Question about Health & Beauty
Price of sharper image warm paraffin bath HF745
2 Suggested Answers
  • 1739 Answers
SOURCE: instruction manual for revlon paraffin bath
Have not been able to find a manual for this product online. However in my searches found the following post that may be of use to you:
http://www.livestrong.com/article/106512-paraffin-bath-instructions/
You could try contacting Revlon directly:
http://www.revlonspa.com/contact-us.cfm
Posted on Apr 04, 2011
Need instructions on how to use dr. scholl's paraffin bath
Online~ Ama Supercross 2017 Live Streaming [Rd 2 San Diego]
https://www.linkedin.com/pulse/watchfoxonline-ama-supercross-2017-live-streaming-rd-2-etete-etet
Dec 14, 2016 | Clothing Accessories
Do you have the instructions or user manual for Homedics Paraffin Baths from several years ago.
I have the manual for the ParaSpa Plus. Your image matches the model. Do you have a specific question?
Sep 27, 2013 | Homedics Paraspa Plus Paraffin Wax Bath"
Need instructions on how to use Dr. Scholl's Thermal Therapy Quick Heat Paraffin Bath -- how long to leave hands/feet in melted wax, how long to leave wax on, what to do after removing wax any...
How to fill your Dr. Scholl's Thermal Therapy Quick Heat Paraffin Bath1. Take the lid off your bath container and remove all packing materials.2. Place the unit on a flat, heat-resistant surface.3. Remove the plastic rack.4. Remove all three blocks of paraffin wax from the plastic wrapping. Each block is equal to one pound of paraffin wax, and three pounds of paraffin wax are needed to begin using your Paraffin Bath. Break each block in half, then in half again.5. Place the blocks of paraffin wax in the Paraffin Bath container.6. Plug the unit into an electrical outlet. The green light will glow. The red "Heater" light will initially come on and then cycle on and off while the wax is melting.7. Replace the lid and turn the switch to the "high" position. The paraffin wax will be ready for use when it is visibly melted (approximately 120 minutes).8. As soon as paraffin wax has melted, place the plastic rack on the bottom of the heating chamber. This will protect hands, elbows, and feet from heat.9. Turn the dial to the "Keep Warm" setting and wait 25 minutes before dipping hands, elbows, or feet.
Warning: DO NOT place hand or any other body part inside the chamber while the unit is melting the wax.
How to Dip Hands1. Remove jewelry, roll up sleeves, and thoroughly wash and dry hands. You can also rub in some of your favorite hand lotion.NOTE: The lid should be on during the time the unit is heating. Put the lid back on the unit after each use.2. Put a small amount of wax on the inside of your wrist to test the temperature.3. Spread fingers apart slightly and slowly immerse your hand in the paraffin wax container. Then immediately, but gently, remove your hand from the Paraffin Bath chamber. Let the paraffin wax solidify on your hand. Wait at least three seconds (until the paraffin wax no longer appears shiny) before redipping. Be careful to avoid touching the sides or the bottom of the Paraffin Bath chamber.4. Continue to dip your hand in and out of the paraffin wax, following Step 3, to build up layers of paraffin wax. For the best results, do this at least five times. The more layers, the longer the heat will last.5. If desired, cover your hands with glove liners and place your hands in the insulated mitts. These retain heat for better results.6. Remove the hand mitts from your hand. Remove the plastic glove and discard. Peel the hardened paraffin wax from your hands. It is recommended that the hardened paraffin wax be discarded.7. Massage in the oils left on your hand after the paraffin wax is peeled off to get the full invigorating and rejuvenating benefits of your Paraffin Bath.NOTE: Allow the paraffin to remain in place for 10-15 minutes before removing; longer if more layers exist or if the mitt has been used previously.
To Treat Feet or ElbowsFollow steps 1-4 as outlined for hands. Mitts are intended for use with hands only.
