Question about Motorola Mobility H730 Bluetooth Headset
Motorola H730 Blue tooth red light flashes when charging
After charging it over night the red light just turned off. I unplugged the charger and replugged it in and shortly afterwards the red light started to flash 8 times quickly and the 9th flash was noticeably longer. When flipping the boom open there is no start up sound, and pressing any of the buttons does nothing. Seems as though its not holding a charge?? Ideas or is this junk
5 Suggested Answers
SOURCE: H700 automatically disconnects though fully charged
I had the same problem. It does seem to be related to the battery. The solution--in my case--was to recharge the headset until the light turned green again and then flip it open and it hooked up again.
Posted on Apr 15, 2008
  • 3 Answers
SOURCE: Light always ON!!!
hold the button and wait till the light blinks twice and it will turn off
Posted on Jun 30, 2008
  • 23 Answers
SOURCE: My motorola h721 keeps blinking red.
if you didn't pair your phone up yet, that could be why. Hold all 3 buttons down for 10 sec. should go solid blue, then pair your phone cause its in discovery.
Posted on Aug 19, 2009
edkiniry
  • 17 Answers
SOURCE: Motorola H730 will not turn on even though it is fully charged
Sometimes they just die. Many electronic items, that have rechargeable batteries, need to be charged on a periodic basis in order to maintain the battery's functionality. If it's under warranty, Motorola is very good about replacing it. Otherwise, assume you'll need a new one. Good luck.
Posted on Dec 03, 2014
Motorola h730 won't charge
This is the complicated issue when you don't know if the problem is with your charger, the battery or simply the cable .
If you don't have a testing device, I suggest you to check the charger at some electronic repair shop so they should detect the origin of your problem
Jul 05, 2015 | Motorola Radio Communications
Karen-
Are you getting a steady blue light when you follow the pairing procedure? Or are you unable to get it to stay on stead?https://www.motorola.com/moto_care/manuals/BT/H730_QSG.pdf
Mark
Forums Manager
Dec 02, 2014 | Motorola Mobility H730 Bluetooth Headset
Solid red light
This may be initially. Leave it on the charger over night.
Mark
Motorola Support
Mar 02, 2014 | Motorola Mobility H730 Bluetooth Headset
BLINKING RED LIGHT WHEN TRYING TO CHARGE UNIT
I fixed this problem by connect it on the charger,hold +and - keys together for 10 seconds,it started to charge and work well.
Jan 21, 2014 | Motorola Mobility H730 Bluetooth Headset
I put my motorola h730 on the charger last night now my bluetooth doest come on
Tamika-
Do you have another charger to test with your headset? Make sure you have the mic boom closed when charging.
Mark
Motorola Support
Motorola Support Find Answers Motorola Mobility Inc
Jan 10, 2014 | Motorola Mobility H730 Bluetooth Headset
Red blinking light
Hi, Ephraim. The flashing red light indicates that the device is showing "low battery". It could be that the LG phone charger fits the charging port on your bluetooth headset but it is not compatible with your device. In order for you to know that it is charging, the device should show a steady red light(means charging).
Please take a look at the table reference below.
•With the Charger Plugged In
______________________________________________________________________
•Headset Indicator Headset Status
Red-----------------------------------------------Charging (battery level less than 50% charge)
Yellow-------------------------------------------Charging (battery level more than 50% charge)
Green--------------------------------------------Charging complete
With No Charger Plugged In
Off ---------------------------------------------Power off
Three blue flashes------------------------Powering on/off
Steady blue --------------------------------Pairing/connect mode
Rapid blue/purple flashes -------------Connection successful
Quick blue flash --------------------------Incoming/outgoing call
Slow blue pulse --------------------------Connected (on a call)
Slow blue flash ---------------------------Standby (not on a call)
Slow red flash ----------------------------Idle (not connected to phone)
Slow purple pulse -----------------------Connected call muted
Steady red ---------------------------------Attempting to connect
Quick red flash ----------------------------Low battery
Note: After 20 minutes on a call or of inactivity, the light stops flashing to conserve power, but the headset remains on
Hope that'll help you in some way.
**Please rate my post and/or leave a comment** ...Thanks...
Sep 25, 2013 | Motorola Mobility H560 Bluetooth Headset
They Won't Charge!
Try to press the power boton in the same time you plug the charger, after this action mine is working and charging perfectly, maybe this is the "reset" solution... Hope this helps you.
Nov 17, 2009 | Motorola Mobility S9 Headphones
Motorola Mobility H730 Bluetooth Headset Logo
83 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
