Question about Bulldog Remote Starter & T-Harness Kit for 95-03 Chevy Blazer/Chevy S-10 Pi
The security light was on in my Chevy Impala, so I reset the security passlock. Now the door chime is constantly dinging unless I turn on the lights, then it stops.
  • 60 Answers
Have you tried resetting the computer?
Posted on Oct 23, 2013
How can I bypass the security code
Why do think the key security is bad? If you still have a factory key, this is not the problem...if no factory key, you can take your VIN number or original key to GM dealer to get new key that they will program for you...Check for dirty battery connections:)
Apr 30, 2015 | 2003 Chevrolet Impala
My 2003 Chevy impala will not trun over at swith
Does the "security" light come on? It may be an issue with the GM Passlock anti-theft system. There is tons of information on repairing the GM Passlock problems. Just search for "2003 Passlock issues."
Oct 27, 2014 | 2003 Chevrolet Impala
Reset passlock code
Is your Impala a 2000, 2001, or 2002? This seems to be a common problem in those model years...much like its predecessor the GM VATS (Vehicle Anti-Theft System). While the VATS had a permanent (albeit unapproved) solution, no suck workaround appears to be available for the Passlock system. Some websites offer a correction "module" that looks to be a hit-or-miss solution. I did find the following procedure on a forum, and it seems to be reliable. Here goes:
If your car has been sitting while you were at work or home or in the store, and you are coming out to leave, follow steps 1-6.
If you just had the SECURITY SYSTEM lock you out of the ignition system, you will have to wait the 10 minutes for it to reset and allow the ignition control module to interact with the system. Once the 10 minutes have passed from the ACTIVE SECURITY STATUS, follow steps 1-6. Do not try to shortcut this as it wont work.
If it is raining, you can close your door, just not all the way. Close it all the way and open the door latch without pushing the door open. This will keep you dry.
+++++STEPS+++++ 1.) OPEN YOUR DRIVERS DOOR AND SIT DOWN. 2.) PLACE KEY IN IGNITION, WAIT FOR CHIME. (3 seconds is what I usually wait) 3.) TURN IGNITION 1 CLICK RIGHT (TO THE ACC POSITION) AND STOP! Do not continue to ON and START yet. WAIT ATLEAST 5 SECONDS 4.) AFTER 5 seconds has passed, TURN KEY TO ON and STOP, DO NOT CONTINUE TO START YET! 5.) WAIT AND WATCH. With your drivers door open, here is what you will see and hear = Your notification will signal DOOR ADJAR, then the BATTERY light, then the SECURITY light, during which you will hear the chime sound as if you just started the car. 6.) AFTER YOU SEE THE SECURITY light switch back to DOOR ADJAR or Battery, and after the CHIME has stopped, you can turn the key to start and voila!
It has worked every time for me and 5 of my friends. This whole process takes about 20-30 seconds, but it sure as hell beats 30 minutes, as GM refuses to compensate my time lost to their vehicle\'s design flaws.
RECAP: 1.) Open driver door, sit down 2.) Insert key in ignition, wait for chime 3.) Once chime starts wait 3 seconds 4.) Turn key to ACC position WAIT atleast 5 seconds 5.) After 5 seconds turn key to the ON postion and wait for the security light to switch back to Battery or DOOR adjar, and the chime to stop (Do not try to START if the chime is still sounding) 6.) Once chime stops and Security light has passed, You may now complete the turn to START and it will start.
Note: This is not a permanent workaround, but it will buy you some time, I can almost guarantee it will work for most if not all people, almost all the time.
Oct 11, 2013 | Chevrolet Impala Cars & Trucks
I think i have a vista keypad. I dont have a manual that shows the keypad features. I like for the doors to chime when opened. They stopped chiming for some reason. can this be reset.
On a vista system, enter your 4 digit code and press the 9 button. The keypad should read: Disarmed Chime. The keypad should ding ding ding when a door is opened. To turn the chime off, enter you code and press the 9 button again.
Jun 18, 2011 | Honeywell 6160 Vista Custom Alpha Keypad
How do i reset the passlock system for the chevy impala 2001....i want to turn the damn security system off!!!!
Turn the key on, don't try to start it, let it set on for ten minutes turn it off. do this three times, after the third time your will start. Make sure you have everything else turned off. and if your lights are automatic with the key on, you will have to put a charger on the battery as you do it. because 30 minutes with the lights on will drain your battery. Also you can not disable the security system
Nov 20, 2010 | 2001 Chevrolet Impala
The dash light indicates I have a door opened and a chime dings when I hit a bump. All the doors are closed.
Check the 2 contacts on the passenger sliding door. If the door is out of adjustment they will have poor contact and a bump will jar it and turn on the light and chime. Make sure the side door closes securely.
Jan 28, 2010 | Dodge Grand Caravan Cars & Trucks
Pass lock problems
Your Passlock may need to relearn the ignition keys, if the ignition lock has gone bad like my in-laws Grand Am Gt, here is what i did so they will not get stranded any more. Buy a Passlock by pass module for around $70.00. You can order one from GMPASSLOCK.COM in the mean time try resetting the Passlock. Good luck
Ignition keys relearn takes about 30 min to do. 30-Minute Learn Procedure
1.) Turn ON the ignition, with the engine OFF.
2.) Attempt to start the engine, then release the key to ON; the vehicle will not start.
3.) Observe the SECURITY tell tale light. After approximately 10 minutes, the light will turn OFF.
4.) Turn OFF the ignition switch, and wait 5 seconds.
5.) Repeat steps 1 through 4 - two more times - for a total of 3 cycles of 10 minutes. 3x10 = 30 minutes.
The vehicle is now ready to relearn the Passlock Sensor Data Code and/or passwords on the next ignition switch turn from OFF to CRANK Important: Turn the Ignition Switch OFF. The vehicle learns the Passlock Sensor Data Code and/or password on the next ignition switch transition from OFF to CRANK. You must turn the ignition OFF before attempting to start the vehicle.
6.) Start the engine. The vehicle has now learned the Passlock Sensor Data Code and/or password.
7.) With a scan tool, clear any DTCs if needed. History DTCs will self clear after 100 ignition cycles.
Without a scan tool you may have momentary starter interruptions while history clears itself.
Jan 18, 2010 | 2000 Chevrolet Impala
Bulldog Remote Starter & T-Harness Kit for 95-03 Chevy Blazer/Chevy S-10 Pi Logo
143 people viewed this question
Top Bulldog Security Vehicle Parts & Accessories Experts
Matthew Spark
Matthew Spark
John
John
Are you a Bulldog Security Vehicle Part and Accessory Expert? Answer questions, earn points and help others
