Question about Galaxy 5000RS 5000RS-DBP Car Alarm
After setting remote start ,if d door is opened or alarm triggered it would not remote start again unless you redo the setup of remote start . eg. with engine running put park brake on take foot off break then press start button until light blinks turn car off engine remains on until door closed then ready to do remote start
  • 112 Answers
I assume your vehicle is a standard transmission ?
Posted on Nov 07, 2013
2002 explorer anti-theft system activates while I'm in house (static). Might anyone have a probable cause ?
The "Proper" way is to use a scan tool with access to body body theft data. Usually alarm events set a code identifying which trigger set the alarm. "IE - B1234 Left Rear Door Alarm trigger Activation.
Since Most people dont HAVE an IDS or NGS or SnapOn...
You can try activating the alarm. all doors closed with windows down. wait 5 minutes. physically grab the top of each door panel thru the open window and shake the door hard like you were trying to pull it open. If its a marginal switch (usually is) the one thats borderline will trigger "open" with minor shaking and the good ones will show fully closed unless the door is in fact fully opened. If the shake test triggers the alarm on 1 door, then you know its either the pin switch (if it has one, not all do) or the door latch out of adjustment or defective.
Nov 12, 2015 | Cars & Trucks
Viper 479V Viper Responder Remote how to program
open the door, turn the key on, press valet switch one time and press it again and hold it until alarm beeps if it dosent beep it means that alarm hasn't read the door open if it beeps press lock on the remote and it should beep again and its will be set. (if the alarm dosent beep you have to put the door trigger wire (green) to ground and repeat steps from beggining
Apr 02, 2014 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
HOW TO PROGRAM VIPER 479/V/P/X
Open the door, turn the key on, press valet switch one time and press it again and hold it until alarm beeps if it dosent beep it means that alarm hasn't read the door open if it beeps press lock on the remote and it should beep again and its will be set. (if the alarm dosent beep you have to put the door trigger wire (green) to ground and repeat steps from beggining
Apr 01, 2014 | Viper Vehicle Parts & Accessories
How to program 473v remote
Sep 16, 2013 | 5101 LE 1 Way Car Remote Starter System
I am getting a second alarm when the first lock alarm is pressed in my wingroad car and when you open the doors the alarm is not coming on
If you open the doors when the alarm is armed and, the alarm does not trigger then, you have the wrong door trigger wire connected. If you were to list the year, make and model of the vehicle I could direct you to the proper wire and location.
Jun 28, 2013 | 5601 1Way SuperCode Security and Remote...
Car alarm goes off 30 seconds after disarm and open a door
Apparently the alarm is set to passive arming and, once you disarm it, it immediately begins the arming process and it is not registering the door being open. I'm going to go out on a limb and say that the alarm door trigger is wired to the dome light and the dome light is turned off; an issue that occurs with GM vehicles that have a dome light override switch. What's the year, make and model of the vehicle?
Sep 02, 2012 | AviStart 4400 2-Way Security / Remote...
Mts mode for preset manual trans auto start function enable,does not allow car to start, instead the park light blinks seven times and give an error tone ... Thank you
There is a sequence necessary to set the Viper every time you exit the vehicle: park the vehicle, put in neutral, place foot on brake, set parking brake,remove foot from brake, remote start vehicle with remote, remove key (vehicle should remain running), exit vehicle and close door, arm the alarm with remote (vehicle should shut down). The system is now set for MTS remote start. Test the system by remote starting the vehicle now (it should remote start at this point). If you open any door after the MTS remote start has been set, you will have to do the programming sequence again.This is a safety feature because something may have changed, i.e. parking brake released when the door was opened. You have to do this sequence each time you park the vehicle if you intend to use the remote start feature.
If this does not work, there may be an issue with the installation, i.e., the door trigger connection. Using dome supervision as a door trigger won't work because during the arming portion of the above mention programming sequence(when the vehicle shuts down), the interior lights will illuminate and the Viper will read it as a door opening. So, actual door trigger wires must be used.
Oct 23, 2010 | 5900 SST 2-Way Security System / Remote...
I work for a garage and we have a 1998 mystique that wont start we were wondering if there was some sort of anti-theft systeme that we dont know about and also we would like to have the were abouts of the...
Starting System
The function of the starting system is to crank the engine at a speed fast enough to allow the engine to start. Heavy cables, connectors and switches are used in the system because of the large currents required.
The starting system consists of a gear reduced starter motor, battery, remote control switch (ignition switch) and relay.
