Question about Toshiba Computers & Internet
When i turn laptop on it comes up with the letter j at the top right corner of the screen and wont go any further
    Sergeant:
  • 324 Answers
Disconnect ALL external devices from the laptop - also check if there is a cd in the driver remove and try to power on the laptop
Posted on Oct 17, 2013
  • 624 Answers
SOURCE: acer 3003lci laptop
From what you describe its likely cause is the connector from the LCD panel to the electronics has oxidation or a loose connection. Sometimes if you?re lucky the flexing test might even fix the problem, but apparently not in your case. What you will have to is either take it apart to find out exactly what is going on or take it to the local authorized repair shop. Your laptop is a relatively new design so I would check to make sure the manufacturers warranty is not in effect before I tried either one of those options. Let us know if you have any more questions and please don?t forget to rate this post.
Posted on Apr 13, 2007
  • 53 Answers
SOURCE: hi i have an acer
you need to turn off the num lock feature. do so by pressing and holding down the FN key then pressing the numlk key just once.
to turn it back on just repet the step above.
Posted on Nov 06, 2008
  • 928 Answers
SOURCE: Suspected Hardware problem
Most probably your HDD is all messed up. Try opening the Windows in safe mode, you can do this by pressing the f8 key while booting, if it doesn't work, you need to reformat your computer.
Posted on Oct 11, 2009
  • 2340 Answers
SOURCE: I dropped my laptop on
You can either replace the screen or you can work on your laptop with a broken screen. Replacing the laptop screen is quite costly depending on your laptop model and availability of your parts.
Posted on Jul 27, 2010
  • 8909 Answers
SOURCE: I turn the laptop on....at
Remove any disc in the DVD player and any Lan connection plus ensure the USB sockets are empty. Reboot and it should be fine.
Posted on Feb 26, 2011
Garmin nuvi 1200 wont let me type the right letters
Try recalibrating the touchscreen. The procedure can be found here:
http://www.sharc.net/discus/messages/6/77.html?1315261162
Turn off the Nuvi. Place your finger on the upper left-hand corner of the screen and then push down on the power button to turn the unit on. Release the power button when the Garmin logo appears. Continue to press on the upper left-hand corner of the screen until you see the calibration screen.
Press each dot to recalibrate the screen.
Once completed the Nuvi will display Calibration Complete
Feb 28, 2013 | Garmin nuvi 1200 Car GPS Receiver
Can't get past lock code
Laptop computers have the advantage being portable and self-contained, but among their drawbacks is a keyboard without a separate number keypad. While for most applications number keypads are unnecessary, they can be useful for data entry. Laptops sometimes provide a number keypad by giving certain keys double duty, allowing them to enter numbers rather than letters when a "Number Lock" setting is turned on. Number Lock, however, can get turned on accidentally, or enabled by an operating system by default, which can really mess up your typing. If typing "M" ends up displaying a "0" on your screen, Number Lock is probably the problem.
Try to locate the function key. On a T-series ThinkPad, it's in the lower left hand corner. It should be labeled "Fn," and the lettering may be blue, green or red instead of white. If your laptop lacks a "Fn" key, use the "Shift" key for Step 3 below instead. Locate the key labeled with "NmLk". On a T-series ThinkPad it shares a key with "ScrLk" which sits on the very top row between the "PrtSc" and "Pause" keys. On other IBM laptops, the "NmLk" key might share a key with "Delete." While holding down the "Fn" key or the "Shift" key, depending on your model, press the "NmLk" key. This should turn off Number Lock and restore your keyboard to its usual state. Number Lock on an IBM laptop is a "toggle" setting. You can turn Number Lock on by following the same steps.
b>
Feb 05, 2013 | IBM ThinkPad Computers & Internet
Mio moov 300 screen alignment problem
Download the user manual online and look for factory resettings. Follow instructions and it should work. On my Garmin, the same thing happened. On Garmin, you turn the unit off, press and hold the top left corner of your screen, and turn the unit on while pressing the top left corner of the screen. You wait for 10 seconds and a black dot appears and requests you touch it. The dot moves around the screen and you keep touching it. Once done, your screen perimeter is identified and all the letters fall in place when you press them. Good luck!
Dec 02, 2012 | SNK Mio Moov 300 GPS Receiver
Hi, My Dell Studio 1735 Laptop doesnot display anything, i hear sounds of it getting rebooted and startedup but, wont display anything. I tried conencting to external monitor NO...
The video card most likely has failed. The computer will need to be serviced by a trained technician. The entire motherboard will need to be replaced.
Feb 28, 2011 | Dell STUDIO 1735 Motherboard - H274K
When I turn on my ps3 slim it goes on to what user you want, I press it and it wont load up all the settings. In the top right hand corner it just says loading and wont go any further.
Try Safe Mode.
SAFE MODE:
1. Place you finger on the on/off sensor leave it their until you console turns off then take you finger off the sensor.
2. Place your finger back on the on/off sensor leave it their until you hear 2 consecutive beeps then take your finger off.
3. Once the safe mode screen comes on select the option PS3 SYSTEM RESTORE.
NOTE: A PS3 system restore will delete all data except the OS. I recommend backing up your console onto a USB flash drive if possible.
Good Luck!
Feb 25, 2011 | Video Game Consoles & Games
When I turn my laptop on it comes up with a single line in the top left hand corner. What can it be
Does it not go further than that? Does the OS load?
If not are you able to access the BIOS page? Accessable by usually pressing "del" or F2 on the splash screen on start-up.
Jan 09, 2011 | Computers & Internet
I have a re-built garmin 265WT. There are two arrows at the top right corner of the screen. When I push the arrow that points to the left, the number or letter moves to the left. When I puch the arrow to...
Try recalibrating your touch screen. if that does not work make sure and rule out pressure damage to specific section of screen. if it turns out to be physical damage to screen or device that recognizes touch. call Garmin for further solutions.
Garmin customer service number: (800) 800-1020
Oct 13, 2010 | GPS
Screen minimizes when using the touch pad
If you touch the top right corner of the touchpad, it restores down the window you are currently in. The bottom right corner of the touchpad minimizes the window you are currently in. The bottom left corner of the touch pad brings up the start menu.
Nov 05, 2007 | Toshiba Satellite A135-S4427 Notebook
'F' displaying on screen and remote not responding.
Excavated with Google from Philips website: " When a letter F appears on the right hand corner of the screen it means the television is in factory mode. To exit from factory mode, press the 'VOLUME -' and ?CHANNEL -? buttons on the TV set simultaneous for 5 seconds. " Hope this helps Michael Junge
Aug 04, 2007 | Philips 42PF5521D 42 in. HD-Ready Plasma...
Computers & Internet Logo
16 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
