Question about Electrical Supplies
The door won't go all the way down , the eyes are clean and no obstacles in the way
    Sergeant:
    Champion:
  • 426 Answers
They have to see each other line them up
Posted on Nov 06, 2013
Door starts down then stops eyes are clean and aligned . i adjusted down force some. changed baterries and wall switch nothing helped
Disconnect the door opener from the door and insure the door easily goes up and dow
with your hand. It may be binding.
Good Luck
Feb 01, 2011 | liftmaster Chamberlain Garage Door Opener...
I have Liftmaster lifts on both of my two car garage doors. One works just fine but the other one only works when you press the wall button and hold it down until the door is done moving. Otherwise it...
One of your sensors is moving and you need to find out why and correct it. The light flickers when the sensor is on the edge of the beam sent by the other sensor. Think of it as a flashlight.
Dec 31, 2010 | Sears Craftsman LiftMaster Chamberlain...
Sears 41A4315-7E garage door opener trouble codes. The door opener works manually. When the remote is used the unit receives the signal but the light flashes 4 times and the door doesn't work. Got any...
4 FLASHES TELLS YOU THAT THE PROBLEM IS WITH THE SAFETY EYES.
THEY MAY BE OUT OF ALIGNMENT OR HAVE A DIRTY LENS.
BE SURE THE EYES ARE CLEAN, MOUNTED SOLDILY AND AIMED CAREFULLY.
THE LEDS SHOULD BE LIT BRIGHT AND STEADY (NO FLASHING OR FLICKER)
NOTE: IF SAFETY EYES ARE MOUNTED TO THE TRACK THEY MAY MOVE OUT OF ADJUSTMENT AS THE DOOR GOES UP AND DOWN. - ADJUST TRACK
HOPE THIS HELPS
Nov 30, 2010 | Craftsman Sears Liftmaster Garage Door...
Door won't close unless I hold the button all the way down.
make sure the eyes are clean and aligned if the opener thinks something is obstructing its path it will not close
Oct 07, 2009 | liftmaster Chamberlain Garage Door Opener...
Roomba 560 just goes in a small circle, will not go forward or backwards, then a red alert lights up ststing to clean it, which a throughly good cleaning has been done, gave this as a gift to someone and...
you cleaned the wrong thing there are small ir lights on the under side of the Roomba they look lke small red buttons clean the lenses with a q-tip and, alcohol. these infrared leds are the roomba's eyes you'd go in circles too if you couldn't see obstacles.
Jan 11, 2018 | iRobot Roomba 560 Robotic Vacuum
My garage door will not stay down when I try to close it.
IF THE DOOR CLOSES ALL THE WAY WHEN HOLDING DOWN THE WALL BUTTON AND REVERSES 6" FROM THE FLOOR WHEN NOT HOLDING THE BUTTON.
I WOULD GUESS THAT THE SAFETY EYES ARE MOUNTED ON THE TRACK.
WHEN THE DOOR CLOSES THE TRACK AT THE BOTTOM IS TOO TIGHT CAUSING IT TO FLEX AS THE DOOR GETS NEAR THE BOTTOM. WHEN THE TRACK FLEXES THE EYES ARE POINTING FURTHER AWAY FROM THE DOOR AND EVENTUALLY THEY ARE TOO FAR OUT OF ALINMENT AND THE LED WILL GO OFF - THE DOOR GOES BACK UP.
SOLUTION: YOU CAN USE THE CLAW END OF A HAMMER TO TAP THE TRACK OUT A LITTLE WIDER - TAP NEXT TO THE WALL ON THE BRACKET THAT HOLDS THE TRACK TO THE WALL. MOVE THEM ABOUT 1/4" EACH SIDE.
OR
YOU CAN MOUNT THE BRACKETS TO THE WALL OR THE FLOOR.
THIS SHOULD SOLVE IT
HAVE A GREAT DAY
Dec 19, 2008 | Sears Craftsman LiftMaster Chamberlain...
Proscan dvd player
the manual may be available in some of these following website....
www.allamericandirect.com/TOSHIBA_PRO_SCAN_DVD_VCR_COMBO_Player_NO_TUNER_p/sdv295.htm
www.usersmanualguide.com/funai/dvd_player
just open your dvd player with the door ejected and then just clean the dust particles and obstacles in the door way and especially clean the lens... use only dry clothes for cleaning ... after that just give a try..
if problem persists or if you are afraid of opening it or if you dont have any idea about it then contact the near by technician and tell your problem...
he will clean the lens with the white petrol or spirit...
then your problem will be solved ...
he will not charge much for cleaning lens he may charge 100 bugs or 150 bugs that s all ...
and if there is any other problem just like the lens is out something like that he may charge more...
Feb 08, 2008 | Televison & Video
Electrical Supplies Logo
24 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
