Question about Fendi Womens Greek God Dial 18k God Plated Stainless Steel Watch F85190
Where was Demeter last seen in any location - Fendi Womens Greek God Dial 18k God Plated Stainless Steel Watch F85190
How do I set the time on a 2 button Reebok vintage digital watch? It came with no instructions.
hi.i dont own one nor have i seen one but ive had old watches before. instead of just pressing the buttons try holding them down 1 at a time and hold the button until the digits flash. which ever button makes them flash the other one will change the time. another way is to press the button 2 or 3 times quickly ? and last try would be to look around the side of the watch and you might find a very small indent ( usualy between the buttons ) .. some of them need a pin to push that in to change the time. there the only ways i know,hope this helps
Apr 28, 2015 | Reebok Watches
How do you navigate the Tapout touch watch, Anyone know how to use these?
Check online at YouTube. Never heard of this watch but seen some pretty cool watches that may be similar to yours or may give you some hints. The Tapout website had nothing for manuals that i found but this may be ingenious marketing on there part. Lose the instrauctions, buy a new watch with instructions. Sorry can't do anything better then this.
Aug 19, 2014 | Watches
How to locate a watch battery number 378?
Could be a 373? 378 doesn't exist I believe.
Sep 05, 2012 | Watches
I want to renew my passport
Renew by Mail if All of the Following are True: Your Most Recent U.S. Passport:
  • Is undamaged and can be submitted with your application
  • Was issued when you were age 16 or older
  • Was issued within the last 15 years
  • Was issued in your current name or you can legally document your name change
If any of the above statements do not apply to you, you must Apply in Person
A Note on the U.S. Passport Card: If you are a previous passport book holder and you are eligible to use Form DS-82, you may apply for a passport card as a renewal by mail - even if it is your first passport card!
How to Renew Your U.S. Passport by Mail: From Inside the United States: To renew your U.S. Passport by mail, you must submit Form DS-82, Application for a U.S. Passport by Mail. Locate Form DS-82 and step-by-step instructions at Form DS-82: Application for a U.S. Passport by Mail.
From Outside the United States:
U.S. citizens residing abroad (except those living in Canada) should renew their passports at the nearest U.S. Embassy or U.S. Consulate.
Need a U.S. Passport Immediately?You should make an appointment to be seen at a Regional Passport Agency only if:
  • The U.S. passport is needed in less than 2 weeks for international travel
  • The U.S. passport is needed within 4 weeks to obtain a foreign visa
Contact the National Passport Information Center to make an appointment or locate a Passport Agency.
Read more here: http://travel.state.gov/passport/renew/renew_833.html
May 17, 2011 | Watches
I have a Concord Saratoga. Won't clasp correctly.
If you look at their web site under "service", the lower line in blue says "for all other models, use the service locator below".
When you use it, the service locator tells you to contact the NJ address.
The implication is that they will service other models.
(Possibly not the clearest site I have ever seen).
Feb 14, 2010 | Watches
A question was asked and answered about a casio 1170 last september from repman. I have the same problem with restarting the watch. Ihave tried grounding what looks like 'AC'inside the watch with the +...
The best Solution for this Problem as of Now is :-
1) Take off white plastic cover so that the only metal cover is seen
2) Notice in upper right corner there is a "golden" pad - tiny one and in the metal cover there is an engraving AC. Use some needle like (conducting) object and connect this pin to metal cover (ground) - this will reset your watch.
I am not sure, whether you tried the same thing as you did mention AC .
Let me know, once done.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Dec 22, 2009 | Watches
SECOND HAND - INVICTA MODEL 2692
Hi Ed,
I have been in the industry for the past 2 years as a watchmaker's assistant. So I'll see if I can help.
The larger second hand you see in this Chronograph model, using it is only available in the Chronograph mode.
How long a battery should last (if I had a dollar for everytime I've heard that one! :)
Well generally a battery should last about 2 years. It all depends on how many functions that watch has, as for a chrono the more you use that function the more the battery power it uses. I have not seen this watch but as it looks to be the 'standard' kind of format of a chronograph, just one battery would surfice.
In regards to 1/10 lap, please take the to a watchmaker as the hands need to be reset, this either can be done manually or can be done by pulling out the crown slightly (please as if you are to forcefull you will pull the crown and stem out) NOT GOOD!. if you pull it out to 'quick date change' where only the date can be changed try pressing one of the pushers and see which sub dial hands move, if that doesn't work try the other pusher.
Again if the above doesn't work, pull the crown out to time set mode (where you can adjust the time) and try the same steps as above. If this fails and it's still off, take it to a watchmaker and he/she will realign the hands for you!
Kind Regards
Shenlun
Jul 12, 2009 | Invicta Dive/Sport - ABYSS ALARM CHRONO...
Longines watch problem
Some longines watch has built-in battery gauge. When battery is low, the second hand jumps every four seconds. If you have new battery installed and the problem persists then there is a short circuit somewhere that drinks a lot of battery juice.
Mar 11, 2008 | Longines Watches
Watch case
This is more of a manufacturing than a support problem. However, if you would like to have the watch resurfaced or restored a qualified jeweler should be able to acid wash and plate it for you. It depends on the value of the watch (monetary or sentimental) and how much you're willing to spend. I wouldn't expect plating to run much more than $150 but you'll want to make sure you're clear on the end result (shiny, brushed finish, tinted, etc.).
Nov 10, 2007 | Watches
Fendi Womens Greek God Dial 18k God Plated Stainless Steel Watch F85190 Logo
67 people viewed this question
Top Fendi Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Fendi Watch Expert? Answer questions, earn points and help others
