How can I repair a tcl washing machine that does not wash when selected for?
gittos73
  • 244 Answers
SOURCE: washing machine repair
without knowing the make there are 3 parts that could be at fault 1)has the motor got carbon brushes these u will find by looking for a wire going to each sides off the motor which go into a plastic covering that surrounds the carbons if these are lower than8ml in length than they need replacing if these r ok than2)its your motor if the motor does not have carbon brushes then the washer will have a module which tells the motor how much power to use its about 4in in length 2in in heigth and will be a circuit board let me know what make it is m8
Posted on Aug 28, 2007
  • 1003 Answers
SOURCE: Hoover Hnwf 7148 washing machine
REPLACE POWER CONTROL MODULE
Posted on Feb 02, 2008
Benimur
  • 6966 Answers
SOURCE: repair of samsung (karisma ) washing machine
Water draining is indicative that the drain valve is left open allowing water to escape even during regular/wash cycle and not only on drain/wash cycle completion. this could be brought about by:
1. laundry material, debris, safety pin, clips or some other foreign material has lodged itself prohibiting the drain valve in closing properly; or
2. the mechanism (solenoid) closing the valve is jammed in the open position.
Corrective measure calls for inspection and possibly cleaning or solenoid/control mechanism repair or replacement. Often these can be found at the bottom or near bottom of the machine below the tub.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jun 21, 2008
  • 9 Answers
SOURCE: Beko washing machine will not complete wash cycle. it will not rinse anf then spin. You have to manually select spin and drain after wash is done. can the maching be reset in anyway.
your timer is most likely bad
Posted on Apr 20, 2009
steverib
  • 15 Answers
SOURCE: will not complete cycle
Your "cycle selection switch" is probably the timer motor. If tapping it lightlly gets it going again it will probably need replaced. It could be a loose connection but I would need to know the model number to tell how to get into the inside of the control panel to look. If you do get adventurous, be sure to unplug the washer before taking the panel apart.
Posted on Aug 26, 2009
LG washing machine error codes I got TCL error code on LG my washing machine What does it mean?
that means you need to clean the tub. use your search engine on the net to learn how. then the error code should go off.
Jul 26, 2017 | LG Washing Machines
Whats so tricky about the repair?
Amana Washing Machine Parts - RepairClinic.com
www.repairclinic.com/Shop-For-Parts/.../Amana-Washing-Machine-Parts
Huge selection of Amana Washing Machine parts in stock. Same day ... A small leak in front of the washer could be caused by a defective pump. OEM Part ...
www.repairclinic.com/Shop-For-Parts/a11/Washing-Machine-Parts
Find your parts fast and repair your Washing Machine with our free repair help. ...Admiral · Amana · ARDO · Asko · Bosch · Crosley · Danby · E-Wave · Electrolux · Estate ..... A small leak in front of the washer could be caused by a defective pump..... Washing machine door lock and switch assembly for front loading washers.
How To Fix Front Load HE Washer Does Not Dispense ...
removeandreplace.com/.../front-load-he-washer-does-not-dispense-deter...
May 15, 2015 - HOW TO REMOVE WASHING MACHINE SOAP DISPENSER ...
Jan 10, 2016 | Amana Front Load Washing Machine Washer...
Tcl reset twm-55as/c washing machine?
Try up pluging the washer for 30 mins or so and see if it resets. Also check the owners book to see if there is any information on resetting the washer
Apr 30, 2014 | Washing Machines
Hotpoint tcl 770 aquarius tripping electrics
REMOVE TOP OF WASHER AND CHECK WIRING ON FRONT RIGHT SIDE AS IT IS PRONE TO CHAFFING CAUSING AN INSTANT TRIP.
Jul 27, 2010 | Hotpoint Aquarius WMA56 Front Load Washer
I plug it in and it won`t turn on
A faulty door switch can cause this, You can test it with an ohmmeter. A faulty control panel can also cause this. Also a faulty fuse or power supply which can be tested with a voltmeter to make sure it is getting power.
May 03, 2010 | Kenmore Elite HE5t Washer
Washing machine fault
im having the problem now with my daewoo that every time i put a wash on its giving me a H6 message error
Nov 09, 2007 | Washing Machines
Servis washing machine
There was a service bullitin on this model concerning the lid switch and this sounds like your problem. Maytag redesigned it because of excessive failures. The new switch kit part number is 12001908. I don't know if you would have any luck contacting Maytag with regards to repairing this for free, but you could check. For reference the bullitin they put out was TCL-0001-b. If you cannot get anywhere with them, it's not a hard fix. We should be able to walk you through it. Catriver..post back
Aug 02, 2006 | Maytag Dependable Care LAT9706
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
