Question about Behringer EUROPOWER EP2500 Amplifier
Audio input line
Input lines for ep2500 and how they are set up
    Champion:
  • 243 Answers
Behringer Power Amps has the input lines on the back, it has either XLR balanced and 1/4 unbalanced inputs, now what are you trying to ask?
Posted on Nov 08, 2013
What does manufacturer control auxiliary input auxiliary output mean
set level of input and output for audio .. similar to line in and line out of a stereo amplifier. This means you cannot alter the level of the signal out put or input to your audio system. It is set by the manufacturer. For a 1996 Ciera I assume you are adding some type of interface so you can either input or output a signal for a device. It is probably a set level on the interface. Some interfaces have tiny knobs where you can control the gain for input or output orthers are set by the manufacturer of the interface.
Aug 03, 2015 | 1996 Oldsmobile Cutlass Ciera
Behringer amp 240 to 120 volts
What you may need is a
Voltage converter ' Voltage Transformer ' step up and step down ...
Connect the 220V line output to EP2500
And the 110V input to your 110V convenient outlet
Aug 20, 2012 | Behringer EUROPOWER EP2500 Amplifier
Line in what is that for
In general:
Line In is the standard name for any generic audio input. Line Out would be for the corresponding output.
It allows a standard for audio equipment manufacturers to use when designing for interconnection.
http://en.wikipedia.org/wiki/Line_level
"Consumer electronic devices concerned with audio (for example Sound cards) often have a connector labeled "line in" and/or "line out". Line out provides an audio signal output and line in receives a signal input. The line in/out connections on a computer sound card are generally unbalanced, with a TRS connector of 6.35 mm (1/4"), 3.5 mm (1/8" miniature) or 2.5 mm (3/32" subminiature). The connections on most other consumer equipment use RCA jacks. In most cases changing the volume setting on the source equipment does not vary the strength of the line out signal."
Jan 11, 2011 | RCA Electronics - Others
I need help setting the default video and audio combo.( no book ) I am new to this receiver and I changed the dvd player to a blu-ray which caused a need to change the audio input to the receiver. Thanks...
the blue ray player should have a audio output generally RCA audio.
just get this cable RCA Audio from the blu ray to a input on your receiver eg. dvd,cd,line 1,line 2 whateva your receiver inputs are lol
Jun 29, 2010 | Audio Players & Recorders
I need to knowwhat phono leads I need to connect pc to tv -sound to come out of tv-Ive a medion pc? WHERE do I connect the leads on the pc?
Normally 3 standard sockets for audio, line in, line out and mic in, that are coloured blue green and pink respectively, for audio out connect to green socket (3.5mm jack plug)
May 11, 2010 | Medion MD-1704 PC Desktop
Distorted recording and loud
If you're using the RCA cables, how is the switch set on the TT?
From the manual....
2. RCA Audio Output Cables: These cables should be plugged into a CD or Auxiliary input on your computer. IMPORTANT:
There is a switch on the bottom panel, next to the RCA cables that selects between PHONO/LINE. Use PHONO level for
plugging into a turntable input on a home stereo. Use the LINE level for plugging into CD/AUX/TAPE inputs. WARNING: You
may damage your receiver if you plug in a LINE level into a PHONO input.
Mar 29, 2010 | ION Audio iTTUSB Turntable
Can i plug an amplifier into an active speaker
The active speaker consists of a crossover (for spliting the frequency full band) and as many amplifiers as speakers it has (e.g.if it's a 2 way loudspeaker - bass, treble - it has 2 mono amplifiers). You apply the line level signal at the crossover's input. So, as a conclusion:
1. You must apply only line level audio at the active speaker's input. This means that you can connect a line output from your mixer or your pre-amplifier, but not the output from another amplifier.
2. You can not use another amplifier for powering up your active speaker. The maximum sound level that this active speaker can provide is done by its own amplifiers. If this sound level is not enough for your case, you can either add some more speakers or use another one more powerfull.
In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Mar 23, 2010 | Behringer EUROPOWER EP2500 Amplifier
Panasonic dvx1000a has no audio input, for xlr connector, the switch line mic is in mic pos. and the external mic not work in that camera.
You have to switch the CH1 and CH2 switches inside the lcd display to input 1 or input 2 to control the xlr inputs. If these switches are in int (L) and int(R) position, then you are adjusting the audio on the CH1 ad CH2 dials below the lcd viewer on the outside of the lcd for the on camera mic. Only use line setting on the front of the camera when you are receiving an audio feed at line level from an audio board. If you set the camera to mic setting, and you are receiving a line level audio signal, you will blow out the audio 0 way too loud, if you are receiving a mic signal and your switch is set to line, you will not be able to hear the mic with the audio Ch1 and ch2 all the way up.
May 17, 2009 | Panasonic AG-DVX100A Mini DV Digital...
Audio Input Problems
buy a creative sound pcmcia card with stereo inputs...it runs aboout 50 bux at compusa...another solution would be usb audio input, they are also available at compusa,tigefr direct...i hope this helps...
Jul 29, 2007 | HP Compaq nc6220 Notebook
Behringer EUROPOWER EP2500 Amplifier Logo
79 people viewed this question
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
