How is the installation for Window 8 - Office Equipment & Supplies
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 128 Answers
Here is a video that should fix your problem
Posted on Nov 05, 2013
How to remove broken side rear glass 95 honda accord
94-97 Honda Accord Rear Side Window Install - YouTube
? 6:00
https://www.youtube.com/watch?v=Cgn0EmuY9NU
Jan 8, 2013 - Uploaded by Function Factory
94-97 Honda Accord Rear Side Window Install ... How to fixreplace install a broken power window regulator ..
Nov 18, 2015 | Honda Cars & Trucks
Installing bernina editor v4 on windows 8
If it was written for Windows 7 or a previous version of Windows, it probably cannot be installed on Windows 8.
Mar 22, 2014 | Computers & Internet
0*0000005c
you must go to ACER web site. And execute diagnostic with the software for indicate what the problem. However you must to know if your computer has the requisite for install window 8. You can visit the window/support for to see what wrong with the computer.God bless you
Apr 02, 2013 | Acer Aspire Computers & Internet
Window regulator replacement in 1988 olds cutlass calais (non-motor). How do I replace the window regualtor?
1985-1998 Oldsmobile Grand Am/Achieva/Calais/Skylark/Somerset
REMOVAL & INSTALLATION
Door Glass and (manual) Regulator
See Figure 1
Fig. 1: Common window attachment
SEE ILLUSTRATION #1 BELOW
1. Remove the door panel.
2. Remove the water deflector from the door.
Be careful not to tear the water deflector when removing it from the door.
The "water deflector" is also known as the "dew wiper"
3. Connect the power window switch/window regulator handle.
4. Lower window to full down position.
CAUTION
Use extreme caution when operating the window with the door panel removed. The window regulator can cause severe personal injury if body parts become entangled in the mechanism.
5. Remove the window run channel.
6. Move window to the half down position.
7. Remove the window retaining nuts.
8. While holding onto the window, lower the regulator to the full down position.
9. Remove the window by sliding it towards the rear and rotating the front of the window upward.
To install:
10. Position the new window in the door.
11. While holding onto window move regulator to half up position.
12. Install the nuts. Roll the window to the full up position.
13. Install the rear run channel.
14. Install the plastic water deflector. If necessary, secure with waterproof adhesive
15. Install the door trim panel.
Window Regulator
See Figures 2 and 3
Fig. 2: Location of the front door window regulator-1995 vehicle shown
SEE ILLUSTRATION #2 BELOW
Fig. 3: Exploded view of the rear door window regulator-1995 vehicle shown.
SEE ILLUSTRATION #3 BELOW
2. Remove the plastic window deflector. Be careful not to tear the deflector when removing it from the door.
3. Remove the door window assembly.
4. Remove the bolts securing the regulator to the door.
5. Remove the nuts securing the upper regulator guide.
6. Using a 1/4 in. drill, drill out the regulator rivets.
7. If equipped with power windows, detach the electrical connector.
8. Remove the regulator through the large access hole in door.
To install.
9. Install the regulator to the door, and attach the electrical connector if equipped with power windows.
10. While holding the regulator to the inner door panel, insert the rivets, and secure them with a rivet tool.
11. Fasten the regulator bolts and upper guide nuts.
12. Install the door glass, and inside door plastic panel.
13. Install the inside door trim panel.
14. Install the plastic water deflector. If necessary, secure with waterproof adhesive.
Fig.1---------------------------------------------------------------------- Fig. 2
Fig. 3
Oct 03, 2011 | 1988 Oldsmobile Calais
Iwant to install IE8 for window 7
you can download IE 8 from microsoft.com and install it manually
or you can do windows update, if your IE is not 8, then IE 8 will be downloaded when you do Windows update and installed for you.
Thanks
Jul 25, 2011 | Microsoft Internet Explorer 8
My driver side electric window assembly collapsed and the window fell down inside the door. The motor is still very good, but I need info and/or a diagram of how it is assembled in order to repair it and...
  1. Lower the window halfway.
  2. Remove the front side door trim panel.
  3. Remove the water deflector.
  4. Support the window in a position needed to access the window rivets by inserting a rubber wedge door stops (1) at the front and rear of the window between the window and the door inner panel.
  5. Drill out the window rivets (3) with a 1/4 inch drill bit.
  6. Remove the window (1) by lifting out of the door. Important: Inspect the window bushings, window bushing retainers, window front up stop, window stabilizer pins and window wedges on the window for damage.
  7. Remove the window bushings and window bushing retainers if necessary, using a flat-bladed tool covered with cloth body tape.
