Question about Boating
MOTOR STARTS FIRST GO RUNS 4OR 5 MINUTES THEN OVERHEATS
    Champion:
    New Friend:
  • 227 Answers
Couple of things can be wrong water pump out busted head gasket thermostats stuck
Posted on Dec 19, 2013
Why does it run for about 15 minutes then shut off for about 15 minutes then come back on then shut off?
because it is making air,it sounds like it is leaking air somewhere,take the hood off and see where its leaking,if its a fitting,undo the fitting and wrap lead solder around it and tighten the nut and run it for 5 minutes let it cool and tighten the nut the rest of the way
Jul 23, 2015 | Air Tools & Compressors
PB4-60 Overheating
if it shuts down then it most likely is a bad motor. If the voltage is properly wired to the motor then the motor is bad. Sometimes new items turn out to be bad out of the box.
Rod
US Parts Center
Jun 25, 2013 | Polaris Pb4 - 60 Booster Pump
How to do 'timer' recording for 4or 5 hours instead of 'title' recording on 922 sling DVR?
bigelow100
The 922 receiver does not have the Time Based feature (Any program in the specified time frame will be recorded, regardless of name). You can setup timers with start early (up to 60 minutes) and end late (up to 90 minutes) for a/all timers. This would give you a 2 1/2 hour window plus the time for the program you want to record. I hope this helps.
Ray Calo
DISH Network
Mar 01, 2011 | Kathrein UFS 922 (250 GB)
My dryer only runs for about 5 minutes then shuts off, as if overheated. You have to wait about 10 minutes before it will start when you push the button, only for it to last only another 5 minutes.
Sounds like you might be causing the thermal overload of the motor to open shutting down the dryer. Try cleaning out all the vents--external to the outside and internal to the dryer. Cleaning out the internal ones will require you to open the dryer up. Be sure the dryer is unplugged before any work is done to its internal workings or the control panel is accesseed. Often times, lint inside the vent or just inside the dryers internal areas can collect near the motor and overheat it. Cleaning this out may aleviate your problem. If this does not work, it may be time to look at a new motor--or dryer replacement. Usually when a motor starts to have internal electrical winding problems there will be a horrible sounding buzz upon start up. Remember, a thermally overloaded motor only has so many restarts before it is done.
Feb 05, 2011 | Maytag Dryers
Turns off after a few minutes
sounds like your motor is overheating or going bad. sometimes lint built up around the motor can cause it to overheat. or the motor is dying.
Aug 31, 2009 | Kenmore 73952 Gas Dryer
DRYERS RUNS FOR ABOUT 5 TO 10 MINUTES THEN STOPS FOR ABOUT 5 MINUTES THEN STARTS BACK UP AND RUNS FOR A 5 TO 10 MINUTES .
sounds like your hi-limit temp switch is getting bad,its located on the heating element case to shut-down the dryer element so it doesn't overheat and cause a fire, they can cause problems
Aug 22, 2009 | Dryers
Roper REX5634KQ0 runs for two minutes in any cycle and then stops
This problem sounds like a bad motor bearing causing the motor to overheat, when the motor overheats there is a thermal protector that opens and the motor will not run until it cools down.
Jan 06, 2009 | Roper REX4634KQ Electric Dryer
Kenmore 90 series gas dryer
possible motor overheat ..if unit has a lot of lint or has had vent problems now or in past lint may have accumilated around motor and caused it to overheat and shut off.. probably to late to save motor
Sep 29, 2008 | Kenmore 73952 Gas Dryer
Bad controller
Try to take the controller out under the driver seat . and unplug and plug it back , if it did not fix the problem.Try to find a used car dealer and replace the small controller it will fix all the problems.
Aug 12, 2008 | 1991 Honda Accord
Boating Logo
24 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
