Question about Exercise & Fitness
Isuzu box truck warning light icons - Exercise & Fitness
What does the little car light that is on on my 96 iszu rodeo mean it looks like a little car
sorry no photos no joy.
here tell me my light
it looks like
no country (lamps vary by laws in each country)
no engine state.
or if car is stick shift or auto.
hopeless.
is see over 30 little cars here (warnings) endless they are.
http://dashboardsymbols.com/the-symbols/
why not open the glove box and read your operators guide
its there, read it.
under dash warning lamps..
for sure.
or buy one.
or learn to post a photo.
now tell my mine.
its a red ball glowing, no words , no icon...
bet you cant.
Mar 23, 2017 | 1996 Isuzu Rodeo
Is there bulb harness for this model
the cluster (warning lights dead, not parking lights)
is a fuse
marked "METER"
in CB7 dash fuse box.
the operators guide has FUSE chapter, read that yet?
Feb 04, 2015 | 1997 Isuzu Rodeo
What do dashboard lights mean
you meant warning lamps. right? not parking lamps.
every year they add more. my newer car has like 100.
each maker uses different lamps. (icons.)
making generic answers impossible ,except the obvious.
CEL , check engine light, or SES. service engine soon.
Oil lamp... low oil pressure do not run engine.
charge lamp, battery will die soon (go discharged and car stalls)
you lost the operators guide, all lamps are explained in every car made in the glove box manual.
get one.
or use this random page.
this is a grand attempt at the generic, its very good.
mean.
it means what the book says it means.
end story.
alldata.com also has the facts on this car.
Aug 29, 2014 | 1993 Isuzu Trooper
What does warning light "A/T Oil Temp warning light mean
I Would Say It Means Automatic Transmission Fluid Is Hot ,So Check Its Level There should Be a Dip Stick For This If Not Then i Would Think something Is Wrong in The Gear box Or The Gearbox Oil Cooler If Fitted Could be An Integral Part Of The Radiator.
Mar 26, 2013 | 2001 Isuzu Rodeo
Alternator wiring or connection
The two WHT wires from 80A MAIN fuse FL-1 in the fuse/relay box connect to the B (battery) terminal. The BLK/YEL wire from 15A ENGINE fuse C-8 in the dash fuse box connects to the IG (ignition) terminal. The WHT/GRN wire from the charge warning light in the instrument panel connects to the L (light) terminal. Tre is no connection to the C terminal in the 1995 Isuzu Trooper
Dec 06, 2012 | 1995 Isuzu Trooper
Warning light on dashboard of 96 isuzu trooper i have no manual and i don't know what the warning light is for
If the warning light is CHECK ENGINE, take your vehicle to your local Autozone. They will hook a scanner up to it for free and tell you what the code is. If you post the alarm code on this website, you will get a description back of what the potential problems are.
Apr 05, 2011 | 1997 Isuzu Trooper
I have a panel indicater light on
That horseshoe-looking warning icon on your instrument panel is a cross-section of a tire. It indicates that tire pressure is low in one or more wheels. It may also inndicate that one or more tire-pressure sensors in the wheels is faulty (small battery is worn out). The air valves on yoiur rims are equipped with pressure sensors, mounted on the inside of the rim. These sensors send a wireless signal to an on-board sensor that reports low tire pressure or faulty sensor. So, check your tire pressure. It may take a few days for that icon on the dash to extinguish.
Apr 03, 2009 | 2004 Isuzu Rodeo
Fuel, brake, and alternator warning lights stay on.
change the charge light relay (the blue one) located offside front wing fuse box, get off ebay or from millners.co.uk
Mar 07, 2009 | 1987 Isuzu Trooper
Exercise & Fitness Logo
44 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