Vehicles equipped with automatic transaxle have a transmission range sensor attached to the circuit which prevents operation of the starter motor unless NEUTRAL or PARK are selected.
Vehicles equipped with a manual transaxle have a start inhibit switch in the starter control circuit, which prevents operation of the starter motor unless the clutch pedal is in the applied position.
The anti - theft protection system provides protection from unauthorized entry into the passenger compartment.
The system is controlled by an anti - theft alarm control. When armed, unauthorized entry into the vehicle is detected by lamp switches.
Once triggered, the system flashes the headlamps, the parking lamps, the alarm indicator, and sounds the horn. In addition, the starter circuit is disabled to prevent starting the vehicle until the system is disarmed.
System Arming
The system will be armed by the remote entry transmitter when the following input sequence is followed:
  1. Turn the ignition switch off and remove the key.
  1. Close all doors (unlocked).
  1. Press the LOCK button on a transmitter to lock doors. Alarm warning lamp will turn on.
  1. Wait for the anti - theft warning lamp to turn off.
The system will also be armed when the following input sequence is followed:
  1. Open a door. Alarm warning lamp will flash.
  1. Lock doors with power door switches. Alarm warning lamp will now glow steadily.
  1. Close all doors.
Opening any door will activate the alarm after the alarm is armed.
Disarming an Untriggered System
The system can be disarmed by performing one of the following procedures.
  • Driver or RH front door is unlocked with a key.
  • Driver door is unlocked by pressing the UNLOCK button of a remote entry transmitter.
  • If remaining in the vehicle, turn the ignition switch to ON or ACC position.
System Triggering
The armed alarm system will be triggered if any door is opened without using a key or a remote entry transmitter to unlock the door first.
Disarming a Triggered System
Carry out either of the following steps will disarm the triggered alarm system.
Two minutes and 45 seconds after the system has been triggered, the horns and exterior lamps will shut off automatically. The system will then reset to an armed state and will trigger again if another intrusion occurs.
Passive Anti-Theft System (PATS)
The Passive Anti-Theft System (PATS), known as SecuriLock, is fully passive in operation and requires no special procedures by the driver to arm or disarm the system. It is invisible to normal scrutiny and is operated by a transponder within the key body. This communicates with the module through a transceiver mounted around the ignition switch lock barrel.
The PATS functionality is incorporated within the powertrain control module.
PATS keys contain an electronic device inside, and are physically larger than a non-PATS key.
The transponder code reading is carried out when the key is inserted into the ignition lock barrel, and turned from position 0' to position II' or III' to crank the engine. If the PCM receives the correct code signal, the engine will start. Should the code received not be recognized, the engine will not crank as the PATS is still armed and the engine immobilized.
Anti-Theft Indicator
Whenever the ignition is switched on the anti-theft indicator will remain on for three seconds while the system carries out an initial ignition key-read.
The anti-theft indicator will flash rapidly for three seconds to indicate the PATS has immobilized the vehicle.
For additional information on the PATS fault codes, refer to the Diagnosis and Testing section.
Aug 12, 2010 | 1998 Mercury Mystique
VEHICLE WONT START
Section 13-11: Anti-Theft System, Active 1998 Windstar Workshop Manual DESCRIPTION AND OPERATION Anti-Theft Alarm System NOTE: The system immediately monitors the ignition key lock cylinder upon removal of the key from the ignition. It is not necessary to arm the system for ignition key lock monitoring.
The anti-theft alarm system:
  • protects the vehicle from unauthorized entry into the passenger compartment, engine compartment and cargo area.
  • monitors the status of the ignition key lock cylinder.
  • is controlled by a remote anti-theft personality (RAP) module. The remote anti-theft personality module also controls the electronic door lock functions. Refer to Section 01-14B for more details.
  • when armed, detects unauthorized entry into the passenger compartment by using an input from the GEM module regarding the state of the door or liftgate (open or closed).
  • protects the engine compartment with a hood switch which is located on the LH cowl vent panel and is part of windshield wiper motor wiring (17A477) .
  • triggers an alarm if the ignition lock cylinder is forcibly removed from the steering column.
Once triggered, the system responds by:
  • flashing the low beam headlamps, the parklamps, rear lamps and the alarm indicator warning light emitting diode (LED).
  • sounding the horn (13832).
  • disabling the starter circuit until the system is disarmed.
Remote Anti-Theft Personality Module
  • The remote anti-theft personality module is located behind the instrument panel (04320).