  8. Remove the window front up-stop screw if necessary.
  9. Remove the window front up-stop, front up-stop nut and front up-stop washer if necessary.
  10. Remove the window stabilizer screws, if necessary.
  11. Remove the window stabilizer pins, stabilizer pin nuts and window wedges if necessary.
Installation
  1. Install the window stabilizer pins, stabilizer pin nuts and window wedges if necessary. Notice: Refer to Fastener Notice in Service Precautions.
  2. Install window stabilizer screws, if necessary. Tighten the window stabilizer screws to 7 N.m (62 lb in).
  3. Install the window stabilizer pin nuts, if removed. Tighten the window stabilizer pin nuts to 8 N.m (71 lb in).
  4. Install the window front up-stop washer, if removed.
  5. Install the window front up-stop screw, if removed. Tighten the window front up-stop screw to 7 N.m (62 lb in).
  6. Install the window front up-stop nut if removed. Tighten the window front up-stop nut to 8 N.m (71 lb in).
  7. Install the window bushings and bushing retainers, if removed.
  8. Install the window (1) into door so that holes in window bushings line up with holes in channel.
  9. Install the window rivets (3) in sequence.
  10. Install the water deflector.
Hope this helps
Oct 15, 2010 | 2002 Chevrolet Camaro
It's windows internet explorer,i want to download
to uninstall:
For Windows Vista users:
  1. Click Start, and then click Control Panel.
  2. In the upper-left of the window, make sure you click on Control Panel Home so that Classic View is not active.
  3. Click Uninstall a program from the lower-left of the window, OR from under the program section.
  4. Click View installed updates from the upper-left of the window.
  5. Wait a few seconds for all your updates to appear on the list, then scroll down the listing and highlight Windows Internet Explorer 8.
to install
If you're unable to download the browser from the top of the Internet Explorer 8 homepage, click the "other locales and versions" text under the "Download Now" button to manually select your locale and operating system for Internet Explorer 8 and initiate the download.
Jan 30, 2010 | Compaq Computers & Internet
2004 Mercury Monterey left frnt window sector gear R&R proceedure
are you a techie? You need a heavy duty riveter to do this repair. May have to rent or borrow from auto store.
here's the procedure
Front Door Trim Panel s4w~us~en~file=adobe.gif~gen~ref.gif Printable View (251 KB) NOTE: LH side is shown. RH side is similar.
  1. Remove the parts in the order indicated in the following illustration and table.
  2. Item Part Number Description 1 23942/23943 Mirror access panel 2 1722897 Cup assembly 3 W56904-S424 Window regulator control switch panel screws 4 14A665 Window regulator control switch panel
    Removal Note 5 W701930-S424 Front door trim panel screw 6 W701930-S424 Front door trim panel screw 7 N602703-S61 Front door trim panel screw 8 1723943 Front door trim panel 9 W705590-S300 Nut insert(s)
  1. To install, reverse the removal procedure.
Item 4: Window Regulator Control Switch Panel Removal Note
  1. If equipped, disconnect the electrical connector(s).
Door Window Glass — Front s4w~us~en~file=adobe.gif~gen~ref.gif Printable View (328 KB)
Special Tool(s) s4w~us~en~file=st1132a.gif~gen~ref.gif Heavy Duty Riveter
501-D011 (D80L-23200-A)
  1. Remove the front door trim panel. For additional information, refer to Section 501-01 .
  1. Position the watershield aside.
    To remove individual parts, only carry out the listed steps: Part Steps Front door window glass 1, 3 Front door window regulator 1-5 Front door glass run 1, 3, 6-8
Item Part Number Description 1 W706495-5100 Rivet (2 required)
Removal Note
Installation Note 2 N8621986 Nut (3 required) 3 21410 Front door window glass 4 W706495-5100 Rivet (4 required)
Removal Note
Installation Note 5 23200 Front door window regulator
Removal Note 6 N800507-S Bolt (2 required) 7 21596 Front door glass run 8 — Front door glass run (Part of 21596)
Item 1: Rivet Removal Note
  1. Connect the window control switch.
  1. Connect the battery.
  1. Position the door window glass halfway down to gain access to the door window glass rivets.
    • Remove the rivets.
9391398.gif Item 4: Rivet Removal Removal Note
  1. Remove the rivets.
Item 5: Front Door Window Regulator Removal Note
  1. Disconnect the electrical connector.
  1. s4w~us~en~file=ani_caut.gif~gen~ref.gif WARNING: Prior to power window motor removal, make sure the regulator arms are in a fixed position to prevent counterbalance spring unwind. Failure to place the regulator arms in a fixed position can cause the spring to suddenly release resulting in personal injury.
    NOTE: The counterbalance spring assists the window in the upward direction.
    Remove the bolts and the window regulator motor.
Item 4: Rivet Installation Note
  1. Using the special tool, install the rivets.
Feb 21, 2009 | 2004 Ford Freestar
k24674
jasbo
jasbo
