Question about C. Crane Versa WiFi USB Adapter II
Need the Windows 8 device driver for my Wifi antenna.
  • 1,183 Answers
Kindly go to the following link , download instuction to manually install the driver for the wireless card /antenna for your computer.
Download Link
Thanks for posting your query on Fixya
Regards
Mandeep Singh
Posted on Oct 22, 2013
  • Guy Halmick
    Guy Halmick Jun 12, 2014
    The directions on how to do this no longer are at ccrane.com. Is it somewhere else. I have the original install disk which gives an error message.
Ideaworks wifi antenna driver download
With the computer on and in Windows, plug in the antenna. Then, go to Device Manager and find the antenna. Right click on it, and choose Update Driver. Let it look online, it may find a driver for it. Good luck.
Jan 11, 2018 | Computers & Internet
Windows 8 Updates disabled WIFI connections
look in the device manager an see if there is a driver loaded for the network devices
if not then see if you can find a driver on the makers website
see that the wifi is not disabled or turned off
May 09, 2015 | Computers & Internet
Need software to download for an Ideaworks long distance WiFi Antennae. Need the drivers
You shouldn't need drivers. All you need to do is plug it in, go to your laptop, go to the bottom right of your machine and click on the wifi section
Full instructions should have been provided in the box.
I even found a video.
I cant link it but type this into google: ideaworks wifi antenna manual
Apr 05, 2015 | Computers & Internet
Windows 8 keeps losing WiFi config
You can test it with an external wifi adapter. I use Edimax nano USB WiFi adapter (it cost around $15) and it has its own drivers and applications. Please don't forget to disable your internal wifi adapter after installing the external wifi adapter.
Feb 27, 2014 | Microsoft Computers & Internet
Fix wifi association problem
(a) Ensure the Wireless Device Switch is On. Just throwing that out there. Your WiFi adapter is noting down some kind of signal strength as well, yes?
(b) Try uninstalling the WiFi Adapter (Intel Centrino Advanced-N 6205 (802.11abgn 2x2), or, Atheros XSPAN HB116 802.11abgn) in Device Manager, then rebooting and let Windows reinstall the device.
(c) Try updating the drivers from here.
http://support.fujitsupc.com/CS/Portal/support.do?srch=DOWNLOADS There are Windows 8.1 x86 and x64 driver packages there.
(d) If the device is working fine (according to Windows) but is still not receiving or sending, then it may be some antenna problem, and you'll have to contact Fujitsu Support for repair. Make sure you've registered your new tablet with Fujitsu.
Post back with how this goes.
Jan 04, 2014 | Fujitsu STYLISTIC Q702 11.6"" Tablet PC -...
Aspire one d2500dr
I assume you're running Windows 7 or 8. In general, you can't uninstall wifi--but you can certainly turn off your antenna (usually a switch on the side or front of the laptop) or you can tell windows to forget about a particular network.
From the sounds of it, you probably did one of the two and now you cannot connect to the Internet.
If you want explicit instructions, I need to know which version of Windows you're running (XP, Vista, Windows 7, or Windows 8).
Oct 18, 2013 | Apevia Computers & Internet
Wifi problems v3-771
Inside most laptops, there is a WiFi Antenna. I once also had an issue with my laptop allowing me access, and then flicking off again. So every time I tried to use a program called "Steam" I would be disconnected from the servers. Inside the laptop, there is a wire that is attached to the WiFi receiver, that gets plugged into your laptops motherboard, If it is loose, just disconnect it completely, then plug it back in. If the antenna is warm, or hot. That means it is burnt out, and will continue not to work unless it is properly cooled. You CANNOT cool a WiFi antenna, so it is best to either search the web, and buy a new WiFi antenna that is the same model and brand as the one in your laptop, or just buy a LAN/Ethernet cable and play like that.
*NOTE - When you first buy a Ethernet cable, the laptop WiFi antenna must be removed, otherwise the laptop will switch between the two, and will make you periodically loose internet connection. Also, the computer will still (not as much) continue to disconnect, and reconnect for a while. Roughly 8-10 days, and then everything should smooth-en out. Here is a link to an image of a WiFi antenna for laptop:
http://www.overclock.net/content/type/61/id/1343839/width/500/height/1000/flags/LL
Or, yours may look something like this:
http://image.dhgate.com/desc_308672220_00.jpg
Hopefully this helps you!
Jan 11, 2013 | Acer America Acer Aspire V3-771-6865 Intel...
Dell Latitude E6510 wifi button will not turn on
Hi
The problem might be arising out of an issue with the Wireless services or the network drivers on your machine.
Please follow the below steps:
Windows 7:
1) Click Start> Type in 'Services' and click on the services option.
2) Within the Services window, scroll down to the bottom and look for 'WLAN Auto configuration'. Right click on the option and click on Restart if its already started or click on Start if its not.
Check if wifi is enabled and if you are able to connect now.
If the above steps do not work, please try the below steps:
1) Click Start> Type in 'Device manager' and click on it.
2) Expand Network adapters within device manager.
3) Look for an adapter which has the word 'wireless' in it.
4) Right click on the adapter and click on uninstall. If you get a window to confirm, click yes( make sure you do not choose the option: " Delete the driver software for this device".)
5) Now, click on Action on Device Manager and select ' Scan for Hardware changes'.
Windows 8: If you have windows 8, Click 'Windows' key and 'W' on your keyboard and search for the same options as mentioned above.
Hope your wifi issue gets resolved!
Regards
Mahesh
Jun 17, 2012 | Dell Latitude E6510 Laptop
Drivers for windows vista 64 bit
i want wireless senao engenius driver vista to HP laptop
Dec 10, 2008 | SENAO High Power 200mW USB WiFi 802.11bg...
Acer 5570 Wifi drivers on Windows XP and Ubuntu 8.xx
Windows XP is outdated none of driver is supporting now.
Sep 15, 2008 | Acer Aspire 5500 5570-2609 Laptop
C. Crane Versa WiFi USB Adapter II Logo
751 people viewed this question
Top C. Crane Computers & Internet Experts
David Payne
David Payne
Are you a C. Crane Computer and Internet Expert? Answer questions, earn points and help others