  • It contains a radio receiver that receives the RF signal from the keyless entry remote transmitter (15K601) through the alarm and lock system antenna (15603) and sends the appropriate command to the power door locks, the horn relay, or the generic electronic module.
  • The remote anti-theft personality module is equipped with an internal backup power supply which holds the programmed code in memory in the event the vehicle battery is disconnected.
Remote Anti-Theft Personality Module Removal
  1. Disconnect battery ground cable (14301). Refer to Section 14-01 .
  1. Remove radio. Refer to Section 15-01 .
  1. Remove lower instrument panel center finish panel. Refer to Section 01-12 .
  1. Lower glove box.
  1. Remove two remote anti-theft personality module bracket retaining screws.
  1. Disconnect electrical connectors and alarm and lock system antenna (15603).
  1. Remove remote anti-theft personality module and bracket.
  1. Remove remote anti-theft personality module from mounting bracket.
Installation
  1. To install, follow removal procedure in reverse order.
  1. Tighten remote anti-theft personality module bracket retaining screws to 6-8 Nm (54-70 lb-in).
Components The system is composed of the following components:
  • remote anti-theft personality (RAP) module with integral antenna
  • alarm indicator LED
  • door lock cylinder switch RH, door lock cylinder switch LH
  • liftgate door lock cylinder switch (220A40)
  • hood switch (part of windshield wiper motor wiring (17A477))
  • ignition lock anti-theft switch (19A438)
The following vehicle components are also used by the anti-theft alarm system:
  • generic electronic module
  • power door lock switch (14028)
  • door open warning lamp switch (14018)
  • autolamp relay (14N089)
  • horn relay and bracket (13853) and horn (13832)
  • low beam headlamps
  • rear lamps (13404) and parking lamps (13200)
  • starter relay
  • door lock relays
  • keyless entry remote transmitter (15K601)
Disarming an Untriggered System NOTE: A perimeter alarm will "shut off" after 165 seconds, but the system is still triggered and is not disarmed.
An armed but untriggered perimeter anti-theft system can be disarmed by one of the following four events:
  1. Unlock the doors by pressing the keyless entry remote transmitter (15K601) UNLOCK button once.
  2. Unlock any door with a key.
  3. Turn ignition switch to RUN or ACC.
  4. The remote entry PANIC button will disarm the anti-theft system only when the perimeter alarm is triggered and sounding.
System Triggering NOTE: Although the remote entry PANIC alarm is not associated with the monitoring of the vehicle, the user will frequently say that the theft system was triggered when actually the keyless entry remote transmitter PANIC button was inadvertently pressed. A panic alarm will not flash the THEFT indicator.
The alarm can be triggered by the following events if the system has been armed and has not been disarmed first:
  • Open any door or liftgate.
  • Open the hood (16612) (if the hood was open when the system was armed, it must be closed before it can trigger the alarm).
  • Dislodge the ignition key lock cylinder.
  • The anti-theft system may be triggered inadvertently when the module is disconnected and then reconnected. To avoid inadvertent alarm triggering, disconnect the smaller 22-way connector first.
When the system is triggered the perimeter alarm will operate as follows: The remote anti-theft personality module will pulse the following outputs at approximately 1.3 Hz, 50 percent duty cycle for two minutes 45 seconds for North America. NOTE: Other perimeter alarms can be programmed for the system.
  • parking lamps
  • horn
  • THEFT indicator
The perimeter alarm can be retriggered, after a perimeter alarm has sounded for 165 seconds. After a perimeter alarm has timed out, if any trigger input is first seen as normal and is then seen in its trigger state, the perimeter alarm will be retriggered. The perimeter alarm can be triggered a total of three times between an arming sequence and a disarm event. An active panic alarm will be deactivated when a perimeter alarm is triggered (a perimeter alarm overrides a panic alarm).
Mar 02, 2009 | 1998 Ford Windstar
Viper 5701 2 way alarm and remote start
Most ford need the door triggers double diode isolated. When the GEM module goes to "sleep" it will set of your alarm . Cut the factory wires where you hooked up the door triggers determine which side goes to the door and which side goes to the GEM module. If it is a negative trigger solder in a 3amp diode with stripe towards the door then solder the door trigger from the alarm to the door side of the diode. Repeat for all door triggers.
Dec 18, 2008 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Galaxy 5000RS 5000RS-DBP Car Alarm Logo
56 people viewed this question
Top Scytek Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Scytek Vehicle Part and Accessory Expert? Answer questions, earn points and help others
