Question about Compaq Computers & Internet
Turn off num lock
I can't find the num lock and when my keyboard is locked i don't know what to do without having to shutdown my computer and restart it.
  • 59 Answers
On the keyboard is a symbol called Fn inthe lower left corner usualy. u need 2 press and hold Fn+NumLock button(usually upper right side of keyboard.)this buttons have other colors...Fn activates the functions whit those colors!if problem doesn't solves, write exact model of laptop
Posted on Oct 28, 2013
moz205
  • 80 Answers
SOURCE: Keyboard inoperative
press and hold fn and press f11.it sounds like you activated the sticky keys
Posted on Dec 22, 2007
  • 242 Answers
SOURCE: can't get num lock to work on Dell Inspiron 6400
The 5th key from the right on the top row of your keyboard should is the Num Lock Key...
Posted on Dec 12, 2008
bob_computer
  • 3153 Answers
SOURCE: the keyboard has a keypad, but when y turn on the
Sorry but you found what is NORMAL for laptops. this is not a bug, error, fault, etc.
It does exactly what it is supposed to do even though it may have a proper number pad too. leave num lock off
Posted on Aug 09, 2009
  • 44 Answers
SOURCE: num lock activated and can't turn it off
One of your Function keys (F11, F12, etc., usually F11) will also have the NumLock function on them. So when you hold Fn and press F11, it will toggle the Number Lock. Try holding Fn and press F11, this should turn it off (and back on should you ever want to use it again). Your keyboard should be labeled with the various functions keys have when Fn is pressed, you may have to look for the one that reads NumLk.
Posted on Sep 09, 2009
SOURCE: Computer is locked in the green symbols of the keyboard
TO SHUT OFF the green keys, you need to disable the multiligual or French keyboard layouts. For Windows 7:
Click CONTROL PANEL
click CLOCK, LANGUAGE, AND REGION
under REGION AND LANGUAGE
click CHANGE KEYBOARDS... etc.
click KEYBOARDS AND LANGUAGES
.......for example, by clicking on a keyboard name (ie. US or and UNITED KINGDOM for example) and then clicking PROPERTIES to the rtight, you can see the actual key layout.......
On the list of installed languages, click anything multiligual or French, and then click REMOVE found on the right-hand column
click APPLY
click OK
Then you've removed the French.
Otherwise you have to click the LEFT ALT key and then the LEFT SHIFT key to swich back and forth between the green keys and the white keys.
Posted on Mar 31, 2010
Dell dimension 2350 num lock wont turn off
I think it's the USB port problem.. try unplugging the keyboard plug and plug it to another port.. and you can also try restarting your computer.. if problem still occur, your keyboard probably malfunctioned
Dec 13, 2013 | Dell Dimension 2350 PC Desktop
Disable num lock
Deskop or Laptop seems to be a contradiction >????
The num lock (number or numeric lock) can become annoying if you tend to accidentally hit the num lock key on your laptop and turn it on or off.
Disabling the num lock completely involves editing the system registry.
Before performing such edits, always save and back up your computer information in case you make a mistake, as the system registry controls many aspects of your computer's operation.
Once you have disabled the num lock on your laptop, you must edit the system registry again to re-enable that function.
Close all windows and programs that are running on your computer.
Press the "Windows" key and the "R" key simultaneously to open the "Run" dialog box.
Type "regedit" without the quotation marks, then press "Enter."
Click the "+" symbol next to HKEY_CURRENT_USER, then select the "+" symbol next to "Control Panel."
Click on "Keyboard."
Double-click "IntitialKeyboardIndicators."
Enter "0" (the number zero) in the "Value Data" field to disable the num lock after logon, or enter "1" (the number one) to disable the num lock entirely.
Click "OK," then close the registry by clicking the "X" in the upper right corner of the registry window.
Restart your computer.
To re-enable num lock, follow the same process, but change the "Value Data" to "2."
http://www.softwarehowtos.com/article-how-to-disable-or-enable-the-num-lock-key-at-startup-1244448193.html
Oct 09, 2013 | Dell Vostro 1510 Laptop Computer PC...
My numeral key are not working[123456789 right side of key bord]
Step 1:
On some laptops it may be difficult to locate and activate the "Num Lock" key. Depending on the laptop, it may be hidden as a function where you have to press two keys. Most of the time, a laptop keyboard is just like a full desktop computer keyboard and it has a "Num Lock" key on it. Most people do not realize the "Num Lock" key is on their laptop keyboard because it barely serves a purpose without a full numeric keypad.