Product Care and Maintenance Place paraffin bath in a safe, cool and dry place when not in use. Wipe with a soft, damp cloth. DO NOT use abrasive cleaner. Never submerge the unit in any liquid. Keep away form all solvents and harsh detergents. DO NOT attempt to repair this paraffin bath. There are no user-serviceable parts.
STORAGEWhen not in use, "unplug it."Allow appliance to cool and store out of reach of children in a safe, dry location. To protect from dust or dirt, simply store in its original box. Never wrap the cord around the appliance since this will cause the cord to wear prematurely and break. Handle cord carefully for longer life and avoid jerking, twisting or straining, especially at plug connections.
CLEANING INSTRUCTIONSRemove plastic rack from heating chamber.1. DO NOT unplug the Paraffin Bath. Allow paraffin wax to remain undisturbed for a few minutes.2. Turn unit off and let the paraffin wax "harden."3. Right before cleaning, turn the unit on again until the paraffin wax is visibly melted around the entire edge (approximately 3-5 minutes), then turn unit off and unplug from the electrical outlet.4. Spread an ample amount of paper towels on a hard, flat, heat-resistant work surface and slowly turn the unit upside down to allow the hardened paraffin wax to drip from the chamber onto the paper towels. Allow the surface of the paraffin wax block to harden and then discard it. To clean the empty chamber, wipe with paper towels to remove any sediment.5. To clean the outside of the unit, remove any solidified paraffin wax.6. DO NOT use sharp objects to remove solidified paraffin max.7. DO NOT scratch or damage the Paraffin Bath chamber.8. DO NOT use abrasives when cleaning the Paraffin Bath chamber as it will damage the finish.9. If you discard the paraffin wax after each use, we recommend you clean out the unit completely every 40 uses. If you re-use the paraffin wax after every use, we recommend you clean out the unit completely every 20 uses.
PLEASE NOTE: This appliance should not be used in the presence of open cuts or wounds, inflammatory skin conditions, growth peripheral vascular disease where circulation is impaired, acute inflammation, or where sensation of the extremity is reduced or absent. If there is any question about peripheral vascular disease or decreased sensation of the extremities, consult a physician or physical therapist before using the Dr. Scholl's Thermal Therapy Quick Heat Paraffin Bath. Discontinue use if dermatitis due to paraffin sensitivity occurs. Discontinue use if wax feels too hot or cool, which could indicate health problems with the user.
There are also a bunch of standard warnings about dealing with electric appliances. Take care of them, don't dump them in water, etc., etc., etc.
It's worth pointing out that paraffin wax is flammable.
Jun 19, 2011 | DR Scholl's Drsp3752 Paraffin Bath
How much wax do you put in a Revlon paraffin wax spa?
3 to 6 pounds start with 3, let it melt, if you need more, add another pound until you get about 3/4 of the way full.
Jun 13, 2011 | Revlon Spa Moisturestay Paraffin Wax Bath...
We lost the factory manual. Once the wax is heated please guide us through each step and the duration? Any help would be greatly appreciated. Thank you so very much and God Bless!
Feb 10, 2011 | Revlon Spa, Moisture Stay Paraffin Bath 1...
I have a paraffin wax machine, I just need to know if after the wax melts do u put the dial on keep warm before u put your hands in.
Hello Dear
No Never keep the machine ON when you soak ur hands in paraffin wax. Keep the dial OFF position.
To keep the paraffin warm switch off the fan or AC of the room. It will not get stuff earlier.
regards
(Please Rate the solution)
Jan 19, 2011 | DR Scholl's Drsp3752 Paraffin Bath
How much wax does it hold? ie:3lbs or 4lbs
This product can safely hold 4lbs of paraffin wax pellets.
Jan 16, 2011 | Revlon Spa, Moisture Stay Paraffin Bath 1...
Instruction manual for revlon paraffin bath rvs1212p1
Dec 27, 2010 | Revlon Spa, Moisture Stay Paraffin Bath 1...
Health & Beauty Logo
37 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
