Question about CAD Microphones GXL1200 Professional Microphone
I cant get soung thru audacity
Im on my laptop
How to transfer vinyl to cd-simply-I have manual but very confusing-simple step by step needed-thank you-Al B
The popular recording software known as Audacity is a good choice for getting all sorts of sounds saved in a digital format. The easy-to-use features of this program will help you to create complex musical compositions, or just record incoming audio streams. One of the basic things you can do with Audacity is to record sound from vinyl records. Many people still keep vinyls on hand, though the production of this medium has diminished. Here are the basic steps that will help you to use Audacity to record vinyl.
Steps
  1. Get your phonograph or record player. Assemble your collection of records and make sure that your record player is in good functioning condition.
  2. Use a cable to connect your record player to the computer with Audacity installed on it. In order to record from vinyl, you'll need to make sure you have accurately connected your record player as an incoming audio stream into the microphone jack of your computer.
    • Use hardware adapters to secure your cable connection. Many older record players utilize a 1/4-sized input jack. The modern laptop computer, as well as many desktop models, use a smaller, 1/8-sized input jack. You can buy simple adapters at your local electronics store to fix this problem.
    • Make sure that your cables and adapters support stereo.
  3. Open the Audacity program on your computer. You will see the signature Audacity screen, with controls at the top, and an empty space to accommodate created tracks.
  4. Start playing the record on your record player.
  5. Hit the red circle that represents the "record" button in Audacity.
  6. Observe the sound coming into Audacity. You should see the track being populated with sound, represented by a fluctuating line as the cursor moves along.
  7. Hit "Stop" to stop the recording.
  8. Stop the record player.
  9. Repeat this process with the entire track. Reset the record player, start playing and hit the Audacity "Record" button again, allowing the entire track to populate with the sound of the vinyl record.
  10. Save your project in your desired format. Audacity supports a number of file formats for the finished product. You can select one of these when you have recorded the entire track. Make every song its own track, or simply record the entire side of the record on one track.
Aug 26, 2015 | Audio Players & Recorders
Background noise on vocal track
There is no doubt that sound on PCs and laptops can be a pain, and I have had to run a mixer output through the mic socket before now, such is the insensitivity of the PC's inputs. But you have done this, which implies that the mic input is not being connected to the sound system. You should have some controls of the way the sound is connected - try the Control Panel (assuming you have Windows) and opening up the sound applet. You won't get anything through Audacity etc., until the system is delivering. Sorry I can't be more specific.
Dec 28, 2013 | Computers & Internet
Mic twont turn on
There is no way to directly connect this mic via USB. It requires a phantom power source, through an XLR mic cable.
Oct 11, 2013 | CAD Microphones GXL1200 Professional...
IAM USING ASUS K 53 S. I CANT ABLE TO CONFIGURE THE SOUNG SYSTEM , THE OPTION IS HIDDEN
You can find the sounds in Control Panel, Sounds. or In the Tray Notification Area, right click on the sound icon. Is the sound working? I am not clear about what you need? respond to post for further assistance.
Nov 20, 2012 | ASUS K53SV Notebook
How to extract audio file from blu ray disc?
I am guessing you have a br-reader in your windows machine. You need to channel the blueray audio via a recording app like audacity. Check this video for the steps -
Download audacity from here - http://audacity.sourceforge.net/
Sep 11, 2012 | Dell Inspiron 1525 Laptop Jet Black (15.4"...
When i burn cds i get a static/ crackling soung
If your copying a cd then Im not sure why this is happening but if you are recording sound to your computer through the microphone and then recording I would suggest the microphone, cable, or even the sound jack as the culprit.
Hope that helps....
Oct 17, 2009 | Compaq Presario CQ60-220US PC Laptop
No sound of my acer
go to the device manager and uninstall the sound drivers and restart the system it should work
Jan 17, 2009 | Computers & Internet
CAD Microphones GXL1200 Professional Microphone Logo
35 people viewed this question
Top CAD Microphones Audio Players & Recorders Experts
Ben Armstrong
Vito Vacirca Jr.
Tom Chichester
Are you a CAD Microphones Audio Player and Recorder Expert? Answer questions, earn points and help others
