Question about Behringer EUROPOWER EP2500 Amplifier
Need to know how to setup the input line for the ep2500
  • Stefan Mayrhofer
    Stefan Mayrhofer Nov 28, 2013
    Hi lenny hedrington, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
    - what input source?
    - can you post a picture of the back where I can read the descrition for the DIP switches?
Audio input line
Behringer Power Amps has the input lines on the back, it has either XLR balanced and 1/4 unbalanced inputs, now what are you trying to ask?
Oct 11, 2013 | Behringer EUROPOWER EP2500 Amplifier
Behringer amp 240 to 120 volts
What you may need is a
Voltage converter ' Voltage Transformer ' step up and step down ...
Connect the 220V line output to EP2500
And the 110V input to your 110V convenient outlet
Aug 20, 2012 | Behringer EUROPOWER EP2500 Amplifier
Clipping the channels
The manual discusses the Clip Inidicator and how to deal with clipping.
Clipping in this amp isprimarily a function of the input signal being distorted so the input level is recommended to be lowered. Beyond that the cause of input distortion would have to be addressed in the device producing it.
http://www.retrevo.com/support/Behringer-EP2500-Amps-manual/id/23281ci655/t/2/
Dec 30, 2010 | Behringer EUROPOWER EP2500 Amplifier
My behringer europower EP2500 poweramp has a bad hiss on channel 2 What could this be?
There is a possible noise build up on your CH2 due to failure or weakness of the LCR network of the preamp circuit. It could also be a noise within any semiconducctor or the preamp IC. Unless you can do a signal test with the elimination of the input to the output amplifier, the fault will not be say to isolate. Hence if youarre familiar do the test by approching from the output amplifier's input, proceeding to the main input where the faulty section can be identified. Hope this helps. Good day
Jul 18, 2010 | Behringer EUROPOWER EP2500 Amplifier
I need to know how to wire an xlr y adapter
I always solder it this way.
Take a female XLR connector, two thin sym. cables and two male XLR connectors.
Solder both cable parallel in the female connector and the ends on the male connectors.
This way you get the same signals on both inputs of your amplifier.
Regards,
Gerard
Oct 26, 2009 | Behringer EUROPOWER EP2500 Amplifier
Behringer EP2500 amplifier channel crackling noise
Got asilimar problemwit a behringer europower pmh 3000.
my
The Right channel began to crack up and drizzle now it seems completely dead.
Changed the cables both of input and seapkers , still the problem stays the same. Any suggestion before brigning for a month at the repair shop? And get out with a 200-400$ bill ?
Apr 28, 2009 | Behringer EUROPOWER EP2500 Amplifier
I have a xenyx 2442fx mixer and ep2500 power amp hooked up to 2 1800x subwoofers and 2 1520 pro speakers. i am using a peavey xr 684f powered mixer to power my monitors. i would like to add another power...
You would need a 2 or 3 way crossover, depending on whether or not you biamp your tops. Simply go out of your main outs on the mixer into the input of the crossover. Go from the low output of your crossover to your low power amp input (subs), and the high output of the crossover to the high power amp input (tops). Then go from your outputs of your amps into the speakers themselves.
Jan 04, 2009 | Behringer B1520 Pro Eurolive 15" 2-Way...
How can i do this
Hi
the crossover has 6 output and 2 inputs in stereo type! you need amplifier to this...
Thanks!
May 16, 2008 | Behringer EUROPOWER EP2500 Amplifier
Behringer amp
Hello pare ko.
EP2500 is a pro amp, manufacturer says that. Notorious to me.
Got 5 of these for repair. Clip is of course cause by too much
signal from source. If the amp is still clipped or on protect even w/out
signal in, time to open and do repairs inside. usually a MOSFET
inside P50N06 (50V-60A) is kaput. or MJE15033G and MJE15032G.
Now if blowing main Fuse, main txistor 2SA1943/2SC5200 maybe gone.
Read carefully the setting of your dip switches setting at the back.
This amp can drive 750 watts/ch@4 ohms.
Good Luck From Siliconchip
Nov 11, 2007 | Behringer EUROPOWER EP2500 Amplifier
Need schmatic for ep2500
check preamps small parts! maybe you have change value capacitors and resistors!
Sep 13, 2007 | Behringer EUROPOWER EP2500 Amplifier
Behringer EUROPOWER EP2500 Amplifier Logo
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Alvan Dawkins
Alvan Dawkins
Level 1 Expert
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
