SOURCE: SAMSUNG NC10 CANNOT SWITCH ON
take it back and replace it it should still be under warrantie
SOURCE: computer cannot restart and i fear i will lose
Hi there
The delete restoration data indicated the system has gone into hibernate mode. If you had any unsaved Word documents open on the screen before it went into hibernate mode, only the unsaved changes will be lost. The actual documents (if previously saved) will remain saved.
You can safely accept the delete restoration message, and the system will boot as normal and let you login. As long as your current work was saved, it will stay saved.
I hope this helps. Kindly rate my solution if I have been helpful.
Thank you.
Testimonial: "great. thanks."
SOURCE: I bought new Samsung Q30
Hardware problem, the speakers are no good, try using your headphones or connect them to external speakers.
SOURCE: I have a N150 plus
In first remove battery, then one press turn on buttom, then put battery, and turn on.
if will not resaults,
reinstall operating system from CD/DVD
