to be able to work the system independently from the receiver. Hope this answered your question. IF you need further assistance please contact me and thanks for using Fix Ya.
Dec 24, 2008 | DISH Network ViP622 DVR DTV Receiver /...
Second DirecTv box unable to locate a signal
it is multi sat multi sat compatable!My opinion is buy a powerd multi switch you can getem at radio shack or from a sat dealer that will clear p your prolem i belive also check all your rg6 coax ends u may have a a bad splice or a fraid shiel wich will make your reciever do the same thing but hope you can fix it
Goodluck
Please rate
Dec 11, 2007 | Televison & Video
Lost locals thru multiswitch
Do you have at least a 2-channel LNB on your system?...accordianman
Oct 15, 2007 | Samsung SIR-S4040R DirecTV DTV Receiver /...
Televison & Video Logo
1,325 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
