Question about Sony FD Trinitron WEGA KV-36FS210 36" TV
Horizontal intermitted problem if I tap lightly on right side facing tv it stops
    Top Expert:
  • Sony Master
  • 74,251 Answers
If you wish to get more details about how to pull out the chasis out to service position, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
It has illustrations about disassembly.
Posted on Oct 11, 2013
Sony KV-36FS210 intermitted horizontal comes and goes nothing is coming up on self test. notice when tap lightly if facing tv on right side it stops. took back off just don't know what I'm looking for....
Sounds like a loose contact. Check all the solder terminals at the horizontal output as well as IC terminals, for any loose or dry solderings. Re-solder all the suspected solder terminals, by applying a little more solder, without making any solder-bridge short in between adjecent solder terminals.
Oct 11, 2013 | Sony FD Trinitron WEGA KV-36FS210 36" TV
I have a 4 year old 40" Samsung 1080p lcd tv. The problem I am experiencing is that when I turn on the tv the picture initially is separated into 4 section horizontally. The top section is ok, the other 3...
I have a 46" Sanyo LCD TV with a similar problem. The top 4th has intermittent vertical lines and then occassionally the whole left side goes dark. There are 4 distinct sections like yours. The top section usually messes up most of the time with the other 3 just happening occasioally. I found the by tapping on the left side of the frame or squeezing the left side of the frame that it will normally start working for a while. I have been doing all kinds of research and can only find people with the same problem but not solutions. Since there is so many people with this problem I am seriously considering spending the money to slowly replace parts until I can find the cause. If tapping on the frame or squeezing on the frame or lightly pushing on the screen seems to work please let me know so when I get deeper into my TV it will help me know more what to do. You can email me at jrwblueyes1@yahoo.com. I'm afraid it is going to be the screen. JR
Oct 12, 2010 | Samsung LE40B650T2 40 in. Full HD Crystal...
My turn signal works intermitantly. It works a
Seems your flasher is going out. If i am correct the switch for your hazard lights is also your flasher. One way to find out is when it stops working tap the hazard light switch and see if it starts to work again. If so there is your problem. Hope this helps
Oct 30, 2009 | 2001 Chevrolet Impala
Coloured lines on screen
Make sure first that the picture is centered by using the remote control to move the picture vertically and horizontally. Use the round pad towards the center of the remote and push the button according to which direction you want the frame to move.
Sep 10, 2009 | Philips 42 in. Plasma TV
Toshiba 36A50 sound, light line horizonally on black screen
It is my guess that you have some intermitent solder connections in the Vertical output circuit.
Hope this helps,
Skyassoc
Jun 23, 2009 | Toshiba 36A40 36" TV
Sony KV27v15 DOA
The high voltage circuit also runs the horizontal deflection circuit and much of the rest as well. The horizontal problems you describe were a prelude to high voltage failure. If the TV is anywhere near 10 years old (how come you guys never give the age????) it isn't worth the cost of overhauling the high voltage circuit. You might be able to replace just the H.O.T. but the flyback is the source of the failure.
Jan 09, 2008 | Televison & Video
T.v. not coming on ,turned off by itself with an arc noise
The part is known as a flyback transformer.. it will have to be replaced.. also the horizontal ouput transistor will possible most likely be bad..
Dec 16, 2007 | RCA D52W19 52" Rear Projection Television
Panasonic OMNIVISION VCR Combo 1999 PVQ-M2509
the tv has a intermitent problem in the power supply.or related circuit have a tech repair on your set it is repairable it could be some lose soldering due to your explanation good luck
Apr 05, 2007 | Panasonic PVQ-M2509 Combo
Video problem
You already have it diagnosed ,all you need to do is find the loose conection and it might not be just one,the set seems to be 5 years or older and it has developed other loose conections besides the one obvious one,if you are familiar with tv service you can look in the horizontal deflection area starting with the horizontal driver transistor and while you are correcting this one you will find other ones, some loose conections are hard to see even for the trained technician so if you are not too familiar with tv service be safe and get the assistance of a servicer,right now it should not be too expensive since you already know were to hit it.
Oct 10, 2006 | Toshiba 51H84 51" Rear Projection...
Sony FD Trinitron WEGA KV-36FS210 36" TV Logo
29 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
