Question about VIA ECS PM800-M2 PM800 P4FSB 800 Supports Intel Pentium 4 Processor (REV:1.0) (ECSPM800M2V10) Motherboard
I can detect no SATA' HDD - VIA ECS PM800-M2 PM800 P4FSB 800 Supports Intel Pentium 4 Processor (REV:1.0) (ECSPM800M2V10) Motherboard
  • 2 more comments
  • Anonymous May 01, 2009
    i can't boot on my sata dvd drive
    i have set my bios to boot on cd first priotity still i cannot boot
    my sata cable are all ok both power and data cable still i cannot boot from sata drive my bios is set to boot from cd first priority and it recognize my dvd drive what could be the problem
    i am already a member and my email is catsteye_119@yahoo.com but i can't login here
  • wiztstar May 03, 2009
    I have the same problem; is there a bios upgrade to handle this problem?
    Problem Solver:
  • 5 Answers
The ECS PM800-M2 only supports SATA 1.0 hard drives. If you are using a newer SATA 3.0 hard drive, there is a jumper on the hard drive which has to be set to SATA 1.0 in order for the VIA 8237R chipset southbridge (which Is on your ECS PM800-M2) to recognize the newer SATA 3.0 hard drives. This Is applicable to all motherboards with the Viatech PM800 / 8237R chipsets. Note: the location for the SATA 1.0 / 3.0 jumper varies on each brand of hard drives. Also check If SATA Is enabled In the BIOS and select IDE mode.
Posted on May 03, 2009
  • 3 Answers
There are 2 different types of SATA, Sata1 and Sata2. The PM-800 M2 does not support Sata2, so in order to connect a Sata Drive, you have to install a jumper on the Hard Drive jumper pins. Check you HD data for the proper setting.
Posted on May 04, 2009
    Problem Solver:
  • 6 Answers
Plz chek your data cable of sata hdd. and then open bios setup and go advance option and check ther hdd is ditect or not if not then your data cable fail.otherwise call me 9887863101
Posted on Apr 23, 2009
Gigabyte g31m-es2c motherboard can't detect my sata hdd
dude make sure if the jumper pin is set properly
as i think your MObo is sata 1 support and all new generation Hdd are sata2 support so u have to set the jumper pin. the setting are different fro different Hdd so check the producers website.
Mar 16, 2010 | Intel Motherboard
Bios not detecting 320gb sata drive
Double check the jumper configuration, You might also want to check the cables and ports incase that's the problem because a properly jumpered SATA drive shouldn't have any compatibility issues. Also check if *********** board supports the SATA ? Let me know if this works..thanks. Mike
Mar 04, 2010 | PC Chips M955G Motherboard
MSI RC410 - cannot detect Sata HDD
i think the problem is with ur SATA HDD. To confirm, try another SATA HDD on ur mother board and see if the problem persists
Sep 20, 2009 | ASUS P5RD1-VM Motherboard
Mother board cant detect my Sata HDD, please advise me urgenly...
I will advice you to exchange the HDD with someone or with brand new one as it seems to be problem with drivers of the sata.
Sep 20, 2009 | MSI RC410M-L Motherboard
Sata hdd not detected
Yes, go into the bios and make sure that SATA is turned on. Sometimes with motherboards that have two ide controllers the SATA is turned off by default. Also another thing to check is whether the motherboard is SATA I or SATA II. If it is SATA I then change the jumper on the hard drive to peg back to SATA I. Your new hard drive is SATA II and the motherboard may not support it.
Jun 10, 2009 | Biostar K8T80-A7 Motherboard
M2N-MX SE PLUS SATA PROBLEM
Do your have windows installed on a ide drive?, cos if this is the case you have to install the sata hdd drivers.
Mar 27, 2009 | ASUS M2N-MX Motherboard
System can detect Fujitsu MHY2160BH : 160GB HDD, but cant install
it seems that your computer might have a SATA hard drive which could not be detectable by windows xp, try to install vista it will detect it easily.
otherwise use dm (disk manager) for detection and partition.
Dec 17, 2008 | Fujitsu 160GB MHY2160BH 2.5" SATA 5400 RPM...
Bios problem
first of all enter into the BIOS SETUP and than check there wheather it detect the SATA HDD OR NOT. IF not than there is option in bios to detect the sata hdd please set it properly to detect sata hdd. it might be set to RAID or something else. and this will definitely solve your problem and you will be able to detect the sata HDD.
Dec 03, 2008 | Computers & Internet
My brand new ASUS ee PC notebook won't boot up. Any suggestions?
check in the bios settings if the hdd is detected..if detected,you need to re-install the windows..if not detecting,you must replace the hdd...ahh! i think the hdd for this laptop is expensive..coz i know its something special..not same like normal hdd in laptop,like ide or sata..its small hdd inside the board...half size for the 2.5" hdd sata or ide
Nov 23, 2008 | ASUS Eee PC 900 16G Notebook
Sata hdd detected but problem with booting&installation
i have sata hdd 160 gb of seagate and hdd detected in raid channelbut when start installing window it shows message press enter for fresh installation "no hdd found please check power card,bios configuration
Jun 30, 2008 | ASUS P5RD1-VM Motherboard
VIA ECS PM800-M2 PM800 P4FSB 800 Supports Intel Pentium 4 Processor (REV:1.0) (ECSPM800M2V10) Motherboard Logo
1,248 people viewed this question
Top VIA Computers & Internet Experts
David
David
Tony
Abhinandan  Patil
Abhinandan Patil
Are you a VIA Computer and Internet Expert? Answer questions, earn points and help others
