Question about Mitsubishi Office Equipment & Supplies
Hi, I have just bought a second hand Mitsubishi Projector EX53U. It was working when I picked it up but a day later I plugged it in and the red POWER light comes on but I can't turn it on.
    Champion:
  • Mitsubishi Expert
  • 225 Answers
You can try reset by holding power video and computer buttons for 2 minutes. IF it tries to come on then goes off it is the lamp. Do you have a remote?
Posted on Nov 26, 2013
smeago1
  • 136 Answers
SOURCE: No light come on from the projector
Thats the projector telling you that you need to replace the lamp. Lamps usually lasts for about 2000 hours so if you had it for a while you may need to replace it.
www.froogle.com and enter your make and model or go to www.projectorcentral.com and find a few retailers in the US that sells lamps.
good luck
smeags
Posted on Jan 02, 2008
heathgr
  • 442 Answers
SOURCE: replaced bulb yesterday worked fine.
green green is power on, normal
then it tries to light the lamp, but it can't so the protection circuit comes activated.
you get red and green blinking
Then it goes to standby, red and off.
so something has happened to the lamp, or lamp ballast power supply.
Take the lamp out and check if all is OK with the 2 terminals in the connector, and the leads to the lamp are intact.
Failing that, I would suspect the ballast lamp power unit
Posted on Mar 26, 2011
SOURCE: projector automatically shuts off immediately after turning it on
If your comfortable w/surface mount troubleshooting and soldering, download the service manual from elsewhere online. Part of the troubleshooting tree for this type of problem is to check the surface mount fuses on the underside on the Main PWB (schematic page 1/8). On mine, the 12V surface mount fuse, F3004 (2.3A) was open (quadrant C1 on the schematic). Replaced it, reassembled the projector (3 interlocks don't 'cha know) and it came up just fine.
Doug
Posted on Dec 10, 2007
SOURCE: Blinking Light on Mitsubishi SL4SU Projector
To jmatthews
Both power light and status light a solid red with no response to any buttons indicates the bulb timer has expired. You need to reset the timer by pressing and holding the left arrow key, the right arrow key and the power button all at the same time for a few seconds.
If there are no problems, the projector will fire up, but you must replace the bulb as it will fail soon and perhaps explode when it does.
Take care
Posted on Mar 23, 2009
SOURCE: the projector lamp does not turn on
I have done this on several of our PT-LB50U's with sucess every time.Remove lamp cover and lamp.Then remove top of case by removing 6 screws on bottom.Remove metal shroud that would cover lamp 2 screws and remove 2 screws that hold lamp plug and move it away.You will see a little blue lever for saftey switch move it back and forth from top and bottom put back together and should turn on.
Posted on May 13, 2010
Replacement bulb not working on HP vp6121
The ballast board controls the bulb. It is the board with the wires going to the bulb socket. Replace that and you'll have a working projector.
Jul 23, 2016 | HP VP6121 DLP Projector- XGA 2000 Lumens...
Why does my Mitsubishi XD221U projector have a power light blinking red and green?
Reset the lamp timer by holding power and menu button down for 25 secnnds
Sep 03, 2014 | Mitsubishi XD221U New
Mitsubishi xl9u cancel password
1,Plug in the power cord,
2, holding down the "left", "right", and
"POWER" buttons on the control panel at the same time.
3,ok
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry Lampdeng Limited
Mobile: 0086-13178867858
Wecha t ID: 008613178867858
Whatapp ID: 008613178867858
Skype: lampdeng@hotmail.com
http://www.lampdeng.com
Mar 01, 2014 | Mitsubishi XL9U LCD Projector
I plugged in my xd490u [mitsubishi] data projector...and then power turned red, status turned green for few some seconds. later power blinked [red + green] and did not work. can anyone tell me what the...
It sounds like your lamp may need replacing. Before you go that route try all of these:
-Make sure the lamp cover on the bottom is fully attached. -If you unplug the power cord while the fan is rotating, the lamp may not turn on about 1 minute when you plug the power cord next time. After the status indicator stops blinking press the power button to turn it back on. May have to press it multiple times. -If your Power Light continues to blink red/green then you should contact your dealer.
Sorry I couldn't be more helpful.
Feb 28, 2011 | Mitsubishi XD490U Multimedia Projector
To jmatthews
Take care
Oct 28, 2008 | Mitsubishi SL4SU ColorView Multimedia...
The Protectiopn circut is working
Hi there
Did you check that your lamp hours were actually reset ?
Mar 27, 2008 | Mitsubishi XL1XU Multimedia Projector
Mitsubishi xl2u projector
also have the same problem
Jan 29, 2008 | RIM BlackBerry Pearl 8100
XG-C50 Problem
Hello
Replace the fly-eye lens of projector.
Viren
Nov 09, 2006 | Sharp (BQCXGC50X1) Projector Lamp for...
134 people viewed this question
Top Mitsubishi Office Equipment & Supplies Experts
Martin Murray
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
