Question about Remington T-Studio Pearl Ceramic 1" Slim Straightener
My straightener was plugged in i pulled it out before pressing the off button and the outlet sparked. when i plugged it back in it wouldn't work. How would i fix this ?
    Top Expert:
  • Remington Master
  • 12,223 Answers
Test the c.breaker reset from the wall if use c.breaker wall, or from the service panel c.breaker.
Some times the power cord has c.breaker to reset the button red too.
God bless you
Posted on Oct 11, 2013
How to get Braun curling iron to heat?
Delilah, if it is a new curling iron and you plug it into a known good working outlet and does not heat up, it is defective. Return it to store for replacement or refund. If it is older and out of warranty, it is probably burnt out limit switch or may need rewired with new plug and cord(probably not cost effective, unless you can test and change)
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to fix broken curling iron Hot Tools repair
5 Troubleshooting Tips for Curling Irons
Hair Curler Repair How to Repair Small Appliances Fix It Club
The Beginner Guide to Repairing Curling Wand At Home
Aug 21, 2016 | Braun Irons
Hi guys. I have a Hoover ironspeed IS21-1 steam generator iron. I love this iron it's the best steam generator I've ever had but now once it's heated up and I go to use it as soon as I press the button...
Try unplugging everything that is using that circuit because it's possible that you have too many items plugged up. Also try other outlet.
Jan 14, 2015 | Irons
My Remington Keratin Therapy Flat Iron Doesn't Turn On.
see thi steps and fix it.God bless you
If the iron doesn't heat, make sure 1) power is on to the outlet, 2) check the electrical cord and 3) check the thermostat and replace if necessary. Use the VOM.
Oct 15, 2012 | Remington Style Therapy: Keratin Therapy...
My remington straightener won't work properly. HELP?!
Try wiggling the lead where it goes into the straightener and then the plug. If it works it may be a broken cable in the lead
Jul 29, 2012 | Remington Keratin Therapy 1-In. Hair...
Sparks when you put in plug
Do any other devices or appliances spark when you plug them into the same outlet? If so, you may have a wiring problem, and you should have an electrician inspect the wiring as soon as possible.
If the iron is the only thing that sparks when you plug it into the outlet, there may be a wiring problem inside the iron, or the ground wire may not be connected. Irons are not generally expensive; you should replace the iron for safety's sake.
Nov 29, 2011 | Irons
The boiler drain plug is seized can't loosen it
In another post I suggested that you may need to press a "restart" or "reset" button on the back of the generator mine is a small yellow one. Fill up the water tank to just below fill line and then press the "restart" button which is way up the other end of the machine - at the back end. I just hope your model has this button. Good luck.
Mar 03, 2010 | Tefal Irons
Won't turn on. When I plug it into the outlet and
Free with the help of a friend with knowledge. Thank you.
Nov 02, 2009 | Rowenta Commercial Garment Steamer - White
Moded cs327 wont turn on any more
FIRST CHECK PLUG FUSE HAS NOT BLOWN , THEN CHECK ELECTRICAL WIRE FOR ANY BURNS OR BREAKS.
Oct 27, 2009 | Conair Infiniti Instant Heat Ceramic Hair...
Remington T-Studio Pearl Ceramic 1" Slim Straightener Logo
105 people viewed this question
Top Remington Irons Experts
Are you a Remington Iron Expert? Answer questions, earn points and help others
