Question about Cuisinart DLC-2011 PowerPrep Plus Food Processor
Cuisinart will not pulse or shut off, lights light up on the dough and the On buttons. Have to unplug it to stop it. It happened when I was making a recipe using pulse and just took off on it's own and won't stop. HELP, I just bought this and have used it less than a dozen times!!!!
4 Suggested Answers
SOURCE: Cuisinart Prep 11 Plus Food Processor - Help!
Not sure if you found the solution by now but we recently had a similar issue. Make sure the bowl is put on such that the handle is facing the front of the processor. There is a little black button that gets depressed when the lid gets put on. We had to get the thing to work one night and spent hours trying to get the processor on and then trying to get a blender to work before finding the problem.
Hope this helps.
Posted on Nov 28, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: Tried to use my powerprep pluss cuisinart food
Remove the work bowl from the base of the food processor, and separate the bowl, lid, and pusher sleeve.
Plug the base into the wall outlet, turn the food processor ON, and then use a pen to press in the dark grey or black button on top of the base of the food processor - if you hear some kind of noise, then your motor is still good.
Put the work bowl on first, with the handle facing the front of the food processor.
Put the lid on, with the lid lined up with the handle of the work bowl.
Put the pusher sleeve in the lid, with the metal piece facing the front of the processor.
Your processor should now turn on.
If it doesn't call Cuisinart and see if you are still in-warranty (3-year warranty).
-Tha Mp3 Doctor (also loves Cuisinart)
Posted on Mar 24, 2009
SOURCE: power is available (light is one) but nothing
Sounds like a safety feature working. Unplug. Take apart as if you are going to clean it. Check all parts carefully to see if there is anything broken, like a nub.(Are all parts there?) Put back together, making sure they are fully engaged. Plug in and try. This happened to my food processor and it was a bit of dried food stuck in the bowls sliding track that kept it from clicking fully connected. Hope this helps!
Posted on Jul 19, 2009
Cuisinart DLC-8S Food Processor: On/Off Switch not working
Replacement of the switch would be a likely repair unless other damage makes replacement impractical.
Apr 14, 2017 | Cuisinart DCC Food Processors
I have a very old cuisinart food processor. It stopped after I tried to make a dough in the mixer
If it is old enough you may have burnt up the motor. I don't know that the older FP's are designed for mixing dough.
Jan 23, 2010 | Cuisinart DLC-10S Pro Classic Food...
I have a small Cuisinart food processor and I cannot figure out how to turn it on. It has two levers low and high. I have it plugged in and the lid on? Please help. Fiona Slattery 858-752-8591
Your PowerBlend Duet™ comes with a food processor button. This button is the perfect speed for all your food processing tasks. Always use this speed when using the food processor. You may also use the Pulse button with this function for pulse-chopping.
To use your food processor, make sure that the bowl is assembled properly and the blade or slicing/shredding disc and the cover are locked into place.
When you use the control panel, the LED will light next to each button you press.
Press the On button. For continuous operation, press the Food Processor button. Motor will start if you have followed assembly instructions.
To turn motor off, press the Food Processor button again or the Off button.
For on/off operation, called pulse-chopping or pulsing, press the On button, press the Pulse button, and then press and release the
Food Processor button the desired number of times. Motor runs as long as you hold the Food Processor button down. The motor stops when you release control switch. Try it a few times.
You control the duration and frequency of pulses by the length of time you hold the Food Processor button down and the rate at which you press it. Pulses should be short bursts. Allow enough time between pulses to let food in work bowl fall to bottom.
Always use the Food Processor button for pulse/chopping. Never turn cover back and forth to start and stop processor.
You can download manual from the below link
http://www.cuisinart.com/share/pdf/manuals/bfp-10ch.pdf
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
Sep 12, 2009 | Cuisinart Food Processors
Power is available (light is one) but nothing
Jul 19, 2009 | Cuisinart DLC-5 Food Processor
Tried to use my powerprep pluss cuisinart food processor and nothing happens. The on button lights up but nothing happens when i press the pulse button.
Mar 23, 2009 | Cuisinart DLC-2014 PowerPrep Plus Food...
Motor fails to operate - very hit and miss
Make sure you are using the dough blade for dough instead of the regular blade - dough will cause the regular blade/assembly to gum up. This is actually a VERY high quality unit w/ a 20-year motor warranty. I would see if you get better results with the dough blade. Don't give up on it yet.
Dec 14, 2008 | Cuisinart Limited Edition Metal MP14 Food...
Hope this helps.
Sep 26, 2008 | Cuisinart DLC-8S Pro Custom Food Processor
Cuisinart won't pulse
I started from scratch with the assembly instructions. Got it together correctly and now everything works.
Mar 03, 2008 | Cuisinart DLC-2011 PowerPrep Plus Food...
Cuisinart DLC-2011 PowerPrep Plus Food Processor Logo
56 people viewed this question
Top Cuisinart Food Processors Experts
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
Are you a Cuisinart Food Processor Expert? Answer questions, earn points and help others
