Question about Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348
Right wheel will turn but sounds striped - Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348
  • 118 Answers
Are you sure its not the gears meching that you hear.
Posted on Oct 11, 2013
No sound from new install Pioneer DEH-X6600BT
You may be using the wrong adapter. Your Durango has a DK GRN/RED wire that supplies power to the separate amplifier. Your adapter may not have provisions for connecting the steering wheel controls to your new radio. Also check 15A FUSE 4 in the junction block in case it is open.
Dec 29, 2013 | Pioneer Deh-X6600bt Car Cd Receiver...
MY 72 SUPER BEETLE STEERING COLUMN MAKES A CLICKING NOISE AND WON'T TURN THE WHEELS FROM LEFT TO RIGHT
Sounds like you have striped out your steering box. I would start there as long as everything is hooked up as it should be.
Nov 28, 2013 | Volkswagen Beetle Cars & Trucks
I have a 2004 chevy malibu with 200 some thousand miles. as I was backing out over my drive today my steering wheel started to knock and the wheels won't turn. It finally did turn after about one and a...
you might have a bad worm gear ,its a gear for tighting the action of the steering wheel,i would have your tech look at it ,but most cases are to replace steering box.
Jul 25, 2011 | 2004 Chevrolet Malibu
Where can i get a wiring diagram for my 2002 chrysler neon auto
12V CONSTANT WIRE RED and PINK/BLACK Ignition harness
12V IGNITION WIRE DARK BLUE Ignition harness
12V ACCESSORY WIRE BLACK/ORANGE Ignition harness
STARTER WIRE YELLOW Ignition harness
PARKING LIGHTS (+) BLACK/YELLOW At Headlight switch
POWER DOOR LOCK (5-wire reverse polarity) ORANGE/PURPLE Harness Coming Into Vehicle From Driver's
Door
POWER DOOR UNLOCK (5-wire reverse
polarity)
PINK/PURPLE Harness Coming Into Vehicle From Driver's
Door
DOOR TRIGGER (-) YELLOW/BLACK At Headlight Switch
DOMELIGHT SUPERVISION (-) Use door trigger
TRUNK TRIGGER (-) GRAY/BLACK At Light In Trunk
TACHOMETER WIRE TAN/BLUE or BLACK/GRAY At Ignition Coil
BRAKE WIRE (+) WHITE/BROWN At Brake Pedal Switch
HORN TRIGGER (-) BLACK/RED Harness Coming From Steering Wheel At
Column
CAUTION! SRS airbag wires are not enclosed in protective loom at the steering column. They are a twisted pair of wires that run with rest of
ignition harness. Be careful not to cut or probe these wires.
Radio:
(Black plug)
Rear Right speaker -: Blue w/White stripe
Rear Left speaker -: Brown w/Yellow stripe
Front Right +: Purple
Front Left +: Dark Green
Rear Right speaker +: Blue w/Orange Stripe
Rear Left speaker +: Brown w/Blue Stripe
Power Antenna/Amp: White
(Gray Plug)
+12v battery wire: Pink or Pink w/White Stripe
+12v Ignition wire: Red w/ White Stripe
Front Right speaker -: Blue w/ Red Stripe
Front Left speaker -: Brown w/ Red Stripe
May 03, 2011 | 2002 Dodge Neon
Sounds like the sterring wheel is striped
Sorry I don't have a solution but have a similar problem. I replaced the steering pinion gear in hopes that would resolve the problem, but it didn't. The steering pinion gear is located at the bottom of the steering shaft and turns the steering gear. Looks like the steering gear needs to be replaced as well. The nuts securing the steering gear are accessible in the same area as the pinion steering gear. I am going to order a replacement steering gear and attempt to replace it.
Jul 09, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Wheel turnd left OK Wont turn right, Get loud
THE GEAR ON THE SHAFT IS STRIPED OUT NEEDS A NEW ONE
Sep 05, 2009 | Garden
Im installing a new sterio in a 95 mustang ----i need a colour code dia. of the wires on the old factory sterio. Which wire goes where?
A Right Rear Spkr (-) Dark Brown w/ Pink Stripe Purple w/ Black Stripe
B Right Rear Spkr (+) Tan w/ Green Stripe Purple
C Right Front Spkr (-) Green w/ Orange Stripe Gray w/ Black Stripe
D Right Front Spkr (+) White / Green Stripe Gray
E Left Rear Spkr (-) Tan w/ Yellow Stripe Green w/ Black Stripe
F Left Rear Spkr (+) Tan w/ White Stripe Green
G Left Front Spkr (-) Lite Blue w/ White Stripe White w/ Black Stripe
H Left Front Spkr (+) Orange w/ Green Stripe White
I Amplifier Turn On Do Not Use For This Vehicle
J Power Antenna Turn On Do Not Use For This Vehicle
K Ground Wire Black w/ Green Stripe Black
L Do Not Use For This Vehicle
M Dash Light Dimmer Wire Orange (if available)
N +12 Volt Ignition Wire Thin Black Wire Red
O Do Not Use For This Vehicle
P +12 Volt Battery Wire Green w/ Black Stripe Yellow
Jun 17, 2009 | 1995 Ford Mustang
Can i get wiring diagram of sterio for Acura Rsx 2004?
Generally there are two types of wires , power , and sound. The power wires will usually be black , red , and yellow or orange. Might also have a blue one. Black is ground , Red is constant power , yellow or orange is accessory power ( only energized when key turned on) .
If you have a blue wire , it sends out power when stereo is on , to power an electric antenna or turn on an external amp. All other wires will be in colored pairs. For example Green and Green with a black stripe , Grey , and Grey with a black stripe , purple and purple with a black stripe.......These are all speaker wires , the solid color one is the + and the one with the stripe is the - , EG: Grey might be right front + , and Grey with black stripe would be right front -
May 03, 2009 | 2003 Acura RSX
Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348 Logo
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
