Using Roku 3 with HDMI cable to stream to TV, is there a way to get an audio out signal (either from the TV or Roku box) to connect to an analog stereo receiver
    Problem Solver:
  • 9 Answers
Your tv should have a couple different audio out options, but you can not just plug in a wire and make it work. You will have to use your remote to go into your settings on the tv and select an external speaker before it will actually send the signals out.
Posted on Oct 18, 2013
3 Suggested Answers
tgvern
  • 281 Answers
SOURCE: Can't get Roku N1100 to
Make sure you select the correct input for your device. If you are using RCA cables then select the RGB option on your inputs, or it may RCA as a connection. If you are using HDMI then make sure that is selected.
Posted on Dec 10, 2011
bfloydbam
  • 6 Answers
SOURCE: my roku will drop the program while watching a movie
Sounds to me that your Roku is losing signal to the Router or hotspot. Try setting the router at least 5 feet away from the Roku Box and the higher the router is in the house, the better signal for all devices. Wi-fi broadcast down easier than up!
Posted on Jan 31, 2012
Pros And Cons Of Roku
Roku is one of the best streaming devices to stream the videos, movies and TV shows.
Pros of Roku
The Roku offers user interface and Roku app in cheaper packages.
Roku does not require the separate box or HDMI cables to connect the TV from the stick plugs.
It has screen mirroring features that display the screens of the mobile device on you Roku tv.
It has the search function to search the lists of channels from the channel stores.
It provides headphone jack for private listening.
Cons of Roku
For the Network connection, Wifi is the only option
You need HDMI cable for Roku stick because it lacks analog and digital audio outputs.
If you need further more information about the roku products contact the roku customer service team @ +1-844-965-4357 and you may visit https://www.rokuactivationcode.com/
Apr 06, 2017 | Internet Computers & Internet
Setting up with code
You can use Roku Streaming stick to any of the television with HDMI port connection. You can directly connect the Roku Streaming stick to TV HDMI port. In case, your Tv doesn't have the HDMI connection then use HDMI extender cable.
Follow the given steps for setting up the Roku Streaming Stick,
1. Once you connected the Roku streaming stick to your Tv, the first screen will be "Language setting". 2. Scroll down or up to select your preferrence language.
3. Go to settings and select your internet connection name from the list of network.
4. Then enter the network name and password.
Note: Connect the Roku device, TV and smartphone in same network.
5. Once you connected the internet, your streaming stick will automatically download the latest version of software.
6. Create a Roku account by entering Roku code link that displayed on your TV.
Once the above steps are completed, you Roku streaming stick will ready to use. For more information call us at 1-844-965-4357 or visit Roku Activation Code.
Jul 28, 2016 | Roku Streaming Stick
Just hooked up the streaming stick to HDMI to the TV. nothing is showing up, What do I do now?
Sounds like you have a bad connection on either your roku stick or your HDMI PORT.Does you ROKU stick show a white light if not check power cable or electrical plug.
Try wiggling ROKU stick just a hair or push it in and out until you get a signal..A purple screen with the words ROKU should show up on TV.If you have a bad port on TV it would have to be replaced but this is rare,if you have a second port on tv try that.Have you tried your ROKU stick on another tv?Does your streaming stick go in vertically or horizontally,if it goes in vertically it may be pressing against side of tv prohibiting a good connection.You could try a HDMI cable, plug the HDMI cable into tv and put ROKU in other side of cable.There is also a restart button on ROKU stick push it and it will start blinking,if it doesn't light up you may have a defective ROKU stick.
Feb 25, 2016 | Roku Streaming Stick HDMI Version
I have sound but no picture
Check your connections between your Roku box and your TV more than likely you have the audio cables plugged into the wrong jacks, Using a single HDMI cable would eliminate this issue if you have an available HDMI input on your TV. Notice which jacks are the audio output jacks on this pic, make sure these are connected to the input on your TV, the ONLY time you don't use these jacks id if you are using the HDMI connection, they are REQUIRED for composite video, component video (high def color) and S-video.
May 25, 2015 | Roku XD Streaming Player 1080P Wireless-N...
How to connect Roku 3 or do I need Roku 2?
I think it will only work if connected directly to the tv with the correct cable.
Dec 27, 2014 | Pioneer Televison & Video
Why would tv sound work fine but while using roku 2 the sound suddenly stopped working?
If the picture is OK then check your sound cables, red and white if analog, or swap out the HDMI cable with one that you know works.
