Question about Echo Chain Saw. 16 in. Gas Chain Saw CS-360T-16SP
How replace fuel lines on echo cs-360t chainsaw
  • 63 Answers
SOURCE: Echo cs-341 stalls out when cutting sideways
Make sure the fuel filter is indeed attached to the fuel line in the tank and pushed down to the bottom of the tank.
Posted on Mar 16, 2009
dontbother10
  • 2220 Answers
SOURCE: Chainsaw starts fine, but dies mid cut?
Immediately after saw quits, while everything is still hot. Sometimes ignition modules quit working when hot.
Ignition Coil Test
SmallEng.com
http://www.youtube.com/watch?v=L7WNBDRG4C4
You may need to use a jumper wire between the threaded part of the plug and the cooling fins. You don’t have to bend up the electrode.
Loosen fuel cap when it starts to die, If that fixes it it has a fuel vent problem.
If you did nothing to the carburetor adjustments, are using a fresh (3 months or less) fuel mix with the same oil/fuel ratio, and are operating at the same elevation there is a reason your saw is acting up.
It sounds as though there may be a fuel delivery problem. Check the fuel filter on the free end of a hose in fuel tank (manufacturer recommends an annual replacement). Check all fuel delivery lines especially at fittings and bends for cracks and holes. If those are good then the likely cause is internal parts of the carburetor. HTH
Lou
Posted on Oct 12, 2009
dontbother10
  • 2220 Answers
SOURCE: i have an echo chainsaw cs 346 it starts fine revs
Try rotating the "H" adjustment CCW a small amount.
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
There are 2 wav (sound - idle & full – may not be highlighted) files that I find most helpful, I think you will too. HTH
Lou
Posted on Jan 11, 2010
dontbother10
  • 2220 Answers
SOURCE: Need replacement crankcase for Echo CS-750EVL chainsaw
There are 2 complete CS-750EVL saws on my local Craigslist.
Try here for Echo IPL:
http://www.echo-usa.com/pdf/documentation/CS750EVL_010185.pdf
If not your saw:
EchoUSA
http://www.echo-usa.com/documentation.asp
Type your model number into the search window.
Good Luck
Lou
http://seattle.craigslist.org/see/tls/1571477399.html
http://seattle.craigslist.org/tac/tls/1571683044.html
Posted on Jan 27, 2010
  • 4088 Answers
SOURCE: ECHO CS 3000 chainsaw-while idling, shuts off if held on an angle
The idle speed screw may be set too low--adjust so that the chain stops moving, but the engine keeps running. Drain the fuel tank and see if the filter falls to the lowest point of the tank whatever the position. If it doesn't, replace the fuel line hooked to the filter as it may have lost flexibility. Hope this helps!
Posted on Apr 29, 2010
Need a manual for above
echo air filters do not have a manual nor fuel specs.
Mar 28, 2016 | Echo Air Filter for CS-440, CS-450,...
Echo Cs-400 chainsaw. Standing the carb up with the sliver vent on top which fuel line goes to the 90° inlet on the bottom and which line from the primer bulb to the carb?
The lengths of the line and,or the bends in the line . I would say the line from the bulb would go the carb since it is used to prime or,choke the carb.
Apr 05, 2015 | Echo Garden
Cs-302 fuel line replacement
How do I remove the Flywheel on a 1982 Echo chainsaw 302? I can't get to the fuel line since a piece got stuck under the flywheel.
Feb 01, 2014 | Echo Cs-302 Flywheel Assembly Cs 302
How do you find and change the fuel filter on an echo cs-350wes
The filter should be hanging from a length of fuel line within the fuel tank. Drain the fuel to see it. Fish the filter out with a hooked piece of wire. If it is lying loose in the tank, then the fuel line is in trouble and should be replaced. In that case, check the condition of all of the fuel lines. Hope this helps!
Oct 20, 2010 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Apr 11, 2010 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Mar 14, 2009 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Echo Chain Saw. 16 in. Gas Chain Saw CS-360T-16SP Logo
197 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
