Question about LG LFX25960ST Stainless Steel French Door Refrigerator
LG LFX23965ST slow water dispenser - LG LFX25960ST Stainless Steel French Door Refrigerator
2 Suggested Answers
  • 12 Answers
SOURCE: lg 27.7 w ice maker
If your ice maker kit has a piercing nozzle you would want to change that cause they build up water deposits very quickly
Posted on Dec 15, 2010
Hi, I have a LG Tromm WD-14331AD. At the start of the wash cycle, water will dispense, but not a lot. When spinning, there is hardly any water in the drum and water just stops dispensing.
A front loader only uses a very small amt of water. That's the point of front loaders. Make sure u only use a very small amt of detergent also. And use white vinegar in place of fabric softener. If washer is slow to fill you can check the filters in the supply lines. Take the water lines off the back of the washer and check the filters in the washer
Jan 01, 2017 | LG Washing Machines
Why does the water from the dispenser run so slow from my lg french dioor fridge
Check the filter.. either on top right in fridge section or on the bottom kick plate.
Also check in coming water line for kinks
Jun 28, 2015 | LG Refrigerators
Water dispenser running slowly
Hello Cynthia;
My name is Peter. I am a retired field service refrigeration technician.
You have a water pressure problem. You need at least 60 PSI water pressure to open the solenoid valves. I suspect you are getting small ice cubes.
If you have well water you are not going to get the pressure for fully dispenser flow.
I have experienced bad water filters. One time our techs received a large shipment of bad water filters. Remove the water filter and test the water dispenser.
With low water pressure you may not want to use a water filter
Dec 08, 2014 | LG LFXS24623S 24.0 cu. ft. French Door...
How do I fix the water dispenser on my LG refrigerator?
#1 cause is the water filter. There may be other blockages in the line. Change the filter one more time and allow the air to purge out of the line. You will make a mess.
Nov 12, 2014 | LG LSC27910TT (265 cu ft) Side by Side...
Fix the water dispenser on my LG refrigerator that is slow.
Hello Frank;
The are 2 possible causes:
1.) If both your water dispenser is slow and you are getting small ice cubes then you either have a bad water filter or a water pressure problem. You water shut off valve can deteriorate internally. This is a common problem.
2.) If your ice cubes are of normal size, then either your water solenoid valve is plugged up or the water tank in your fresh food section is partially frozen restricting the flow. I would bet on a bad solenoid valve.
You can Ohm the solenoid which should read '0' if it is good.
Nov 12, 2014 | Refrigerators
Water dispenser very slow
Check the filter and replace if necessary.
Oct 26, 2012 | LG LMX25981ST Four-Door French Door...
The water dispenser is really slow coming out and it takes however to make ice. There is no kink in the water line to the fridge.
water stopped dispersing out of water dispense, No indication as to why. New filter was instlled, checked water line, no leakage indicated, ice maker had been making ice prior to this, turned off ice maker to avoid motor burn out.
Dec 26, 2010 | LG LRSC-26922 Side by Side Refrigerator
Lg 27.7 w ice maker water dispenser has little 'water pressure slow flow on water dispensing
Dec 15, 2010 | LG Refrigerators
Water dispenser is working very slow the water is flowin very slow.
is the s water holder frozen?
Look behind the lower left prodcue box
if not it could be the despenser valve not
opening all the way
Is the ice maker working OK?
Aug 04, 2008 | LG 22.4 cu.ft. French Door with External...
LG LFX25960ST Stainless Steel French Door Refrigerator Logo
62 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