Also, on the SETTINGS screen make sure your audio is set to stereo not surround sound.
Dec 27, 2014 | Roku 2 XS
WE JUST BOUGHT ROKU , HOOKED IT UP , CAN'T GET ANYTHING ELSE TO COME UP
You must match the TV's input connections and the Roku output on your remote. This means if the Roku's output is connected to your TV's "HDMI 2" (or A/V 2, etc.), you must be able to select HDMI 2 (or A/V 2, etc) on the TV - either with your remote or pressing a button on the TV itself.
Sometimes, the TV will skip over unused inputs when it was first set up. This is done to reduce the number of button presses to go from say "HDMI 1" to "HDMI 4" by programming OUT the HDMI 2 & HDMI 3 choices.
You'll need to program IN the input that your TV uses to connect the Roku if it isn't already available. You MUST connect cables properly if not using HDMI. RGB is Red-Green-Blue and must be connected to RGB jacks at the Roku and TV for a picture and the the White & Red (left and right) audio must connect the the corresponding Red / White audio jacks - or it will provide strange results.
Make sure the power plug is connected to an outlet that is ON and connected to the power jack on the Roku box itself. Unless you have a defective Roku box or TV, it SHOULD work. You can try using a different HDMI or A/V jacks on the TV to determine if it is the TV jacks or not.
Sep 10, 2013 | Televison & Video
Hdmi will not work only use of component cables will.
Hello
The HDMI[1] input on your TV receives digital audio
and uncompressed digital video and audio from an
HDMI device or uncompressed digital video from a
DVI[2] device.
This input is designed to accept HDCP[3] program
material in digital form from EIA/CEA-861/861B-
compliant[4] consumer electronic devices (such as a settop
box or DVD player with HDMI or DVI output).
The HDMI input is designed for best performance
with 1080i high-definition video signals, but will also
accept and display 480i, 480p, and 720p signals.
To connect an HDMI device, you will need:
• one HDMI cable (type A connector)
For proper operation, it is recommended that you use
a short HDMI cable. You should not encounter
difficulty if you use an HDMI cable shorter than 16.4
ft (5m).
HDMI cable transfers both video and audio.
Separate analog audio cables are not required (see
illustration below). Some CDVs (video CDs) may
not output digital audio signals. In that case, you
may hear sound by connecting analog audio cables.
However, if you connect analog audio cables with
this connection, the HDMI terminal on the TV will
not receive the HDMI digital audio signal and you
will hear analog audio only.
To ensure that the HDMI or DVI device is reset
properly, it is recommended that you follow
these procedures:
• When turning on your electronic components,
turn on the TV first, and then the HDMI or
DVI device.
• When turning off your electronic components,
turn off the HDMI or DVI device first, and
then the TV.
To connect a DVI device, you will need:
• one HDMI-to-DVI adapter cable
(HDMI type A connector)
For proper operation, the length of an HDMI-to-
DVI adapter cable should not exceed 9.8 ft (3m).
The recommended length is 6.6 ft (2m).
• one pair of standard analog audio cables
OK
Dec 16, 2010 | Toshiba 30HF84 30" TV
I want to connect the Audio from tv to Surrounding audio system
For connections of audio, so that you can hear all tv audio through the
surround system, connect either an optical audio cable or red & white
analog audio cables from the tv to the home theater. If you are using
optical audio, there is a plug on back of tv labeled for digital audio
output and an input on the surround sound system. If you plan on using
analog red and white, use the PROG OUT red and white output jacks on the
back of the tv to the AUX input on the home theater.
For video connections, to get HD you will need to be using either HDMI or
Component cables. HDMI is the cable that will provided 1080p signal (the
best HD signal), but if the source does not output 1080p, then your tv
will not display 1080p. Most cable boxes output at 1080i or 720p when on
HD stations. This signal still provides great picture quality, but HDMI is
not needed to get these HD signals. You can use component cables for your
cable box and the DVD player output to the tv for video. HDMI might give
you a slightly better picture quality but the signal will be the same.
To make the connection, you will want to connect from the cable box to the
tv (component or hdmi). Also from the home theater system to the tv using
hdmi or the video cables from component (red, blue, & green cables).
We hope this information is helpful to you.
Thank You,
Panasonic Consumer
Dec 16, 2008 | Panasonic Home Theater System System
Televison & Video Logo
98 people viewed this question
Top Televison & Video Experts
Electro Med Services...
