Question about Electrolux ICON Designer E30SO75ESS Oven
Thermador error code f23 - Electrolux ICON Designer E30SO75ESS Oven
Errorcode f23? WHAT IS WRONG.
The F-code usually relate to the gate closing or locking.
[PDF]SERVICE DATA SHEET 318127067 (1010) Rev. C
ftp://ftp.electrolux-na.com/prodinfo_pdf/lassomption/318127067.pdf
1) if the oven controller displays an F15 error code and the ESEC controller ... F23 The controller failed to communicate with the convection fan and oven lights
Aug 17, 2015 | Ovens
Why do I have error code F25 on my Thermador oven error codes
clean the touchpad control panel. Make sure the oven door closes properly to prevent excessive heating of the touchpad. If these don't resolve it, it calls for a replacement of BOTH the touchpad AND the relay board. EXPENSIVE!
Aug 23, 2014 | Thermador SC272T Electric Double Oven
Flashing F33 error code thermador double oven
either a bad oven sensor or a bad power relay board.
Feb 10, 2014 | Thermador SC272T Electric Double Oven
We cleaned my kenmore elite oven. now it won't work. when i try and turn it on i get an F23 error. do you know how to get the oven/stove working again?
Error code F 23 indicates the control detected a problem with the communication link or can be generated as a result of irregularities in the power supply or usage.
  • The error code F23 can often be resolved by removing power to the appliance for a minute and then restoring the power.
  • By unplugging the appliance it allows the control to receive a fresh supply of power. This in turn will clear the controls memory of any irregularities it may have received from the power supply. Once refreshed the error should no longer be displayed.
  1. Unplug the unit or turn the circuit breaker off for 60 seconds.
  2. Restore the power to the appliance by plugging it back in or turning the circuit breaker back on.
  3. Check to see if the error code is still displayed on the range.
  4. Run the appliance in the cycle that initially caused the error or attempt to turn on broiler.
If the error code is displayed, then service is needed. The unit should be inspected by a qualified appliance repair technician.
Should you choose to use Sears, the number to schedule a repair tech is: Sears Repair Department 1-800-469-4663.
Nov 23, 2010 | Kenmore Ovens
What is error code F34 on the thermadore built in double oven
If your Thermador was manufactured between 2004 and 2007, this may be due to a recall issue. I kept getting this error on my Thermador wall oven when I would run the self-cleaning feature, and when heating it over 375 degrees. After doing some research, I discovered that my oven was recalled. Apparently there are gaps in the insulation which could cause a fire. You can find out more on the Thermador website: http://www.thermador.com/safety-notices/7_oven-safety-recall-notice-expanded
Oct 15, 2010 | Ovens
We have an Gaggenau eb 290 oven and the error code F23 shows up - what does this mean? how can we fix it?
F23-relay electronics not selecting. There is either a fault with the pcb or a loss of continuity within the ribbon cable. Unfortunately, I think you are going to need an expert to look at this to confirm.
Sorry I cannot be of more assistance but some faults do require a physical check from a professional and cannot always be sorted out from a distance.
All the best.
May 13, 2010 | Gaggenau EB290 Electric Single Oven
Kenmore Elite slide in range model # C790-440732 keeps displaying error code F23 and oven will not work except on broil
I have the same problem with my Kenmore F23 code will not bake but the broil works?? What the heck?
Feb 07, 2010 | Kenmore Ovens
My thermador oven tells me error code 14
Sometimes you can unplug the unit for at least 30 minutes and reset the unit and it wont do it again.Try that first. An error code on a thermador of 14 means latch switch problems.
May 12, 2009 | Thermador SMW272 Electric Double Oven
Thermador Built-in oven model cm301
Same issue w/our Thermador CM301. F23 and F24 codes - BSH acts like they have never heard of the problem! Awful service. This should be reported to the Consumer Board.
Feb 19, 2008 | Thermador SC302T Electric Double Oven
Electrolux Wall oven E30EW75ESS
Same F23. Resetting the beaker seems to fixed it. Thanks to all
May 27, 2007 | Electrolux ICON Designer E30SO75ESS Oven
Electrolux ICON  Designer E30SO75ESS Oven Logo
Top Electrolux Ovens Experts
ashburton
Mack Baxter
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
