Question about Haier L32B1120 32 LCD TV
Need screw size for haier l26b1120 pedestal - Haier L32B1120 32 LCD TV
    Top Expert:
  • Haier Master
  • 75,417 Answers
To know about this, you have to download the repair manual to this set by internet. Its disassembly procedure section, will describe you all. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window. Disassembley procedure to some popular models TVs are given with illustrations.
Posted on Oct 11, 2013
Can you tell me what size screws I need to mount my Toshiba Model 46G310U on a wall?
M6 or M8
http://support.toshiba.com/support/search?s_query=mounting+bolts
User Manual
Page 6
... stand. 3) Once you have removed all four screws holding the pedestal stand in place, remove the pedestal stand ..., level, stable surface that can support the weight of the surface. Four screws Hook Sturdy strap (as short as possible) 46 / 55" TV VESA Mounting Pattern 32" TV VESA Mounting Pattern Four screws Hook Sturdy strap (as short as possible) Four screws Hook Sturdy strap (as short as a quilt or blanket. Make ...) 200x200 mm 200x200 mm 400x200 mm 400x200 mm Screw Size M6 M6 M8 M8 (unit in mm) 40" TV VESA Mounting Pattern Removing the Pedestal Stand 1) Carefully lay the front ...
Toshiba 46G310U Mounting Screws
Sep 24, 2017 | Televison & Video
Need the size of the screws in back of the tv to attach to the pedestal.
IF YOU HAVE USERS MANUAL SIZES SHOULD BE IN THERE IF NOT EMAIL LG AT THE ADDRESS FOR YOU COUNTRY OR YOU COULD TRY PHONING .
Dec 26, 2015 | Vizio L32 32 in. LCD HDTV
How i fix my wobbly high chair
If you know someone that has a welder they could weld it . Or if you don't .and can get the pedestal loose from the base you'll see where the break is .I would cut a piece of plywood drill a hole in plywood the size of pedestal push it in plywood stand stool up push down . Till pedestal touches floor take drill .get some 1" self drill/tapping screws commonly called : TEK-screws put 3 screws in the wood at an angle so screws go into the pedestal to hold it tight paint or stain the wood.your handy work.
May 15, 2014 | Furniture
Remove pedistal base from 24h898 aoc envision tv
You need to remove the cover that hides the 4 screws that hold the stand to the monitor. There are 3 pieces to the pedestal base. The base plate, the pedestal, and the screw cover. To remove the screw cover, look on the back where the pedestal attaches to the monitor. There is a cover just above the pedestal. Pinch the top left and top right sides (about one inch from edge) to unclip the cover. Remove the 4 silver screws (2 on each tab) and put them in a ziploc bag to avoid losing them. Tape them to the pedestal/base and cover.
Jan 18, 2014 | AOC 24 Envision L24H898 1080p Widescreen...
Toshiba 40rv5252r stand screw size
I called Toshiba for this TV model "40RV525R" and they said the pedestal stand for the t.v. to stand on was an m5, product # 75012791, and the length was approx 20-25 mm
Feb 11, 2012 | Toshiba 40RV525R 40 in. HDTV
Help with mounting screws on ge pedestal sbsd137hww
Would anyone happen to know the size of the mounting screws for the ge pedestal sbsd137hww
Aug 04, 2011 | Dryers
How do you install whirlpool duet pedestal
Make sure that you get the pedestal designed for your washer. The white pedestal for the GHW9400P would be LAB2700MQ. (There are slight differences in the pedestals for different series washers. The holes in the base of the washer will not line up with the holes in the pedestal for a mismatched combination.)
First if your washer has been installed, uninstall it. You need to turn off the water. Then disconnect the power cord and (carefully) the fill hoses. Loosen the hoses first and then completely remove them. Drain the hoses into a bucket. Disconnect the drain hose from the back of the washer. Use pliers to squeeze the clamp to get the drain hose loose.
