Question about Vehicle Parts & Accessories
Autopage rs622 no longer starting car - Vehicle Parts & Accessories
  • Andrew Fodor
    Andrew Fodor Oct 12, 2013
    I have an AutoPage RS622 alarm with remote start installed in a 2007 Toyota Tacoma. I have the 5 button extended rage remote, not the LCD remote. Everything was working just fine until recently, the truck will not start remotely. When I press the Start button on the remote, the ignition system enters the "On" state: the parking lights come on, the dashboard lights up, the A/C fan comes on like they are supposed to, but the engine does not start. I was able to adjust start button settings from single press to double press, etc, but nothing seems to get that last step of actually starting the engine. Any suggestions on troubleshooting this?
  • Andrew Fodor
    One more thing: I have a solenoid switch inside the engine compartment that closes just before the engine starts to charge a second battery. It still closes which further confirms that the ignition system has entered the "On" state, but no engine start.
Xt 33 autopage (crank) but no start
could be your car requires a bypass module... or the safety inputs preventing the alarm from starting car are in place... without knowing your make/model that's the best I can do...
Jul 18, 2016 | Autopage Vehicle Parts & Accessories
My autopage remote wont start
RF425 is an alarm only, it does not start the vehicle.
Aug 23, 2011 | AutoPage RF425 LCD (RF425LCD RF425 LCD)...
My autopage rs 727 lcd is not starting in remote start, it is only cranking
what kind of vehicle? it is most likely a transponder or theft system bypass problem, since it is trying to crank.
Feb 12, 2011 | C3RS727LCD 4Channel Alarm with Remote Car...
The lights no longer blink when unlocking and do not come on when starting
you will need to check the fuse, located on the 5 pin harness at the main brain. It is white in color.
Dec 26, 2010 | RS855LCD AutoPage MultiChannel 2 Way...
I have the normal alarm Autopage AutoPage C3RS603
Nothing is hard to hookup just time consuming andf it all depends on how good you R with wiring how good R you..?
Jul 16, 2010 | C3RS603 2Channel Remote Start Module with...
Vehicle Parts & Accessories Logo
27 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
