Question about PetSafe Wireless Fence System PIF-300
Petsafe PIF-300 does not transmit to collar - PetSafe Wireless Fence System PIF-300
Write about the PetSafe stay+play wireless dog fence?
According to me, one of the best wireless dog fence is a PetSafe stay+play wireless fence. If you prefer outdoor camping, travelling then this portable dog fence system is perfect for you. You can take this dog fence anywhere without doing set up for the whole day.
Nov 03, 2017 | Saws
My petsafe 1000 big dog shock collar remote is stuck on 15. I can't fix it tried everything. Please help!!
Reset your remote by removing the battery if your problem is still exist then you open your remote and tuch the up/down button base with metal (conductor) I sure it will work.
Jun 16, 2015 | Radio Communications
How to set the collar of a Petafe in ground fence.
1st you have to hold down the little black button on the collar, when it flashes at you release the button.
-Then press the button again and count the # of flashes.
-Keep pressing the button until you get it set to the desired flashes related to the setting you want to use.
-1 flash- audible correction with no shock.
-2 flashes audible correction with low shock.
-3 flashes audible correction with high shock.
It is always recommended to start with the low shock , if using shock setting, then move to higher setting if needed. Most larger dogs require a high shock setting, I have a yellow lab and use the high setting for him. Hope this helps.
Feb 23, 2015 | PetSafe Pet Safe In-Ground Stubborn Dog...
Cat flap
No... unless the door is removed entirely or you customize.
Apr 25, 2013 | Radio Fence PetSafe Freedom Pet Doors
What is the best fence I can use for my dog?
First, try to get a fence made from a durable material like aluminum or a wire fence. Of course you will compromise the looks...
don't get a wooden fence unless it is more expensive since big dogs tend to ruin them
Jan 31, 2013 | Home Fencing
My dog's SmartPets 4in1 Dog Training Shock and Vibration Collar has stopped working
It seems like your batteries have run out - you can buy new batteries from here http://www.amazon.com/PetSafe-6-Volt-Lithium-Battery-Batteries/dp/B0009811TW/ref=pd_sim_petsupplies_8 The battery is very easy to change, the handset also runs on batteries but they are AA and can be purchased from your local store.
May 13, 2012 | Pets - Others
Can I delete the PIF frames and sound files stored in the camera's internal memory?
Yes. There are two ways to delete the PIF frames and sound files from the camera: * Connect the camera to a computer and drag the EPUDL folder and EPSOUND folder to the recycle bin or trash can on your computer. * Format the camera’s internal memory. Note: If you plan to restore the sound files to the camera’s internal memory, save a backup copy of the EPSOUND folder before you delete the folder.
Sep 13, 2005 | Epson PhotoPC L410 Digital Camera
PetSafe Wireless Fence System PIF-300 Logo
81 people viewed this question
Top PetSafe Pets - Others Experts
Ross Keen
Tom Chichester
Ruth summersides
Are you a PetSafe Pets - Other Expert? Answer questions, earn points and help others