Pull the washer away from the wall. Cover the area behind the washer with cardboard and tip the washer onto its back (on the cardboard).
Pull out the drawer of the pedestal. Next snap the spacers into the holes on the top of the pedestal. (These are part of the hardware kit in the drawer of the pedestal.) Remove the shipping spacers from the front of the pedestal (behind the drawer). Remove the Philips head screw from the drawer slides and pull the drawer completely out (save the screws). Push the slides back into the pedestal.
Look at the washer and remove the feet if present. Partially install two of the hex head screws from the pedestal installation kit in the bottom holes of the washer. (These are at the center back of the washer if it is standing up.) Leave the screws about 3/8" from the bottom of the washer. Move the pedestal over to the washer and slide the keyhole openings of the pedestal over the two partially installed screws. Position the pedestal against the top of the washer and insert the remaining two hex head screws. Do not tighten completely.
Align the pedestal with the base of the washer on all sides. When it is lined up, tighten the 4 screws by reaching through the drawer opening of the pedestal. Bring the washer and pedestal back upright. Reinstall the washer (remove the packaging if this was a new install). Level (front to back and side to side) the washer using the pedestal feet (again reach through the drawer opening). Make sure that all 4 feet touch the floor. Tighten all 4 locknuts.
Pull out the drawer slides and reinstall the drawer. Reinstall the Philips screws. Close the drawer.
For pictures of the install, go to the Whirlpool support site http://www.whirlpool.com/owner_center . Search for your pedestal and get the installation manual. The direct link for the LAB2700MQ0 install is http://www.kitchenaid.ca/assets/pdfs/literature/Installation%20Instructions%20-%208537141.pdf .
I hope this helps.
Aug 04, 2011 | Whirlpool GHW9400 Duet Washer
Try to mount TV to the wall and need to release the TV stand
To Display your LCD TV using a Wall Bracket:
If you decide to wall mount your LCD TV, always use a ULlisted wall bracket appropriate for the size and weight of the LCD TV: 32HL37/32HL37U/32HL17/32HL17U: 38.6 lbs (17.5 kg)
37HL17: 46.3 lbs (21.0 kg)
42HL17: 59.5 lbs (27.0 kg)
1) CAUTION: Two people are required for installation.
2) Unplug and remove any cables and/or other component connectors from the rear of the TV.
3) Follow the instructions provided with your wall bracket. Before proceeding, make sure the appropriate bracket(s) are attached to the wall and the back of the TV as described in the instructions provided with the wall bracket.
4) After attaching the appropriate bracket(s) to the wall and the back of the TV, remove the pedestal stand from the TV as described below.
1) Carefully lay the front of the unit face down on a flat, cushioned surface such as a quilt or blanket. Leave the stand protruding over the edge of the surface. Note: Extreme care should always be used when removing the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose the pedestal stand screws. The jack pack cover can be removed without tools.
3) Remove the five screws. This will allow removal of the pedestal stand.
4) Once you have removed all five screws holding the pedestal stand in place, remove the pedestal stand from the TV by sliding the pedestal stand away from the TV.
Sep 28, 2009 | Toshiba REGZA 32WLG66 32 in. Television
Missing pedestal screws for 3000 series 42 inch LCD. model 42PFL3704D
I just received the same TV (Philips 42PFL3704D/F7) in a box...with no screws to mount the pedestal to the TV. What size screws do I need to buy??
Jul 07, 2009 | Philips 42PFL3704D LCD TV
What is the screw hole size in back of tv
The screw holes are metric. The set is supplied with M5x25 screws to attach the pedestal, so the wall mount screws will be in that same range.
Mar 01, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
Haier L32B1120 32 LCD TV Logo
117 people viewed this question
Top Haier Televison & Video Experts
Jaime Hernandez
CoppellTVRepair.com
Are you a Haier Televison and Video Expert? Answer questions, earn points and help others
