Question about Lanier Office Equipment & Supplies
Lanier 5635 Im trying to setup my Lanier 5635 with my Mac. But Im not sure how. Please help
20YrsCompExp
  • 227 Answers
SOURCE: how can I find a schematic design of Lanier Model 5635/5645 Copie
Goto my website and Download the file from the Public Folder. It is the only Point 2 Point in the folder.
Do not forget to vote Yes or No if this information was helpful
www.copytech21.spaces.live.com
Posted on Apr 01, 2009
  • 32 Answers
SOURCE: meter reading
2 ways to check the meter.
press the user tools button on the op panel. on the screen press counter. you can either view the counter on the screen, or press print counter, and it will give you a hard copy.
the 2nd way is to look behind the front cover, probably behind a piece of tape, on the right side, about half way down.
Posted on Apr 02, 2009
Ickoajnc
  • 183 Answers
SOURCE: Where is the used toner bottle located on the
The transfer belt is located on right side of the machine. When you open the duplex unit if you have on the machine which can be opened by the pull plug which is located on the right- front corner of the duplex unit and then you have another pull plug on the same location with which you will open the right door of the copier. Inside on the side of the opened door it has an black case on which has attached an brown belt on the top of the black case has an lite green colored pulling plug which has to be pulled up and then you can pull up the black case and remove from the machine than you will see that the brown belt can be removed and under the belt has a black seal on which has 6 screw's open it and inside you will see than a lot of toner has been loaded remove it with vacuum cleaner or empty the case in some bag or something and then repeat the procedure clockwise and turn on the machine and the problem is solved.
If this can't help you than better is for you to call a techinican
Posted on Jul 10, 2009
  • 11 Answers
SOURCE: I have a Lanier 5635 and its not working. The
546 A Unstable fusing temperature The fusing temperature varies 50°C or more within 1 second twice continuously. • Thermistor defective(temp. senzors in the fixing unit) • Poor connection of the fusing unit • Power supply unit defective
Posted on Jul 12, 2010
  • 903 Answers
SOURCE: Lanier 5635 error code displaying
sc320 on the Lanier 5635 is a laser unit error code. Often if you power cycle the machine (turn it off with the orange power switch on the left side of the copier, wait a few seconds, then turn it back on) the code will clear and the copier will resume normal operation. If the error code comes back or doesn't clear, you'll probably need to replace either the entire laser assembly or the polygon mirror motor inside the laser unit. These are best done by a professional -- contact your local Lanier service company if the problem persists.
Posted on Nov 18, 2010
Sc542 error on lanier
That is a dirty thermistor in the fusing unit.
Apr 14, 2014 | Lanier 2045 2145 5635 5645 Toner 23 000...
Lanier 5635 Sorter
Under user tools, system settings make all prints, copies to come out in internal tray, the front and rear covers have to come off to remove screw 1 each side the SC code is shift tray motor error
Dec 18, 2013 | Lanier Office Equipment & Supplies
Why is my Lanier 5635 display screen dark?
On the left of the operation panel you have the dial contrast. Try to adjust that. If doesnt work problably you have a broken LCD
Feb 16, 2011 | Lanier Office Equipment & Supplies
Lanier 5635 error code displaying a SC320
Oct 15, 2010 | Lanier 5222/27 Laser Printer
I have a Lanier 5635 and its not working. The error code is SC546. Ant ideas whats going on.
Jun 23, 2010 | Gestetner DSm515pfd Digital Copier -...
Lanier 6725 copier: Paper is always jamming and
I have worked for Lanier for 20 years, the 6725 was a great machine, but getting parts, spending $$$ and still having an old copier. Lanier is owned by Ricoh and all machines are Ricoh with a Lanier sticker on it. Its time.
-Carl, please let me know if this helps.
Jun 26, 2009 | Office Equipment & Supplies
IMac connection to lanier ld122
Does this printer have the PS option installed? If not you will be unable to print even if you clear up the network issue.
As far as network goes is it currently connected and working with other PCs?
Mac printing is easily setup by typing the IP address of equip in the queue box upon setup. I believe the default queue name is "print" all lower case. If IP in unable to work properly make sure lanier has appletalk turned on and setup printer using appletalk.
Again if the machine doesn't have Postscript option you won't be able to print anything.
Hope this helps,
TankMurdock
Apr 23, 2009 | Office Equipment & Supplies
How can I find a schematic design of Lanier Model 5635/5645 Copie
Apr 01, 2009 | Lanier Office Equipment & Supplies
Meter reading
Nov 20, 2008 | Lanier 1205 Copier
23 people viewed this question
Top Lanier Office Equipment & Supplies Experts
quennie732
Adorjani Laszlo
Anthony Karuku
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
