Question about Exercise & Fitness
Horizon fITNESS t850
The speed button does not work
    Top Expert:
  • 12,223 Answers
Tight the ribbon cable in display monitor and clean it. with contact cleaner. Tight the upper and lower connector and clean it very well
Adjust the Reed switch, see the diagram attached, tight the wires and clean it.
God bless youhorizon fITNESS t850 - 7e7f37c7-a76f-430b-86b2-3144c26a8c79.gif
Posted on Oct 11, 2013
Lubed belt, lube belt still appears
Find the reset button and push it.
Unplug AND remove the batteries....
Good Luck.
May 05, 2015 | Horizon Fitness T101 Treadmill
Tip
HORIZON FITNESS TREADMILL ENGINEERING MODE AND RUNNING BELT ADJUSTMENT
Eng0 - Display and Button Check
1. While in the Engineering Mode Menu, press Speed "+" or "-" until Eng0 appears in the display.
2. Press "Enter" to select Eng0.
3. Press "Start" button to verify all LED's
Eng1- Hardware Test
1. While in the Engineering Mode Menu, press Speed "+" or "-" until Eng1 appears in the display.
2. Press "Enter" to select Eng1.
3. Press "Start" button to verify belt movement, sensor wire, and elevation function.
Eng2 - Auto Calibration
1. While in the Engineering Mode Menu, press Speed "+" or "-" until Eng2 appears in the display.
For more check the following link . from the drop down menu select treadmills.
www.electro-medical.blogspot.com
on May 03, 2015 | Horizon Exercise & Fitness
Horizon T91 Treadmill - Key Pad Troubleshooting
correct. If the console is not responding or some buttons do but others don't the membrane needs replacement.
Apr 02, 2017 | Horizon T92 - Treadmill
Horizon treadmill won't incline
Step 1:
see the diagram attached.
Clean the motor, lube the gear+shaft
Adjust the small POT for a little.
RUN the software calibration for troubleshooting. see the diagram
Step 2:
Step 3:
Step 4:
he Steps for Newer Style Console Calibration
1.Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
2.Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
3.Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
4.If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
5.Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
6.Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
7.Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
8.Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
9.Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
10.Press ENTER. You should see "SS" or "55" in the console.
11.Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
12.Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
13.When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
14.Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
15.If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
God bless you
Feb 07, 2013 | Horizon Fitness Horizon T101 9 Program...
Will 175/70/13 tires fit 1989 plymouth horizon originally equipted with 185/80/13
They will fit the car but are 2 sizes shorter than original equipment. Will make it ride a little rougher, and may make the speedometer read faster than your actual speed. Probably not a huge effect on the speedo.
Aug 25, 2011 | 1989 Plymouth Horizon America
Lubed belt but display still says lube belt and I cant do anything how do i clear the display I have the horizon gs950t
After lubrication you have to reset your treadmill settings. Then only the message will go off. To reset the tread mill do the following.
1. Hold the "Stop" button for three seconds to reset the treadmill and clear the current workout selection or screen. The console will reset but will save any accumulated data
2. Press and hold the "eTRAK" button for 10 seconds to reset the console date. This permanently deletes any previously accumulated data
3. Press and hold the "Stop" button while pressing the Speed "+" button. Hold for five seconds to reset the console after applying lubricant to the machine. Lubricant application is usually only necessary when you receive the "LUBE" error
ok
May 04, 2011 | Horizon Fitness Horizon T90 Treadmill -...
Screen states Lube Belt , do not have user Manual , Where are lubrication points and what type "lube" can I use ?
hi,
It is necessary to lubricate your treadmill running deck every six months or 150 miles to maintain optimal performance. Once the treadmill reaches 150 miles, the console will display the message "LUBE" or "LUBE BELT". The treadmill will not operate while the message is showing. Hold Stop for 5 seconds to suspend message for 5 miles. Your treadmill came with a bottle of lubricant which can be used for two applications. If you need lubricant, contact Horizon Fitness. Only use lubricant provided by Horizon Fitness.
• Turn off the treadmill with the on/off switch, then unplug the power
cord at the wall outlet.
• Loosen both the rear roller bolts. (For best results, place two removable
marks on both sides of the frame and note roller position). Once the
belt is loosened, take the bottle of lubricant and apply it to the entire
top surface of the running deck. Tighten both rear roller bolts
(matching up the marks for proper position) to original position. After
you have applied lubricant, plug in the power cord, insert the safety
key, start the treadmill and walk on the belt for two minutes to spread
the lubricant.
• Lubricate the air shocks with Teflon based spray.
• Once lubrication is complete, reset the console by pressing and holding 'STOP' and Speed '+' buttons for 5 seconds.
ok
Dec 26, 2010 | Horizon T91 Treadmill
I have a horizon fitness t51 treadmill. I weigh about 138 pounds and typically run 5 miles a day at a 2% elevation at a steady speed somewhere between 5-6 mph. It recently has developed one of two...
hi,
from ur description i think ur treadmills control module have problem. motor driving card and motor is ok. normally there are no serviceable part inside the controlling module ( user interface module). only thing can do is remove the controlling module, take out its board check all the micro switches( press button switches) replace it found faulty or not( remember to remove the power before). the refix it and the test the tread mill.
ok
Dec 26, 2010 | Horizon Fitness Horizon Motor T51...
The console display on my Horizon Fitness T63 treadmill won't stop scrolling/flashing the programs (P1-P6) and will not start up.
Sounds like there is a stuck button on the console, or possibly a loose ribbon cable inside the upper console maybe?
Oct 21, 2010 | Horizon Fitness T90 Treadmill
Exercise & Fitness Logo
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
