Question about Bosch AquaStar 2400ES-NG
Bosh aquastar 240fx intermittent hot water delivered
4 Suggested Answers
mrhotandcold
  • 248 Answers
SOURCE: bought a TK-RE02 for my aquastar 240fx (takagi
the basic installation will be the same only the setting will be different boiler wil be factory set shouldn,t be a problem best of luck
Posted on Nov 10, 2009
c7121
  • 160 Answers
SOURCE: BOSH 240FX WATER HEATER WITH 11 FUALT CODE
CHECK AND MAKE SURE THE GAS SHUT OFF VALVE IS OPEN COMPLETELY.
Posted on Dec 15, 2009
heatman101
  • 43501 Answers
SOURCE: I HAVE A BOSH TANKLESS
The problem will be one of two things....
1 - The burner is not staying on when it should be...it goes out recycles and then refires.... it is going out because of a problem with the flame sensing...
I don't think it is this problem though...
1 - The other problem and the one I think that it is....
The flow switch is notsensing the water flow properly....the switch is either in the full on or the full off position...therefore the burner is either one full fire or it is off, ther is no modulation of the burner....checking this out could be a very difficult process... but the first thing that I would do is to replace the flow switch and then the board if it keeps up once you know that you have a good flow switch...
heatman101
Posted on Jan 19, 2011
Bosh 2400eng makeing noise at start up and sht down,loud noise
possibly needs descaling and or pump needs replacing
Sep 18, 2013 | Bosch AquaStar 2400ES-NG
We have a Bosh GWH2400ENG Tankless Water Heater. I cannot seem to get the unit to produce any hot water at all or if I can get it to start to produce hot water it does for mabey a minute and then shuts...
Look for the error code on heater. Go to: http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/2400ETechSupport/Troubleshooting/tabid/1131/Default.aspx
For technical support on your heater.
Apr 23, 2011 | Bosch AquaStar 2400ES-NG
Bosch 1600H-NG Natural Gas AquaStar AquaStar Natural Gas Tankless Water Heater. Problems with constant hot water. The heater turns ok but (i think) when i turn on the cold side the heater stops. at...
Possible flow sensor issue. Check to see if your water pressure fluctuates a lot or is fairly steady. These units are sensitive to the pressure. take care.
Feb 19, 2011 | Bosch 1600H-NG Natural Gas AquaStar...
I have a 16h Bosh hydropower hot water heater . The unit suddenly has no spark .I have taken off the little generater cap and thouroughly cleaned it and the internal turbine . With no improvement . All...
sounds like the generator has packed up. check water flow and clean any filters on the water line. you will need a service agent to check milli volts on generator and power pack
Dec 15, 2010 | Bosch 1600H-LP Liquid Propane AquaStar...
Dec 01, 2009 | Bosch & Tankless LP Hot Water Heater
Bosch Aquastar 2400E LP Does Not Heat Water
Sounds like the water flow sensor and servo, may just need cleaning, get it checked out by a Bosch agent
Nov 10, 2009 | Bosch AquaStar 2400ES-NG
Takes long time to heat then goes from hot to cold.
I know that this is a great answer but with out being there its hard to answer you call there tech support they are great, I have had to call they from jobs before they can help
Phone Support:
Gas Products Technical Support: 800-642-3111
Electric Product Technical Support: 866-330-2729
Feb 03, 2009 | Bosch 1600H-NG Natural Gas AquaStar...
Bosch AquaStar 2400ES-NG  Logo
60 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
Donni Steen
john h
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
