Question about Pool & Spa
Polaris gas pouring out exhaust
When I try to turn it on it turns over then gas poors out exhaust. will not turn on
  • 7,482 Answers
Hi sawyer
Sounds like you have dirt/debris in your carburetor jets, fuel passages or a diaphragm that is becoming non-flexible.
Check/Clean/Replace your Air Filter, a dirty air filter can make your engine run to rich with fuel.
Note: ALWAYS USE COMPRESSED AIR TO CLEAN YOUR JETS AND PASSAGES, VERY IMPORTANT.
Note:Before you disassemble the carburetor:
Write down on a piece of paper and or take a picture of how the linkage attaches to your carburetor for later reference when you go to reinstall your carburetor.
Mark each piece with a awl, or some kind of sharp instrument that will make an alignment scratch before you disassemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Sometimes you can get by with priming the carburetor or by using a very small shot of starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Check you fuel line/s condition...after a while they will degrade and need replacement.
Check/Clean/Replace your fuel filter if you have one.
When you remove your fuel lines from the carburetor be sure to make a drawing or take a picture of how the lines are connected to the carburetor.
Also a good time to take a picture for later reference for reassembly.
If the mower is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
The diaphgram may look good and flexible, but it can be deceiving and not act as a fuel pump as it should because it has become too hard and will cause hard starting,start and run and shut off, etc.
When you clean your carburetor, I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use COMPRESSED AIR to blow out all the fuel and air passages.The higher air pressure is needed to blow some of the trash/debris from the fuel or air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit, or you could also ask the parts man that you get your kit from.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Once you have your carburetor cleaned/rebuilt that should solve your problem.
Bud
Posted on Oct 12, 2013
I have a Polaris 550 gas is pour out the cylinder hear holes when it turn over ???what do you think is wrong a lot of fuel coming out
It sounds like the carburetor has a sticking float and is letting fuel in after the float bowl is filled.
Dec 14, 2016 | Polaris ATV
94 lexus es 300 leaking gas and white smoke from exhaust tail pipe and when I turn off the car it starts to pour out of the same spot
Charles, after searching the net., stuck injectors,faulty fuel pressure regulator or faulty ECU. Have a good Tech, check engine codes, diagnose and estimate repair. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
White smoke out of exhaust not what you think Club Lexus Forums
Es300 Smoking Bad And Gas Smell Help
http://www.automotiveforums.com/t967184-_93_lexus_es300_fuel_in_exhaust_runs_rough.html
Jul 09, 2016 | Lexus Cars & Trucks
95 polaris xplorer wont stay runnin
There are many reasons your car may not start. Check the fuel supply to your engine. If that's okay, check the wiring to and from the starter for a loose connection. If there is a "clicking" noise when you try to start it, you may need a new starter.
FGTech Galletto 2-Master EOBD2 V51 BDM-TriCore-OBD
Dec 17, 2012 | Polaris ATV
1997 polaris trail blazer 250 fuel pouring out of exhaust
Your needle and seat is stuck open.Youll have to open up the carb.
I have changed lots of these. I worked for polaris for nine years.
Jun 06, 2012 | Polaris ATV
2003 polaris magnum 330 i have cleaned the carb, gas hose to the carb i also cleaned. when ever i start it the only way it runs is with the choke on and no gas is pouring out of the gas line and the t
Sounds like contamination has set into the fuel shutoff valve on the bottom of the fuel tank, or the fuel cap vent hole is plugged. Test the fuel line that comes from the fuel tank. First turn the valve off, disconnect the fuel line that feeds the carb, insert the fuel line into clear small container, then open the fuel valve to the on position and look for fuel flow,now turn the valve to the reserve position and check again for fuel flow. If these test fail to yield fuel try the procedure again this time with the fuel tank cap loosened and check for fuel flow. If in both tests the fuel fails to flow then the problem can be isolated to the fuel valve/tank outlets or the fuel line to the carb.
Dec 09, 2011 | Polaris ATV
Will not start but if i poor gas in the carburator it will then when i shut it off and then try to start it it will not start back up unless i poor gas in the carb what could it possibly be thank you....
Its faulty fuel pump.When you pour gas in carb, it gets fuel directly, but when you start without pouring gas, then fuel is not reaching there.Low fuel pressure.Replace fuel pump and fuel filter.----- Thank you.
May 19, 2011 | 2000 Chevrolet Blazer
Changed spark plug. Gas is backing up into the airfilter box. backfires sometimes. Has suction going into the carb when turning over and pressure coming out of the exhaust when turning over. Any idea what...
YA SOUNDS LIKE THE NEDEL IS STIKING IN THE CARB LETING GAS RUN IN YOU NEED TO CHANG THE OIL OUT TO AND CLEAN AND PUT A KIT IN YOUR CARB IF ITS GETING FIRE TO THE PLUG THAT SHOULD FIX YA UP LET ME KNOW
Oct 15, 2009 | Polaris ATV
Sportsman 800
HELLO;Yes if the motor wasn't rebuilt with a piston of lower compression than your running at a higher level and you might look at rejetting the carb and also checking the timeing. GOOD LUCK......GREASY.
Aug 24, 2009 | Polaris ATV
Polaris Xpress 300. Won't start, backfires through carb sometimes
Sounds like maybe the needle and seat in the carb letting gas through.
Jun 28, 2009 | Polaris ATV
Front wheels don't turn
It's probably a damaged drive gear. Polaris was at one time giving out free repair kits for this problem because of the poor design of the original.
Apr 18, 2009 | Polaris 280 In - Ground Pool Cleaner with...
Pool & Spa Logo
35 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
