Sony dvp sr510h
Unit won't power on. Less than a year old. Has been used less than 10 times. Unplugged from wall and plugged it back in. No change. Unplugged HDMI cable from unit per Sony web site. No change. Thoughts?
MakikiChris
  • 84 Answers
SOURCE: RCA RTD258 Not working
Do you have a DVD in the player? If an incompatible region code disc was left in the player upon shutdown, it will cause your particular system to lockup. Your unit has a 1 year warranty, and you can easily obtain over the phone help from RCA by calling 580-634-0366 and have your unit?s date of purchase and model/serial number ready. The model/serial number information is on the back of your unit. During your phone call the Technician will determine if you should receive a replacement unit, and if so, will provide you all of the relavent information and a Service Request Number for your tracking convenience. Keep this SR# permanently so you can cite your history should future problems arise, also, a helpful tip is should you utilize a Passcode for your system and forget it, the Master Passcode is 9688.
Posted on Jul 31, 2007
SOURCE: IN76 Pojector Just Turned Off, Will Not Turn Back On
same thing on my in76. a color wheel had to be replaced. projector is less than a year old an all parts and labour was covered.
Posted on Jan 23, 2008
  • 59 Answers
SOURCE: Sony DVP-NC85H Multi-disc DVD Tray locked
Look on the bottom of the unit. There is a hole with the letters ex and op. Shine a light in the hole and you will see a white plastic object with a slot for a slot screwdriver. You can turn this either way but be careful. If you feel resistance and the object does not turn, turn the other direction and the unit will open. Remember if the disc loaded the clamping of the disc is in place so you must turn it the proper way to let the current disc loose hence the op and the ex. Op is open. Ex is exchange.
JC
Posted on Jul 27, 2008
SOURCE: Sony ICF-CD855V clock radio no power
Transformer wire that connected to one of the AC terminals was broken. Soldered a jumper wire between the terminal and the transformer. The most difficult part was finding a tool to remove the 3 triangle headed screws from the power supply, ended up making my own tool.
Posted on Dec 31, 2008
rayname
  • 70 Answers
SOURCE: Wall unit emits a chemical smell when the unit is running
check the condensate pan clean out with vinegar water solution make sure you do not see any oil residue that would be a sign of a refrigerant leak let me know if you have further problems your manual should tell you how to get the cover off
Posted on Jan 08, 2009
Sony DVD player SR510H hook up to Panasonic TV but no sound or picture
Describe your "hook-up" hardware. Make sure you are using "out" socket or HDMI plug-in socket at back of DVD player.
May 22, 2015 | Sony DVP SR510H - DVD player
I need the dezoning code for a Sony DVP-SR510H DVD player.
You maybe able to get a region free code off these WEB sites.
Unlock DVD Players - Region Free Code
www.dvdexploder.com/ www.download-info.com/dvd/index_new.htm
Jan 01, 2013 | Sony DVP SR510H - DVD player
Sony DVD Player not working
The controller board is slowly dying. I think it might be time to buy a new DVD player.
Aug 19, 2012 | Sony DVP SR510H - DVD player
Sony DVP-S7000 DVD player does not respond to front panel buttons or the remote control
The only possible solution and it is a long shot, unplug unit from wall receptical, now press and hold power for 60 seconds, this will drain any residual voltage and reset the microprocessor in hopes it will work. If this fails I recommend the sony technician.
Jul 17, 2012 | Sony DVP-S7000 DVD Player
It says push power protector on my new sony surround system i cant do anything with it
Protect mode will kicking whenever a fault is detected.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Apr 17, 2009 | Sony BRAVIA DAV-HDX267W Theater System...
Sony home theater system started blinking protect
Bad speaker wiring.
Internal fault.
Regards.
Mar 23, 2009 | Sony DAV-DX250 System
Power turns off
Protect mode will kick in whenever a fault is detected.
You get the unit not powering up, and sometimes you hear a clicking noise, that is the protection switch that keeps shutting down the unit.
Bad speaker wiring.
Internal fault.
Regards.
Jan 31, 2009 | Samsung HT-X50 System
Unit shuts itself off after 10 -15 minutes
Bad speaker wiring.
Internal fault.
Regards.
Jan 08, 2009 | Samsung HT-WX70 Theater System
No power to Compaq Presario
There were several recalls on Compaq's ac adapters and batteries that caused fire to units...
Check this out
http://www.consumeraffairs.com/recalls04/2006/hp_batteries.html
I would also check with compaq about your problem. They were replacing and repairing the units free of charge due to the defects. I would check with them
Hope this helps you
Oct 21, 2007 | HP Compaq Presario R4010US (PX352UA) PC...
Televison & Video Logo
Top Televison & Video Experts
