Question about Tablets & eReaders
How to reset my ten inch tablet model C22-keycode41884294-power input DC5V 2.5A Made in china
Irulu tablet won't reset right
They are an entry level tablet made in china and quite frankly are junk. If you get a year out of one you are lucky. Children need two or three a year.
To reset , hold the volume up and power button.
Dec 15, 2016 | Tablets & eReaders
I purchased a dopo 10 in. tablet for my son and it is completely locked, i need help please, it just says to many pattern attempts, then goes to enter email info, yet kicks me back to the lock screen.
Hi J ....it sounds like you will need to do hard reset.this may be due to the latest app you installed or a failed update from google.
first... Switch off the tablet.....second hold the power button and volume up together for at least ten seconds....third let the tablet do what it does till you see the android robot with red triangle....wait....then input from the menu offered ....usually you will need to reset the tablet to factory install.this is a pain but in future disable auto updates if you can.. Tell it to let you manually install.once you have the tablet back sign into you google play account.that should remember your purchases and help you reinstall .unfortunately you will lose all the private info and pictures.for what it's worth if you do decide to make another pattern draw it on some paper and photograph on another device.please vote if this helps you.have a nice weekend.
Feb 07, 2015 | Double Power DOPO M-975 9" 4 GB Wi-Fi Grey...
Mid tablet forgot password
Power on the phone and hold the VOLUME DOWN and UP button, and then hold the POWER button.
Wait for the screen with the three Android images to appear, and then release the VOLUME DOWN button.
Press VOLUME DOWN to select FACTORY RESET, and then press the POWER button.
Aug 01, 2014 | CHINA DIRECT 7 Inch Android Tablet with...
My proscan tablet keeps crashing. It says google play has stoping working. I've reset the tablet twice. what can I do?
Keeps crashing because can't handle too many tasks at one time. I have the same problem. I have the same problem. Try the pin hole reset next to the HDMI input . Press in gently with a paper clip and hold for thirty seconds.
Google play? Try uninstalling updates. Disconnect from internet when not in use.
These tablets have lots of problems not easily solved because there are no firmware updates for this model.
May 25, 2014 | Proscan 10.1-Inch Internet Tablet,...
When starting up, my tablet won't get past the screen that says ANDROID.
Holding down the power button for ten seconds resets the device. After resetting two or three times, be patient because it will definitely load on the third time.
Oct 22, 2013 | Kocaso MID-M750B MID-M750B 7-Inch Tablet...
Audiosonic c22 10 inch tablet manual Where can I
where can one get a user manual for a audiosonic 10" c22 tablet
Oct 10, 2013 | Archos 7 Home Tablet Tablet Android 8 GB 7...
Tablets & eReaders Logo
11 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
