Question about Epson Stylus CX8300 Printer
My cx8300 saw waste ink pad in printer is suturated contact the dealer to replace it!how can i solve the problem!!thanks!!
I get start the printer Epsom printer cx8300,cx8400 and viw the error wast ink bad bad no run how ripper that
Posted on Dec 17, 2009
Wast ink counter epson stylus cx 9300f rest
Download the adjustment program (see below)
Extrak adjustment you have downloaded
Go to The extrakded folder then click tricks-collections.bat file
Now set the date setting in you PC to 11 April 2008,
Run adjustment program by click AdjProg.exe file the click accept
Click Particular adjustment mode then select destination and printer port then click OK
Select Waste ink pad counter from the below window and double-click to execute it
Click [Check] button to check current protection counter's value.
Then Click [Initialization] to reset the protection counter to the initial value. Thats all.
After finishing, you can change the date to normal.
Link Adjustment program for epson CX7300, CX8300 and CX9300F
Adjustment program for epson CX7300 : http://www.mediafire.com/?8wrkugah2mj
Adjustment program for epson CX8300 : http://www.mediafire.com/?0xfnrgarvuj
Adjustment program for epson CX9300F : http://www.mediafire.com/?o020wlaf6te
Jul 29, 2012 | Epson Stylus Multifunction Inkjet Printer/...
Tip
How To Reset Ink Counter On An Epson CX7300, CX8300 or CX9300
You must set the date in your computer to "April 11, 2008" to run Resetter Epson CX7300, Epson CX8300 and Epson CX9300 without error. If do not alter the setting of date of according to rule then software will deleted automatically when running.<br /><br />If you have an error, delete all following entry before you rerun the software.<br /><br />delete registry key: <span style="font-weight: bold;">HKEY_LOCAL_MACHINE\SOFTWARE\EPSON\PTSG</span><br /><br />and delete folder: <span style="font-weight: bold;">C:\adjustment program</span><br /><br />To reset waste ink pad counter Epson CX7300, CX8300 and CX9300F use adjustment program. I have tried this software and this software worked. To run this software without error please follow the instructions above.<br /><br />Here How to use this software:<br /> <ol> <li>Download the adjustment program (see below)</li> <li>Extract the file you have downloaded</li> <li>Go to The extracted folder then click tricks-collections.bat file</li> <li>Now set the date setting in you PC to 11 April 2008,</li> <li>Run adjustment program by click AdjProg.exe file the click accept</li> <li>Click Particular adjustment mode then select destination and printer port then click OK</li> <li>Select Waste ink pad counter from the below window and double-click to execute it</li> <li>Click [Check] button to check current protection counter's value.</li> <li>Then Click [Initialization] to reset the protection counter to the initial value.</li> <li>After finishing, you can change the date back to normal.</li></ol><b><br />Link Adjustment program for Epson CX7300, CX8300 and CX9300F</b> <ul> <li> Adjustment program for epson CX7300: <a href="http://www.mediafire.com/?8wrkugah2mj">http://www.mediafire.com/?8wrkugah2mj</a></li> <li> Adjustment program for epson CX8300: <a href="http://www.mediafire.com/?0xfnrgarvuj">http://www.mediafire.com/?0xfnrgarvuj</a></li> <li> Adjustment program for epson CX9300F: <a href="http://www.mediafire.com/?o020wlaf6te">http://www.mediafire.com/?o020wlaf6te</a></li></ul> <br />
on Mar 09, 2011 | Office Equipment & Supplies
Parts inside in my printer are near the end of their service life
A Service Error where you get a message telling you that "Parts inside your printer at the end of their service life, contact your dealer for replacement", or "Parts inside your printer require maintenance or replacement, call your service company", is normally a Maintenance Request Error. The maintenance request error is actually a Waste Ink Ink Pad Error and usually your remedy is:
1. Replace the Waste Ink Pad/Pads with a new one/ones (many people ignore this one, and they just follow #2)
2) Reset the Internal Waste Ink Pad Counter by using SSC Utility
Download from this site http://www.ssclg.com/epsone.shtml and follow instructions.
