Question about Frigidaire FFU17F5HW
I have a Frigidaire FFU17F5HWD upright. I noticed
I have a Frigidaire FFU17F5HWD upright. I noticed that light inside was not working but outside display still showed level 4 cooling. I unplugged unit but nothing came back on. It is on a GFCI switch which has power going to it. Not for sure what to do next. The unit is 3 yrs old.
Light on outside doesn't work but freezer is working how to replace the light.
Posted on Oct 10, 2014
    Master:
  • 492 Answers
Reset the circuit breaker. It too maybe a GFI circuit.
Posted on Oct 18, 2013
Ok, upright freezer, frigidaire, read -12 after power outage but working ok..when I tried to reset temp to 0, light went off, freezer went off, front display reads 56..any ideas?
Thank you for your post, Cynthia!
Based off the information you have provided your Frigidaire freezer is not cooling properly and is now displaying the temperature of 56. It sounds like your freezer is not on, even though it has power the compressor is not turned on. I would suggest pressing either the down or up arrow three times within five seconds. That should power on your compressor and it should start cooling properly. I hope this is helpful and if you should need further assistance please feel free to reconnect. -Matt
Feb 28, 2015 | Frigidaire Freezers
Lffh21f7hwa
Hello Michael - Sounds like the temperature control was accidently turned OFF. When this occurs the temperature control turns off the compressor, but does not disconnect the power to the light bulb or other electronics. Let's try activating the freezer by pressing the UP arrow until display shows "4" or desired setting. Allow 24 hours for temperature to stabilize. For future reference you can lock the control to keep from accidently changing the temperature setting. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if the unit's status has changed successfully. Thank you.
Jul 01, 2013 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Control panel on the front of the door on my Kenmore upright freezer show an Sb. Can't get it to do anything else!!
This code represents a malfunction. Call frigidaire and find out what that code means. Your manual should tell you as we'll.
Feb 04, 2013 | Frigidaire 14 cu. ft. / 396 liter Upright...
Upright self def. freezer not getting cold
Is your compressor running? Try this: place your hand on top the compressor, quickly-in case it's hot-it should be vibrating and cool/warm to the touch. If it's not running then the cheapest/fastest test is to try a 3in1 start kit from a local appliance shop. The 3 in 1 start should be around $14 to $20 to wire up. It's extremely simple to wire up, just ask the clerk at the appliance shop's parts counter and they will explain it. I hope this helps you out!!! :)
Nov 19, 2012 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
My new frigidaire freezer the digital display on outside of door flashes off what to do?
Hello - Typically "OF" indicates that the freezer is turn off. To activate freezer, press UP three times until display shows "1" then press UP to desired setting. If it will not allow you to change setting and freezer continues to be off, try resetting the freezer by unplugging it or flipping the breaker off. Wait approximately ten minutes and turn it on. If "OF" continues to display, the unit could possibly have a communication problem with the electronic control assembly. Contact a professional to move forward accurately.
Nov 04, 2012 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Freezer cools some to a refirdgerator level, however will not freeze
A few suggestions are 1. Turn down the fridge portion a little and colder air should redirect into the freezer part 2. If it is an older unit sometimes defrost it , unplug it and turn it upside down for a day or so (this moves some of the corrosion inside the pipes). Turn it back up and plug it back in .
Aug 30, 2011 | Frigidaire 20.6 cu. ft. / 583 liter...
Freezer says "of" on display
I assume that stands for off... there are 2 parts that affect compressor operation...
t'stat
timer
t'sat could keep the compressor from running if it is bad. to check unplug freezer. . get to t'sat and take the 2 wires off it. then jump them together.. plug back in if the compressor kicks on he replace t'sat if it dont replace timer (timer maybe stuck in defrost)
jope this was helpful
Mar 06, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
My Frigidaire upright freezer is only 4 years old & isn't working
freezers have safety devices to protect themselves. The compressor has an internal overload to keep it from overheating. some have external reset buttons and some do not. either way the cause must be corrected. if the freezer was low on refrigerant you would see signs of oil near the coils, tubing, or compressor. If there is no leak, it overheats when there is airflow restrictions(dirty coils) or a fan has stopped working. only a few screws keep you from seeing all there is to see. If it is clean and the fan is running, then the compressor may just be the culprit
Nov 24, 2009 | Frigidaire 20.6 cu. ft. / 583 liter...
Walls of freezer are hot to touch
freezer is working overtime . these symptoms generally indicate excessive outside air coming into freezer. make sure doorgasket is completely sealed all the way around door.
Sep 08, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
Does the light on the outside of freezer stay on . I bought a used freezer. It is a frigidaire commercial upright (frost free) Does the light on outside of freezer stay on all the time? I have no manual....
Normally there is a Green light showing that power is on
A Yellow one for fast freeze and a Red one for under temperature
The outer casing is well insulated from the inside otherwise the freezer motor would run none stop without cooling the contents so the temperature of the outside casing will reflect the room temperature not the intenal
Aug 21, 2009 | Frigidaire 20 cu. ft. / 566 liter Upright...
Frigidaire FFU17F5HW Logo
327 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
