Question about Sony FD Trinitron WEGA KV-36FS210 36" TV
Sony KV-36FS210 intermitted horizontal comes and goes nothing is coming up on self test. notice when tap lightly if facing tv on right side it stops. took back off just don't know what I'm looking for. Was told ic chip on a board?
    Top Expert:
  • Sony Master
  • 74,459 Answers
Sounds like a loose contact. Check all the solder terminals at the horizontal output as well as IC terminals, for any loose or dry solderings. Re-solder all the suspected solder terminals, by applying a little more solder, without making any solder-bridge short in between adjecent solder terminals.
Posted on Oct 11, 2013
  • david cruz
    david cruz Oct 11, 2013
    Thanks Sasi I'm not expert or have exprience with circut boards order service manual going to try fixing this myself. I gather your talking about A board? around flyback area?
    Problem Solver:
  • 19 Answers
Hello!. When the set goes off does the front red led blinks ? thats an error code. If it goes only to a horizontal thin line then back to full frame its the vertical deflexion IC that causes the problem and it happens a lot on these sets because of internal temperature and bad soldering issue.
Posted on Oct 12, 2013
Testimonial: "Carlos my set doesn't turn off on it's own. went to self test mode no codes come up. set does blink red while turning on. I have back cover off I did notice on a board neara long ic chip a cap I believe it's called has leaked. I waiting for service manual to come first before making repairs. I did order two ic chips for D board also going to change while back is off. too bad there's no way of posting a picture on my intermitted problem dave cruz"
4 Suggested Answers
  • 41 Answers
SOURCE: Sony KV-32S66 Picture Rolling Up/Black Horizontal Lines
the problem there is a loose connection on the board,you said that you smacked the right side of the tv and it goes normal.there are parts that should be resolder on the board in order to back into normal operation.
Posted on Oct 22, 2008
  • 8457 Answers
SOURCE: KV-HX32 SONY WEGA TV
The hight voltage transformer it dead.The FBT(The flyback transformer is dead)The block of plastic with the red wire with a cap hook to the CRT(the tv tube).
Posted on Aug 25, 2009
Testimonial: "Thank you so much"
freetek
  • 5568 Answers
SOURCE: Canno turn the tv on.
You probably have a main or high voltage power supply problem; the latter produces the 20,000 plus volts for the CRT and gets its voltage from the main supply. It's difficult to say which is at fault without a few measurements.
Posted on Feb 14, 2010
Horizontal
If you wish to get more details about how to pull out the chasis out to service position, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
It has illustrations about disassembly.
Oct 11, 2013 | Sony FD Trinitron WEGA KV-36FS210 36" TV
Screen not coming on
This Chassis line had a lot of issues with hair-line cracks in the Horizontal Circuit along the right side near the High Voltage Transformer and Heat Sink. It has also had issues with cold solder connections in the Horizontal Drive Circuit especially the Horizontal Driver Transformer. These issues have many times caused a massive Power Supply and Horizontal failures if not repaired.
I hope this helps,
Skyassoc
Jul 24, 2009 | Sony KV-32S22 32" TV
Half screen
Hello xmen0614,
If the screen is halved in a horizontal fashion meaning that the screen only goes up half way this is an indication of a vertical deflection problem, quite possibly the vertical coupling capacitor or a problem with the vertical drive signal. If the TV is halved vertically meaning the either the left or right side of the TV is black while the other has picture, this could mean a problem with the damper diode, the Horizontal output Transistor, or the horizontal drive signal.
In either case I would suggest doing a ring test on the Yoke Transformer, The IHVT (Integrated High Voltage Transformer).
Also check the Vertical coupling capacitor, and the horizontal drive transformer (Ring test this).
You noticed that I included the Vertical and Horizontal sections? This is because you did not mention which direction your screen was halved in.
If it is halved to to bottom check the vertical circuitry, If it is halved left to right check the horizontal circuitry. For either one do a ring test on the Yoke Transformer.
I hope this helps,
Thank you,
Shuttle83,
http://www.electron-age-technologies-llc.com
Mar 23, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Top of screen slants on the right and left side horizontally
go in touch with SONY i assume ur set is still under warrenty.....call customer help and support
Mar 12, 2009 | Sony FD Trinitron WEGA KV-36HS420 36" TV
DTV converter boxes
You need to look on the tv and see if has a digital turner symbol. If you can only pick up analog channels, you need a converter box.
Jan 22, 2009 | Sony FD Trinitron WEGA KV-36FS210 36" TV
T.V. screen is green with bright horizontal lights top to bottom
There are 2 possibilities of green screen in this model.
1- Driver circuit of green gun is defective. 2- Screen itself is defective.
Now I want to know, do you have TV repair experience and basic electronics knowledge to test and check above 2 sections in TV?
Jan 10, 2009 | Sony FD Trinitron WEGA KV-32FS16 32" TV
Sony Vega Service Codes
KV-32HS510 and KV-27HS420, seven times blink error code shows problem in Horizontal deflection circuit.
There are many possibilities like dry solder joints, weak capacitors, Horizontal transistor short or flyback transformer fried etc.
If you have little experience of TV repair and good solder skills and have necessary tools to test / check defective parts, then you can make it. you also need to have related service manual to see board location, schematics and part numbers.
Dec 12, 2008 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Oct 22, 2008 | Sony KV-32S66 32" TV
Sony KV-36HS20
SEVEN Blinks---High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
Jan 28, 2008 | Sony KV-35S45 35" TV
Sony FD Trinitron WEGA KV-36FS210 36" TV Logo
81 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
