Question about Xerox WorkCentre XD100 All-In-One Laser Printer
SCANNER ERROR i have formatted my machine then installed all the driver of printer but except scanner everything is working fine while scanning it gives the msg "cannot communicate with scanner.Cable may be disconnected or scanner may be turned off.Checked Status.Scanner driver will be closed.
  • promod Sep 24, 2007
  • 167 Answers
Generally all in one devices have problem with drivers!!! The main problem is communication between computer and printer!! Try to find another driver or reinstall the old ones!!!
Posted on Jan 25, 2008
SOURCE:
Hi. I bought an Epson Stylus TX210 printer not to long ago, and it was working fine. Everything except the scanner. so, my parents and I were trying to fix it and I'm not sure what we did wrong because...
im not sure what i'm and doesn't means
the drivers for the scanner might have been corrupted
you might have to uninstall the printer/scanner restart your computer then reinstall the printer/scanner and its drivers
click start control panel administrive tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you might see a yellow?question mark this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options you can troubleshoot
hope this helps
Apr 17, 2011 | Computers & Internet
I have upgraded my system Os from XP SP3 to Windows 7, after that when I installed Epson Stylus CX2800, everything was working fine except Scan program
Get a windows 7 driver for the printer or an update from epson, un-install the old one then reinstall the upgraded software.It did the same with my Lexmark,but I did get the newer driver from Lexmark and it worked out fine.
Dec 05, 2010 | Epson Stylus Multifunction Inkjet Printer/...
My HP C4480 scanner only returns a black image (on
Did you repaired old drivers? if so first uninstall your products drivers and also its folders from program files, then uninstall "wrong update" and reinstall scanner. sometimes built in scanning modules comes wrong but everything works with original scanning software, use different software to scan and some of them may work perfectlly.
Feb 20, 2010 | HP PhotoSmart C4480 All-in-One Printer ...
HP L7650 Scanner Could Not Be Initialized in Leopard (Not Found)
If you're using Vista, this happens all too regularly with HP printers. I've had a few where I have to uninstall everything then re-install to make things work.
Two weeks later the same thing, same process.
Try downloading latest drivers from HP and see if that helps. HP don't admit there's a problem.
Don't seem to have this problem with Epson printers tho.
Oct 02, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Will not scan
you will have to uninstall the scanner drivers from the computer in the control
panel>scanners..then uninstall the printer drivers from the printer in the control
panel and then run the wireless setup wizard on the printer then try reinstalling the
drivers and the s/w using the disc that came with the printer......see if works
May 16, 2009 | HP Photosmart C7280 Printer
Can't scan
Any idea what MSI error message you had? HP has a product page for the PSC 1315. Click here to go to the product page. Once you're on the product page, you can search for MSI and you'll get a number of pages to choose from. You need to know the specific error message to choose the right one. HOWEVER, those errors mostly look like ones you'd see while installing.
If you didn't see those errors when you were installing, you might try to uninstall and reinstall your software/drivers. The drivers HP has for download are newer than the drivers that were on the CD when you bought the printer. The newer drivers are available here.
Sep 16, 2008 | HP PSC 1315 All-In-One InkJet Printer
I can't get the scanner to work on my mp160. The printer and copier work fine.
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
prirweto-i-13
Feb 25, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Scanner error
hi,
528
Sep 24, 2007 | Canon PIXMA MP160 All-In-One InkJet...
Xerox WorkCentre XD100 All-In-One Laser Printer Logo
248 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Clive
Clive
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