Press the "Num Lock" key on the laptop at the top, right of the keyboard. Press the "Num Lock" key and the "Fn" key simultaneously if the above does not work. Press "Fn" and "F11" simultaneously on the keyboard to activate the "Num Lock" function. Some laptops, like Toshiba, do have a "Num Lock" key. The shortcut for G3 Mac laptops it is "F5," and on G4 Mac laptops it is "F6."
Feb 07, 2013 | Computers & Internet
I cleaned my keyboard while turned on and now I cannot get my number pad to work, which buttons did I accidentally push to get to turn off and how can I get them back on.
Based on your description of the problem you're experiencing, it sounds like you most likely pressed the "NUM LOCK" key. If NUM LOCK was activated before you cleaned the keyboard and was accidentally pressed during cleaning, this key press would deactivate NUM LOCK, causing the number pad to stop responding. To reverse this, simply press NUM LOCK again. The NUM LOCK button is located right above the "7" key on the number pad (see picture below).
Alternatively, since the setting determining whether NUM LOCK is activated when your computer is started is stored on your hard drive, you can try restarting the computer to revert back to an active NUM LOCK. Be sure to try this in case the first solution above does not work.
If you found this solution helpful, please leave a positive rating!
Sep 06, 2011 | Maxi Switch Silitek SK 6000 Keyboard
CAPs lock key is on al the time
When you start your PC, Num Lock, Scroll Lock, and Caps Lock don’t automatically toggle on. You can automatically turn each of them on or off whenever your PC starts, for all accounts on the PC. As a practical matter, most people probably want to have only Num Lock automatically turned on, but this Registry hack gives you the power to force any combination of keys on or off.
Start>Run then type in "regedit" whithout quotes.
HKEY_USERS.DefaultControl PanelKeyboard.
3eaaaca.jpg Find the String value
InitialKeyboardIndicators. By default, it is set to 0, which means that Num Lock, Scroll Lock, and Caps Lock are all turned off. Set it to any of the following values, depending on the combination of keys you want turned on or off:
0 Turns off Num Lock, Caps Lock, and Scroll Lock
1 Turns on Caps Lock
2 Turns on Num Lock
3 Turns on Caps Lock and Num Lock
4 Turns on Scroll Lock
5 Turns on Caps Lock and Scroll Lock
6 Turns on Num Lock and Scroll Lock
7 Turns on Caps Lock, Num Lock, and Scroll Lock
Exit the Registry. When you restart, the new setting will take effect.
Note: You have problem with Caps Lock so just modify Caps lock option on Regedit.
And do not forget to run virus scan on your computer once you are done.
Rate always the all answers.
Thank you
Jan 02, 2009 | EzKey EZ8000 Smart Office Keyboard PS2
When i turn my computer on i always have to turn on the num lock. i think my num lock should stay on even though i restart my computer.
How to get Registry cleaner.
Windows XP
Click START>RUN
Type regedit
Click ok
Windows Vista
Click Start and type regedit on your keyboard HIT ENTER.
Than:
you can turn on num lock by changing "HKEY_CURRENT_USER, Control Panel, Keyboard, InitialKeyboardIndicators" to "2"
OR if that single registry entry doesn't solve your problem than go for this.
HKEY_USERS\.DEFAULT\Control Panel\Keyboard\InitialKeyBoardIndicators
Dec 28, 2008 | Logitech Cordless Desktop MX3200 Laser...
Caps Lock / Num Lock shutdown
it may be a computer virus or OS bug
Jul 17, 2017 | Fellowes 59493 Keyboard
Somehow I have locked the keys.
Turn the key? :-) No, seriously not sure what you mean by locking the keys. Did you restart your computer? Have you tried the keyboard on another computer. Check the status of the Num-Lock, Scroll-Lock, Caps-Lock, or F-Lock. Hope this helps.
Sep 09, 2008 | Microsoft Digital Media Pro Keyboard
Keyboard
Can you please clarify this
  1. Do you keys not respond at all
  2. Do you get numbers when you want letters or otherwise letters to numbers
  3. Or does it respond only in one mode numbers only or letters only
My suggestions
  1. If its situation 1 then try reastarting your machine, and unblocking the num lock and vice versa
  2. If its situation 2 just try unblocking num and blocking back by turning on or off the num lock, its just num lock or FN + Num lock in some PC
  3. If its situation 3 just restart your computer.
Mar 25, 2008 | Acer TravelMate 361EV PC Notebook
Computers & Internet Logo
63 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
