Question about Westwind Classic Hugger Polished Brass 52" Ceiling Fan
Purple orange yellow and black wires on 3 speed harbor breeze where do they go on the replacement switch?
2 Suggested Answers
worldvet
  • 859 Answers
SOURCE: Trying to replace 3 speed ceiling fan switch
The black goes to the L connection the others are a guess. You can do this two ways. Connect the colored wires in any sequence and then see what switch sequence give you high and lowest, the other one will be medium. Once you determine that, mark the wires with a piece of masking tape as high, medium and low. Otherwise you connect them, turn power on and use a multimeter to see which color gives you the highest voltage and which gives you lowest. Since you aren't comfortable using live wires and a meter, go with the first option and use the process of elimination to find the wires giving you the speeds you need to find the highest and lowest. Next, you need to determine how your switch sequence works. First pull has to give you highest speed. so you may end up wiring them in reverse if your first attempt is backwards. There is a reason the first pull needs to be highest, it powers up the motor so you can then chose a lower setting. A low setting first will over tax your motor and wear it out eventually as it has to work harder at first.
Let me know if you need further clarification and perhaps this is all you need to get fixed.
Regards,
Worldvet
ps I checked on the Internet of a wiring diagram and I bet you did tok all to no avail.
Posted on May 27, 2008
I have a harbor breeze Centreville ceiling fan when installing the motor my son dropped it. i now have 4 loose wires- orange, yellow, purple and black. not sure where they connect.
Sorry, the best I can give you is something you may have already tried. Harbor Breeze help line.
Their number is 1-800-643-0067, option 2. Hours of operation are 8-6 M-Thurs, 8-5 Fri EST.
Jul 17, 2016 | Dryers
How do I connect the purple,brown,grey and black wires to a harbor breeze fan?
Try this; Purple - 3
Brown - 2
Gray - 1
Black - L
If this doesn't work you probably have the wrong switch. Just because they look the same on the outside doesn't mean they're the same on the inside!
Jun 09, 2015 | Dryers
I need to connect Orange, Yellow, Purple and Black wires from fan into the correct corresponding numbers on fan switch 1,2,3, L (0033906)
Try this; Orange - 1
Yellow - 2
Purple - 3
Black - L
If this doesn't work, you probably have the wrong switch. Just because a switch looks the same on the outside doesn't mean it's the same on the inside.
May 13, 2015 | Dryers
Which wires go to 3 speed fan switch L 1 2 3 i have a black ,orange,yellow ,purple wires?
Try this; ! - orange, 2 - yellow, 3 - purple & L - black
Aug 17, 2014 | Dryers
Westinghouse 3speed fan switch 77288
It's the westinghouse switch. Many results on search. I just wasted 2 hours playing switching wires all combos. Others suggested the switch from Lowe's. Harbor breeze #0033905 . Plug wires back in as you listed Black L, Grey 1, Brown 2, Purple 3. Works perfectly for $3.98 plus tax.
Others said you can call Hampton Bay and get the replacement also.
Sep 24, 2013 | Hampton Bay Dryers
I don't know witch wires go where?
Hello. The most common configuration is: L - Orange, 1 - Black, 2 - Yellow, 3 - Purple
. Here's a link to some troubleshooting advice: http://www.ceiling-fans-n-more.com/ceiling-fan-pullchain-replacement-and-repair.php and a link to diagrams: http://www.hurontel.on.ca/~taitg/pages/cfan.html
Hope this helps, and don
Apr 15, 2010 | Speed Ceiling Fan 3-speed Switch By...
I have the aloha model 5745, need to replace speed switch, which wires go where? yellow purple, black, orange;L 1 2 3
I'm an electrician and
I just replaced the speed switch on a 5745. This people at Aloha Housewares, Inc. were very nice and speedy in sending a new unit at no cost.
Connections are:
1=yellow
2=purple
3=black
L=orange
Jul 11, 2009 | Aloha Housewares (93645) Ceiling Fan
I have a westinghouse three speed fan. there are 4 wires a black, purple orange and yellow . the new switch has four connectors L 1,2,3 does any one know witch goes where? thanks , i bought the new switch...
ok. hope this helps, use a switch from FANTEC. it'll be called a 3 speed fan switch. CAM #5 No. 21105. this will also say Single Layer 3 or 4 wire application SPLIT continuity function.. THE SPLIT PART IS VITAL. now when wire it. the BLACK wire goes in SLOT 3. ORANGE wire goes in L. PURPLE wire goes in slot 2, ORANGE wire goes in slot 1. IF, and i repeat IF this does not work for you ensure you have a SPLIT CONTINUITY FUNCTION switch. NO MATTER WHAT the BLACK wire WILL go into slot 3. the ORANGE wire WILL go in slot L. switch the orange and purple wires only. ENSURE POWER IS OFF WHEN CONNECTING OR DISCONNECTING WIRES. YOU WILL GET THE SNOT ZAPPED OUTTA YOU IF YOU DON'T. please post if this helps.
May 02, 2009 | Westinghouse Electric Westinghouse...
Hampton bay ceiling fan
we have a hampton bay fan burning smell coming in didnot run
May 14, 2008 | Hampton Bay 24002 Ceiling Fan
This should do the trick. Good luck and make sure the power is off.
Jan 28, 2008 | Hampton Bay 24002 Ceiling Fan
Westwind Classic Hugger Polished Brass 52" Ceiling Fan Logo
47 people viewed this question
Top Westwind Dryers Experts
Dan Webster
Dan Webster
Are you a Westwind Dryer Expert? Answer questions, earn points and help others
