Question about HP LaserJet 9050 Printer
49.4CF1 service error - HP LaserJet 9050 Printer
    Novelist:
  • HP Expert
  • 175 Answers
49.4CF1 = gen firmware error-
Common problem on LJ9000 series. most likely a corrupt file has been sent to print,
How to Clear- switch printer OFF
if the net card is not built into the formatter- then unscrew and remove - remove all network/USB points from printer and then cycle the power- leave the printer disconnected from network and allow to reach ready state( If the machine still shows error- read below) if the machine does clear and reach ready then the error is with a bad file in the Print Spooler Que and may still need to be cleared from the print que (on the PC). If the error does not clear then you may need to Reset the machine - to perform a cold reset.
Switch power ON- Wait until Memory Check is Running( lots of asterisks on screen) whilst the mem check is running press and HOLD the green Tick button, Hold until all Three Heartbeat lights have come on together- let go of the tick button use the scroll buttons to navigate down to Cold Reset select and press tick cold reset is now performed- if this doesnt clear your issue then please contact your service Department and inform them that a new formatter may well be required-this repair can be completed using Belmonte Business Equipment.co.uk
Posted on Oct 11, 2013
Chassis settings service required error message. 2007 v70R with all OEM shocks and alighnment done about 1K miles later the error message comes on.
About 3,440 results (0.84 seconds) Search Results
    Chassis Settings Service Required - Page 2 - 2004 - 2007 V70R ...
    v70r.com > Home > Volvo > 2004 - 2007 V70R
    Nov 1, 2011 - So, in our case it seems that the shock / strut itself is totally undamaged (at .... As usual, the "chassis setting service required" message didn't show as I ....All of them will indeed need to be replaced when normal weeping ..... Error codes 0115 and 0201 can be related to a low battery, but 0023 and 0113 ...Missing: oem
    www.fixya.com/cars/t26080647-chassis_settings_service_required_error
    1 hour ago - Chassis settings service required error message. 2007 v70R with all OEM shocks and alighnment done about 1K miles later the error message ...
    Volvo S60 R "Chassis settings service required" warning - Swedespeed
    forums.swedespeed.com > Forum > Ask IPD > General Maintenance
    Sep 26, 2008 - 29 posts - ‎15 authors
    Now I have this message "chassis setting service required" Did the guys hit ... My way costly Volvo Service Department wants me to bring the car in for ... The explanation was that there is a defective shock and they ... First try was to replace a strut that gave a error. ... All is back to normal. .... 2004 V70R - GT. "Anti-Skid Service Required"
    Dec 22, 2012
    "chassis settings service required"
    Sep 4, 2012
    Another "Chassis Settings Service Required" thread
    Aug 13, 2012
    AntiSkid Service Required and Chasis Settings ...
    Dec 5, 2
Feb 03, 2016 | Cars & Trucks
Laser scanner unit error. Turn off the printer, and then turn it on again. If the same error occurs, turn off the printer, then contact the store you purchased the printer, or a service representative....
Turn off the printer, and then turn it on again. If the same error occurs, turn off the printer, then contact the store you purchased the printer, or a service representative. When contacting the service representative, inform them of the error code displayed and symptoms.
Error Code: E100 0000
Mar 26, 2012 | Canon LASER SHOT LBP-2900 Printer
Error call service 4000:00433933
The codes on this model are the same as on the Kyocera Mita copiers.
ie: 4-digit codes
Call service 0150 engine pcb EEPROM error
Call service 0420 option paper feeder communication error
Call service 1010 lift motor lock error
Call service 1140 lift motor going up error
Call service 1150 lift motor going down error
Call service 2000 main motor error
Call service 2200 drum motor error
Call service 4000 laser scanner unit (polygon motor) error
Call service 4200 laser scanner unit (pin photo sensor) error
Call service 5100 short-circuited main charger output
Call service 6000 broken fuser heater lamp M wire
Call service 6020 abnormally high fuser thermistor M temperature
Call service 6030 broken fuser thermistor M wire
Call service 6400 zero-crossing signal problem
Call service 7000 toner motor lock error
Call service 7410 drum unit non-installing error
Call service F000 communication error between the main controller board and operation panel board
Call service F010 main board (system DIMM board) checksum error
Call service F020 main or expanded memory error
Call service F030 general failure
Call service F040 communication problem between main board and engine board
Call service F226 main pcb video data control error
May 18, 2011 | Kyocera FS-3900DN Laser Printer
Please call for service
If the machine is saying "Please Call Service"..you will have to access the Service Call function to determine the exact problem.
Press PROG,*,6
Press PROG to select "service call" mode, then press ENTER.
The Error Mssge will be displayed.
For example Heater Error, Drum Fuse Error, Inside Fan Error, etc, etc...
**Most common( given m/c age.) would be "Heater Error"...which indicates a problem with the Fuser Unit.....if this is the case you will need to contact local Muratec service for parts.
Oct 23, 2010 | Muratec - MFX-1300 Copier
Message is Service call error 00010014
SERVICE CALL 00010014
Description
Failure of pressurizing
Nov 21, 2009 | Epson Stylus Pro 9800 InkJet Printer
My OKI printer is giving me a message which reads, "Service Call 106: Fatal Error".
YYYY
106: FATAL ERROR
An error has
occurred which
requires service.
YYYY = the general
cause. 106 = error
number.
Try turning off the
printer then turning it
back on. If this does
not remedy the
problem, write down
the message including
the error number
“106,” then call your
authorized Oki Data
Service Dealer for
service.
Note: If you see a
series of octets
containing letters and
numbers scrolling
across the display, be
sure to write these
down also and report
them to the Service
Fuser error. Replace fuser or if no-go, Main board.
Aug 26, 2009 | Office Equipment & Supplies
Computer shows no display
did you try installing newest drivers from intel/gigabyte website? what you described looks to me as a overheating problem. try running the game with case open. are you running on the integrated GMA graphics or PCI-E graphics card(like geforce, radeon)?
Jul 02, 2009 | Gigabyte Computers & Internet
Epson stylus pro10000 problem service reg
SERVICE REQ. 00020000:NVRAM ERROR
SERVICE REQ. 00020001:NVRAM COMPARISON ERROR
SERVICE REQ. 00020002:SDRAM ERROR
SERVICE REQ. 00020003:FLASH MEMORY ERROR
Problem
Abnormal detection in a corresponding element
Solution
1. Once save parameter to Flash memory card and install it to the printer again.
2. C362DRV board. replacement
Feb 18, 2009 | Epson Stylus Pro 10000 InkJet Printer
Error c0998
That what service manual says:
Service Req xyyyy
A Controller error or print engine error detected. Turn off the printer. Wait at least 5 seconds and then turn it back on. If the error message still appears, write down the error number listed on the LCD panel (xyyyy) and turn off the printer, unplug the power cord, and contact a qualified service representative
Apr 29, 2008 | Epson Aculaser C1100 Printer
HP LaserJet 9050 Printer Logo
1,851 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
