Question about Pool & Spa
How to turn my Pentair 35gm on to automatic thank you
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,448 Answers
Turn on and set temp to what you want if you have a system use the system to govern heat if doesnt work need more info
Posted on May 08, 2014
The spa switches on automatically
is this heater on an ez touch panel ,if so check the setting....
check the membrane pad on the heater also
Jul 07, 2014 | Pentair Mastertemp Heater
Pentair front wheels not turning
make sure the inside of the wheels arent stripped they are gears if loose take apart adjust out so they touch the other gear that should fix that if gears are stripped you can change the front wheels to the back
Oct 19, 2013 | Pentair White/Gray Legend Platinum...
Is there a reset button on a Pentair Dynamo pump?
No.
there is no reset button, that you can manually press to reset it. There is an internal "thermal overload switch", which is an automatic reset. So if your pump motor is overheating, it will turn off, but once it cools down enough, it will reset automatically.
some styles of the Dynamo, have a toggle switch at the back underneath, which is simply an on and off switch.
Sep 02, 2013 | Pentair Wf 6 1.5hp Whisperflo Inground...
Pentair legend front wheel does not turn
remove cover and adjust wheels to gear or if stripped switch front to back
Jul 07, 2012 | Pentair White/Gray Legend Platinum...
Pentair pool cleaner won't stay locked in
bad in-wall fitting see if tabs ore off if broken replace if cannot get out of wall turn off pump put fitting in wall and then try with channel locks to remove
Apr 02, 2012 | Pentair White/Gray Legend Platinum...
Pentair Legend Platinum Falls on it's Side
This condition often is due to bag being heavy with sediment or the ballast float on head has water in it. Try removing the head float and listen fot the sound of water while shaking it. If audible, replace float.
Apr 19, 2009 | Pentair White/Gray Legend Platinum...
Pool & Spa Logo
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
