Question about C. Crane Versa WiFi USB Adapter II
Need a Windows 8 driver for this WiFi antenna.
Windows 10 driver for idea works model RET7183 USB wifi tower antenna
quite likely the company has not developed drivers for windows 10 and possibly never will . when I tried win 10 and things did not function I reverted to win 8.1 to save the problems of having to buy new stuff .
Jul 16, 2016 | Computers & Internet
Need software to download for an Ideaworks long distance WiFi Antennae. Need the drivers
You shouldn't need drivers. All you need to do is plug it in, go to your laptop, go to the bottom right of your machine and click on the wifi section
Full instructions should have been provided in the box.
I even found a video.
I cant link it but type this into google: ideaworks wifi antenna manual
Apr 05, 2015 | Computers & Internet
How can I get a wire less connection on my dell, latitude c800 it only show dial up options?
It's possible that there is no wifi antenna.
Go to Dell.com and then select the support page, let it scan your laptop to see if there are any drivers that need updating. If there is a wifi update - download & install it. If the scanner tells you that there was no wifi antenna then get a USB wifi antenna & the software to run it.
Sep 06, 2014 | Dell Computers & Internet
Aspire one d2500dr
I assume you're running Windows 7 or 8. In general, you can't uninstall wifi--but you can certainly turn off your antenna (usually a switch on the side or front of the laptop) or you can tell windows to forget about a particular network.
From the sounds of it, you probably did one of the two and now you cannot connect to the Internet.
If you want explicit instructions, I need to know which version of Windows you're running (XP, Vista, Windows 7, or Windows 8).
Oct 18, 2013 | Apevia Computers & Internet
Need the Windows 8 device driver for my Wifi antenna.
Kindly go to the following link , download instuction to manually install the driver for the wireless card /antenna for your computer.
Download Link
Thanks for posting your query on Fixya
Regards
Mandeep Singh
Oct 11, 2013 | C. Crane Versa WiFi USB Adapter II
Wifi problems v3-771
Inside most laptops, there is a WiFi Antenna. I once also had an issue with my laptop allowing me access, and then flicking off again. So every time I tried to use a program called "Steam" I would be disconnected from the servers. Inside the laptop, there is a wire that is attached to the WiFi receiver, that gets plugged into your laptops motherboard, If it is loose, just disconnect it completely, then plug it back in. If the antenna is warm, or hot. That means it is burnt out, and will continue not to work unless it is properly cooled. You CANNOT cool a WiFi antenna, so it is best to either search the web, and buy a new WiFi antenna that is the same model and brand as the one in your laptop, or just buy a LAN/Ethernet cable and play like that.
*NOTE - When you first buy a Ethernet cable, the laptop WiFi antenna must be removed, otherwise the laptop will switch between the two, and will make you periodically loose internet connection. Also, the computer will still (not as much) continue to disconnect, and reconnect for a while. Roughly 8-10 days, and then everything should smooth-en out. Here is a link to an image of a WiFi antenna for laptop:
http://www.overclock.net/content/type/61/id/1343839/width/500/height/1000/flags/LL
Or, yours may look something like this:
http://image.dhgate.com/desc_308672220_00.jpg
Hopefully this helps you!
Jan 11, 2013 | Acer America Acer Aspire V3-771-6865 Intel...
Drivers for windows vista 64 bit
i want wireless senao engenius driver vista to HP laptop
Dec 10, 2008 | SENAO High Power 200mW USB WiFi 802.11bg...
Acer 5570 Wifi drivers on Windows XP and Ubuntu 8.xx
Windows XP is outdated none of driver is supporting now.
Sep 15, 2008 | Acer Aspire 5500 5570-2609 Laptop
Wifi Dongle
function PopupWindow(URL, WIDTH, HEIGHT){ var winleft=(screen.width-WIDTH)/2; var winright=(screen.height-HEIGHT)/2; day=new Date(); id=day.getTime(); eval("page"+id+" = window.open(URL,'"+id+"','toolbar=0,scrollbars=1,location=0,statusbar=1,menubar=0,resizable=1,width="+WIDTH+",height="+HEIGHT+",left="+winleft+",top="+winright+"');"); }
USB WiFi Dongle
Product reference: 11590 Here is some Technical data on your wireless adaptor. There is also a link at the bottom where you can download the driver for the operating system you are running.
" src="http://www.mobilefun.co.uk/graphics/rightarrow.gif" width="10" /> Description The USB WiFi Dongle easily connects your USB-equipped desktop or notebook computer to your wireless network for internet and file sharing. Desktop users can now join the network with the ease of a USB plug-in, without opening their PC cases, laptop users can enjoy the benefits of staying mobile-while connected to the internet.
By adhering to the 802.11g wireless standard, the USB WiFi Dongle is capable of streaming video and transferring large files across a wireless network. You will most likely need this if you have a bought a wireless ADSL or cable modem and wish to connect your PC to the internet or other PCs on the network wirelessly. The USB WiFi dongle is also compatible with all mobile phones and PDAs with WiFi connectivity.
Features:
  • Versatile use with Desktop PC or Laptop Computer
  • Portable, compact, pocket sized design
  • Compatible with IEEE 802.11b (11Mbps data rate).
  • Compatible with IEEE 802.11g (54Mps data rate).
  • Dynamic data rate scaling at 6,9,12,18,24,36,48 and 54Mbps for 802.11g.
  • Support wireless data encryption with 64/128 WEP for security.
  • Support infrastructure networks: Access point and ad-hoc network.
  • Supports WPA enhanced security.
  • Supports DFS/TPC for European operation.
  • Friendly user configuration and diagnostic utilities.
  • High speed USB 2.0 interface.
Technical data:
  • Chipset: SiS 163U.
  • Standards: IEEE 802.11b, IEEE 802.11g.
  • Frequency Band: 2.4GHz ~ 2.483GHz.
  • Data Rate: IEEE 802.11b, 1, 2, 5.5 & 11Mbps.
    IEEE 802.11g, 6, 9, 12, 18, 24, 36, 48 & 54Mbps.
  • Transmitter Power: 17 dBm.
  • Receive Sensitivity Operating at 11Mbps: -80 dBm @ 8% FER.
  • Operating Range: 100 - 400m, depending on environment.
  • Antenna: On board chip antenna.
  • Security: 64-bit or 128-bit WEP/WPA/TKIP.
  • I/O Interface: USB 2.0.
  • Size: 58 (L) x 23(W) x 9(H) mm.
  • Weight: 9g.
System Requirements:
  • Windows 98SE/ME/2000 and Windows XP.
  • Pentium 233 MHz or higher.
  • 32 Mb of RAM under 98, 98 SE, Millennium & NT 4.0 with Service Pack 5.
  • 64 Mb of RAM under Windows 2000 and Windows XP.
  • 100 Mb of disk space.
rightarrow.gifDriver Download To download the latest drivers for Windows 98 or higher click here.
Apr 14, 2008 | Computers & Internet
C. Crane Versa WiFi USB Adapter II Logo
90 people viewed this question
Top C. Crane Computers & Internet Experts
David Payne
David Payne
Are you a C. Crane Computer and Internet Expert? Answer questions, earn points and help others