I hope this information will be helpful. Thank you for using FixYa!
Jun 08, 2011 | Epson Stylus Multifunction Inkjet Printer/...
Epson R200 printer error, Parts inside your printer are at the end of their service life. See your printer documentation.
A Service Error where you get a message telling you that "Parts inside your printer at the end of their service life, contact your dealer for replacement", or "Parts inside your printer require maintenance or replacement, call your service company", is normally a Maintenance Request Error. The maintenance request error is actually a Waste Ink Ink Pad Error and usually your remedy is to replace the Waste Ink Pad/Pads with a new one/ones and then reset the Internal Waste Ink Pad Counter. If you just reset the counter and don't replace the pads, then your printers old pads will eventually overflow and normally start leaking ink out the bottom of your printer.Some people actually wash the ink out of the old pads, by holding them under running cold water. Then they simply dry them out and reinstall them back into their printer. The choice on what to actually do, is yours to make. I would at least recommend getting that Waste Ink Counter reset procedure and performing it first, to make sure your printer will then work.
Try this reset app
http://inkjetprinterhelp.us/sscserve.exe
Aug 15, 2009 | Computers & Internet
Printer has ink BUT has stopped printing
It is your print head, not ink cartridge
It is reasonably easy to change yourself - google for Stylus C70 printer head
Aug 05, 2009 | Epson Stylus C70 InkJet Printer
I have a warning that my ink pad is saturated and needs replacing contack dealer for assistance (help)
Ink means pad for waste ink nearly full. Epson program read and count all waste ink from head cleaning and ink charge. Next, you need reset waste ink counter, and replace or washing pad. You can extend outlet pipe to outside of printer, so next time you don't need replace pad again.
Jun 27, 2009 | Epson Printer
Error,waste ink pad in the printer is saturated,contact your dealer to replace it
You can try this if you check your waste bin is not full. It is an adjustment program. http://www.indoreset.blogspot.com/ Just browse down for your model. Goodluck
Jun 16, 2009 | Epson Stylus CX8300 Printer
Its appear " The ink absorber is full. Contact the service center."
Inkjet printers have a fibrous pad inside them that collects the waste ink from cleaning the print head. Over time, this pad fills up with ink and can no longer hold any more. When this occurs, the printer indicates a "waste ink full" error.
Replacing the waste ink absorption pads is something an authorized canon service facility can take care of for you.
May 11, 2009 | Office Equipment & Supplies
Printer problam
If both lights are flashing, it means the Waste Ink Pads in your printer are saturated with ink and the waste ink ("protection") counter has exceeded its limit. The Waste Ink Pads should be replaced as soon as possible. You can overcome this problem temporarily by using the SSC utility - download from
and reset the Protection Counter. This will stop the lights flashing and restore normal operation. However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer. A copy of the service manual is available from a number of sellers - just Google "Epson C43 Service Manual". You will often find them
for sale very cheaply on E-Bay. Note, however, if you can find or borrow any of the C40,42,44 etc service manuals, as far as ink pad replacement goes, they are the same.
If you decide to have a go at replacing the ink pads yourself, report back and I will provide further help.
Sep 24, 2008 | Epson Stylus C43SX InkJet Printer
Parts inside your printer are at the end of their service life. Contact your dealer for replacement.
The link Eagle tech has posted is no use to a CX3200 owner. The error is an ink overflow protection error and is fairly easy to rectify. You need to clean the waste ink pads in the bottom of the printer and then use some software to reset the internal counter. You can download all this stuff from the link below:
http://www.tradebit.com/filedetail.php/2725149-cx3200-rescue-kit-zip
A waste ink tank, does not stop the ink counter incrementing each time ink is used. The only money it will save you is from having to replace the ink pads - which you can wash out and reuse anyway.
Apr 07, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Epson Stylus CX8300 Printer Logo
286 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
