Question about Samsung LN-T5271F 52 in. LCD Television
I have a Samsung LNT5271F Television and the screen is black. I have sound but no video. I can't even see the menu or volume button, nothing is showing up on the screen. HELP! :S
    Problem Solver:
  • 16 Answers
If the tv has more than one input, you should try switching to the other one. If it has another output(s), you should try the other output(s).
Posted on Oct 11, 2013
4 Suggested Answers
circuitworld
  • 335 Answers
SOURCE: sound but no video HPT5054 Samsung
One of your transformers on the inverter board are failing to sustain regulated power to the florescent lamps resulting in a dark picture. Also check the SMD fuses on the inverter board(s) see if they have blown. You will need a continuity meter to check them. You can get one from radio shack and be sure to get one with audible sound....you don't have to replace boards when you can fix them.
Posted on Jul 10, 2009
  • 6 Answers
SOURCE: Black screen but have audio.
It's a pretty common problem. (If this is a plasma your post says lcd but it came up under plasma.) The no picture but sound problem is usually the y sus board. I've replaced 2 on mine now. The 680uf 35V capacitors usually are bulging because one of the power transistors went and took them out. This has happened to both of the y boards I had. One time the failing y board took out the buffer boards too, and once it did not. The fix is super simple and anyone with even the most rudimentary knowledge of computers or electronics can do the labor yourself. You should do the simple stuff first by just doing a quick test with a multimeter. Just check the power coming to the y board. After that you can just remove the y board by removing 3 cables and like 3 screws. Plug in the new board and it's done! You can source the parts from a place like shopjimmy or discount merchant. 3 boards were like 200 bucks. 1 board is like 100 bucks. Labor took me 15min. Think about that the next time an electronics repair place charges you 1000 dollars. Of course they check everything (Yeah right) and warranty their work (I don't) but if you check the service manual it states that this is the most common repair. Look for the Canadian manual online. Hope this helps!
Posted on Feb 23, 2010
SOURCE: Picture on Samsung LCD LNT5271F is blurred
Had this exact problem diagnosed by a local repair shop as a bad LCD panel. According to the technician there's a loose ribbon cable on the panel and it would cost as much to replace/repair as a new TV.
Posted on Sep 10, 2010
Samsung flat panel TV. I have sound with a black screen. Can you help me
Hi Cherie, The link below is a YouTube video showing how to fix a Samsung television NO picture GOOD sound, Also there's videos down the right side of the link that may help as well........CHEERS.. Samsung UN46D6000 No picture Sound OK problem FIXED BN95 00497B BN41 01662A
May 01, 2016 | Samsung Televison & Video
Samsung galaxy tab 2 comes on and off(sounds) but screen is blank(black)
Hold the power button down for about 20 seconds, it should hard reset the tablet.
Nov 18, 2013 | Samsung GALAXY TAB 2 7.0 8GB BLACK P3100,...
Sony bravia KDL40S20L1 Lost complete video. Still have audio.
First, unplug all wires/cables from the back of the television including the power cable. Then plug the power cable in and using the power button on the television, turn on the tv and hit the menu button on the side of the television. I
f you have a menu, it could be a simple fix (meaning there isn't a bad board, etc).
You could also use the remote control to try to enter maintenance mode to see if the screen works.
Make sure if your remote has four little white buttons under the power button, select TV
With the tv plugged in and OFF (this is standby) press the following four keys in order within a second of each other.
DISPLAY / 5 / VOLUME + / TV POWER
When the screen comes on (even if black) press the JUMP key quickly once or twice.
if you see a menu, the boards should be okay. If not, might be a little expensive or you didn't press the buttons in time.
In general, if you see a menu on the screen, the lcd board and the electronics involved with making a picture should be okay and it might be loose connections
Mar 04, 2013 | Televison & Video
Black screen
busted lamp. please increase the volume of the tv even thought there is a black display. if a volume comes up then chances are the ccfl lamp is busted that is why you get black display.
Apr 06, 2012 | Vizio P42HDEA Television
Black Screen I checked the connections.....has sound but no picture black even when I push menu button or source
This could be the t-conn board in the back middle top of screen, it's under a metal plate.
Dec 31, 2010 | Samsung LN-S3292D Television
Picture on Samsung lcd LNT5271F is blurred sometimes lines color distortion double images then goes away and will come back. Part of the screen will go completely lines then come back. Starting to happen...
May 12, 2010 | Samsung LN-T5271F 52 in. LCD Television
My screan is black but I have sound. my small chld
It sounds like you have an inverter problem inside the set. You should be able to see the menu. There is nothing in it to totally knock the display out.
Oct 14, 2009 | Insignia IS-LCDTV32 32 in. Television
Menu screen is black
That sounds like your video card is going out on your computer. You will have to get that replaced and then things will work properly.
Jun 10, 2009 | Microsoft Age Of Empires II: Conqueror 2.0...
Black bar down screen left side 12 inches in from left
this is either a circuit board problem or the panel could have a bad tab
Dec 07, 2007 | Samsung SPP4231 42 in. EDTV-Ready Plasma...
Open Questions:
See all Samsung LN-T5271F 52 in. LCD Television Questions
Samsung LN-T5271F 52 in. LCD Television Logo
77 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
